POV-Ray : Newsgroups : povray.general : yet another sig Server Time
25 May 2026 22:36:51 EDT (-0400)
  yet another sig (Message 1 to 10 of 10)
Subject: yet another sig
Date: 11 May 2001 09:23:03
Message: <3afbe7b7$1@news.povray.org>
# 4 (standard pov) - obfusticated enough? (and BTW this is extremely
addictive).
#macro G(D,E,F)#declare I=array[3]{D,E,F}#declare
B=0;triangle{#while(B<3)#declare
C=1;#declare
H=strlen(str(I[B],0,0));#while(C<=H)A[val(substr(str(I[B],0,0),C,1))]
+#declare C=C+1;#end<-5,-2,9>#declare B=B+1;#end}#end#declare
A=array[7]{x*1,x*2,x
*4,y*1,y*2,y*4,z*1}light_source{-A[1]-A[2]-z*9 rgb
1}union{G(105,10,146)G(105,246,
10)G(105,56,146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb
1}}//TM
Here are my other sigs in one place for ABX
#1 (requires mp)
#version unofficial MegaPov.6;#init_3d_spline{"",x*2,<2,5>,y*2,<4,3>,<3,2>,
<5,2>,<4,3>,<6,3>,<6,2>,<6,3>,<7,2>,<8,3>,<8,2>}#macro B(C,D)$A=0;#while
(A<1)glow{type 0location z*25radius 100fade_power 3color D size C
translate eval_3d_spline("",A)}$A=A+.002;#end#end
B(.05,red.9)B(.1,blue.9)//TM
#2 (requires mp)
<3,2>,<5,2>,<4,3>,<6,3>,<6,2>,<6,3>,<7,2>,<8,3>,<8,2>}#macro C(D)$B=0;
#while(B<1)sphere{eval_3d_spline("",B)D translate z*25}$B=B+.002;
#end#end union{C(.1)pigment{blue.9}finish{ambient.9}}merge{C(.5)
pigment{rgbt.9}interior{media{emission blue.7}}hollow}//TM
#3 (standard pov)
#macro A(B,C)light_source{B+z*-9C}#end
camera{location-9*z}plane{-z,-9pigment{rgb.9}}triangle{y*2,-x,x}
A(x*-7,blue.9)A(x*-4,blue.9)A(<2,-4,0>,red.9)A(<-2,-4,0>,red.9)//TM
Subject: Re: yet another sig
Date: 11 May 2001 09:26:29
Message: <3afbe885@news.povray.org>
Bah - word-wrap settings... try again.
#macro G(D,E,F)#declare I=array[3]{D,E,F}#declare B=0;triangle{#while(B<3)#declare
C=1;#declare H=strlen(str(I[B],0,0));#while(C<=H)A[val(substr(str(I[B],0,0),C,1))]
+#declare C=C+1;#end<-5,-2,9>#declare B=B+1;#end}#end#declare A=array[7]{x*1,x*2,x
*4,y*1,y*2,y*4,z*1}light_source{-A[1]-A[2]-z*9 rgb 1}union{G(105,10,146)G(105,246,
10)G(105,56,146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Date: 11 May 2001 10:50:13
Message: <3afbfc25@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
: #macro G(D,E,F)#declare I=array[3]{D,E,F}#declare B=0;triangle{#while(B<3)#declare
: C=1;#declare H=strlen(str(I[B],0,0));#while(C<=H)A[val(substr(str(I[B],0,0),C,1))]
: +#declare C=C+1;#end<-5,-2,9>#declare B=B+1;#end}#end#declare A=array[7]{x*1,x*2,x
: *4,y*1,y*2,y*4,z*1}light_source{-A[1]-A[2]-z*9 rgb 1}union{G(105,10,146)G(105,246,
: 10)G(105,56,146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
  Don't know if this version is less obfuscated, but at least it's shorter:
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
Date: 11 May 2001 11:01:26
Message: <3afbfec6@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3afbfc25@news.povray.org...
Bah! I even remembered that "local" would be shorter than "declare" and then forgot
to change it. Oh, well. Hmm, what else has changed? Well, I don't understand the mod
or div stuff (I'll look it up and see if I can figure it out). Ah, so a mesh is just
a union of triangs! Well, we learn something new every day. (well, I knew a mesh was
made of triangles, I just thought internally it would be more complicated).
Right. That's my sig. Ta.
Date: 11 May 2001 11:06:31
Message: <3AFC0036.AF8E63D5@gmx.de>
Tom Melly wrote:
> [...] Ah, so a mesh is just
A mesh is *not* just a union of triangles just to set this right, if many
triangles are involved, a mesh is much more efficient.
Date: 11 May 2001 11:17:12
Message: <3afc0278@news.povray.org>
news:3AFC0036.AF8E63D5@gmx.de...
So internally it's handled differently, but externally it looks like a union?
Date: 11 May 2001 11:23:11
Message: <3afc03df@news.povray.org>
Tom Melly wrote in message <3afbe7b7$1@news.povray.org>...
Thanks. All will be available for viewing after weekend and I'll send url then.
#macro Sig(A,B,X)_(A,B)_(B,X)_(X,A)#end#macro _(A,B)cylinder{<A.x,A.y,3>,<B.u,
B.v,3>.1,9}#end global_settings{max_trace_level 9}light_source{0 1}camera{up y
*4right-3*x}blob{_(<3,1>,<1,-5>)_(<2,-2>,<4,-2>)Sig(x,<-1,1.5>,<1,3>)_(z-1,z-4
)pigment{rgb 1}}box{-3 3pigment{rgb 0}finish{reflection 1}hollow} // POV-Ray31
Date: 11 May 2001 11:31:47
Message: <slrn9fo1f8.m8m.ron.parker@fwi.com>
On Fri, 11 May 2001 16:17:11 +0100, Tom Melly wrote:
>"Christoph Hormann" <chr### [at] gmxde> wrote in message
Almost.  A union can use any texture, but a mesh has to use predeclared
textures.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 11 May 2001 11:34:25
Message: <3afc0680@news.povray.org>
: Well, I don't understand the mod
: or div stuff
  Then it's obfuscated ;)
Date: 11 May 2001 11:41:49
Message: <3afc083d$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3afc0680@news.povray.org...
> : or div stuff
Confusing idiots is easy ;)
