POV-Ray : Newsgroups : povray.general : error in vegetate.inc Server Time
17 Jul 2026 07:27:53 EDT (-0400)
  error in vegetate.inc (Message 1 to 10 of 13)
Subject: error in vegetate.inc
Date: 21 Jun 2001 14:33:13
Message: <3b323de9@news.povray.org>
I get this error when running the vegetate.inc in my scene...
C:\Program Files\POV-Ray for windows\Include\Vegetate.inc:387 warning: csg
union unnecessarily bounded.
These are the settings, as they appear in my scene file...
#declare VegeNumber = 500;
#declare VegeAlign = on;
#declare VegeWaterLevel = 10.0026;
#declare VegeMaxSlope = 80;
#declare VegeMaxScale = 1.5;
#declare VegeMinScale = .9;
#declare VegeList = array[5]
#declare VegeList[0] = object{rock scale 2 }
#declare VegeList[1] = object{TREE scale 7 }
#declare VegeList[2] = object{flower scale 2}
#declare VegeList[3] = object{rock scale 2.5}
#declare VegeList[4] = object{flower scale 2.5}
object{ VegeObject }
#include "vegetate.inc"
I also have the standard includes at the top of the scene...Ideas?
C.J. - POV User
POV Ray Study Gallery
http://hyperion.spaceports.com/~povstudy/
hou### [at] yahoocom
Subject: Re: error in vegetate.inc
Date: 21 Jun 2001 16:08:08
Message: <3b325428@news.povray.org>
In article <3b323de9@news.povray.org> , "C.J. - POV User"
This is a warning, not an error!  Read about manual bounding of objects in
the documentation.
     Thorsten
Date: 22 Jun 2001 06:08:51
Message: <3b331933@news.povray.org>
C.J. - POV User <hou### [at] yahoocom> wrote:
: I get this error when running the vegetate.inc in my scene...
: C:\Program Files\POV-Ray for windows\Include\Vegetate.inc:387 warning: csg
  As Thorsten noted, you speak about an error while povray speaks about a
warning.
  AFAIK POV-Ray issues this warning when the user-specified bounding box is
bigger than the one calculated by POV-Ray itself. You can either define the
bounding box better, remove it (and see how it affects speed), or just ignore
the warning.
Date: 22 Jun 2001 08:37:14
Message: <3b333bfa@news.povray.org>
"Warp"  wrote  >   As Thorsten noted, you speak about an error while
> warning.
box is
define the
ignore
> the warning.
 - Warp -
 I've had the same thing happen in tomtree ...
 however, when I removed it, the render times skyrocketed so I put it
back.
 I haven't yet fingered out how to better define it.
 Y
Date: 22 Jun 2001 09:17:01
Message: <3b33454c@news.povray.org>
yooper <Out### [at] huntelnet> wrote:
:  I've had the same thing happen in tomtree ...
:  however, when I removed it, the render times skyrocketed so I put it
: back.
  Sometimes POV-Ray thinks that she knows better than the users, but as
all humans, also she can make errors.
Date: 22 Jun 2001 12:36:23
Message: <3b337407@news.povray.org>
Sorry everyone I miss spoke. I meant Warning. As the warning states it is
occuring in the Vegetate.Inc. I thought this was more serious because it
seem to hang my machine. I was really being impatient. I have it running now
(on its second hour) and it is past all the warnings. It is spending a lot
of time on creating bounding slabs. This is just a bit more demanding scene
than what I usually make...so my PC is chomping away at it.
BTW - Is there any more information on manual bounds? I found just a little
info. in POV about it.
C.J. - POV User
Warp <war### [at] tagpovrayorg> wrote in message news:3b331933@news.povray.org...
csg
> warning.
is
the
ignore
> the warning.
Date: 22 Jun 2001 13:54:32
Message: <3B3386B2.E7FF1C51@inapg.inra.fr>
Note that scene files that generates lots of warnings can have very long parsing
time due to the display of said warnings. One workaround is to turn the warnings
off (-GW on the command line).
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 23 Jun 2001 02:26:59
Message: <3b3436b3@news.povray.org>
C.J. - POV User wrote in message <3b323de9@news.povray.org>...
I don't see where that warning could be coming from.  Line 387 of
Vegetate.inc reads:
 object{VegeList[VEGENUM[VEGEcounter]] transform VEGETrans[VEGEcounter] }
As you can see, I don't add a bounding box to the object.  The only thing I
can think of is that one of the objects in your list has an unneeded
bounding box, but in that case, the error message should be pointing to
where the object is declared.
The long time spent building bounding slabs is much easier to explain.  You
specified that Vegetate place 500 objects randomly selected from your list,
and presumably one or more of "rock", "flower", and "TREE" is a union of a
large number of primitives.  A hundred or more of that union will result in
a very large number of objects for POV-Ray to generate a bounding tree for.
Mark
Date: 23 Jun 2001 10:51:36
Message: <3b34acf8@news.povray.org>
You win the prize Mark! I found the source of the warning. "TREE" is the
Birch settings from tom tree. Tom Tree and Vegetate both use bounding. To
get around this went into Hammapatch and made a basic palm instead. This
worked OK, but would generate a page falt in windows, if I had more than 200
objects in code (VEGEnumber = 200).  200 was not a high enough number of
objects for my island, so I went and pruned my palm back in Hamma and was
able to generate more than 200. But it was very slow...So I remove the
flower and the palms. Now I'm working with the rocks and a simple grass
model. this allows me to add 10000 objects with out it dying on me. =^)
C.J. - POV User
Mark Wagner <mar### [at] gtenet> wrote in message
news:3b3436b3@news.povray.org...
csg
> Vegetate.inc reads:
I
You
list,
in
for.
> Mark
Date: 23 Jun 2001 10:52:23
Message: <3b34ad27@news.povray.org>
Thanks Gilles! That'll help.
C.J. - POV User
Gilles Tran <tra### [at] inapginrafr> wrote in message
news:3B3386B2.E7FF1C51@inapg.inra.fr...
is
parsing
warnings
> G.
> Graphic experiments
> Pov-ray gallery
