POV-Ray : Newsgroups : povray.general : Test Server Time
24 Apr 2026 16:02:51 EDT (-0400)
  Test (Message 1 to 10 of 10)
Subject: Test
Date: 8 May 2001 07:51:52
Message: <3af7ddd8@news.povray.org>
Just testing the wordwrapping settings.
#local Q=seed(7);#local B=<-2,2,5>;#local E=<2,-2,5>;#local C=<2,4,6>*4;blob{
threshold 1#while(vlength(B-E)>.1)#local S=B;#local B=B+<rand(Q),rand(Q),rand(
Q)>/20;#local B=B-2*(B-S)*(vlength(B-E)>vlength(S-E));sphere{0,1,1 scale.1//NX
translate<B.y,-B.x,B.z>}sphere{0,1,1 scale.1translate B}#end pigment{rgb C}}
Subject: Re: Test
Date: 8 May 2001 10:01:54
Message: <3af7fc52@news.povray.org>
Nekar Xenos <j-p### [at] citywalkcoza> wrote:
: #local Q=seed(7);#local B=<-2,2,5>;#local E=<2,-2,5>;#local C=<2,4,6>*4;blob{
: threshold 1#while(vlength(B-E)>.1)#local S=B;#local B=B+<rand(Q),rand(Q),rand(
: Q)>/20;#local B=B-2*(B-S)*(vlength(B-E)>vlength(S-E));sphere{0,1,1 scale.1//NX
: translate<B.y,-B.x,B.z>}sphere{0,1,1 scale.1translate B}#end pigment{rgb C}}
  Why all that extra unnecessary stuff which makes the signature longer?
  Removing unnecessary stuff gives something like:
#local Q=seed(7);#local B=<-2,2,5>;#local E=<2,-2,5>;blob{#while
{<B.y,-B.x,B.z>,.1,1}sphere{B,.1,1}#end pigment{rgb 9}}//     NX
Subject: Re: Test
Date: 8 May 2001 10:27:10
Message: <3af8023e@news.povray.org>
Like this? (I don't understand the use of '?' and 'B.y' though - ABX helped me
there)
#local Q=seed(7);#local B=<-2,2,5>;#local E=<2,-2,5>;blob{threshold 1#while((E
-B).x>.1)#local S=B;#local B=B+<rand(Q),rand(Q),rand(Q)>/20;#local B=(vlength(
B-E)<vlength(S-E)?B:2*S-B);sphere{<B.y,-B.x,B.z>,.1,1}sphere{B,.1,1}#end
pigment{rgb<8,16,24>}}// nekar Xenos
Subject: Re: Test
Date: 8 May 2001 10:45:27
Message: <3AF806B0.D3078DA1@gmx.de>
> there)
For (C?A:B) look in section 'Float Operators' in the docu.
Subject: Re: Test
Date: 8 May 2001 10:50:45
Message: <slrn9fg1ua.ik2.ron.parker@fwi.com>
>there)
A few interesting excerpts from the docs:
|The default value if none is specified is threshold 1.0.
|Conditional expressions: The operand C is boolean while operands A and B
|are any expressions. The result is of the same type as A and B.
|(C ? A : B)         if C then A else B
|You may use the dot operator to extract a single float component from a
|vector. Suppose the identifier Spot was previously defined as a vector.
|Then Spot.x is a float value that is the first component of this x, y, z
|vector. Similarly Spot.y and Spot.z reference the 2nd and 3rd components.
#local R=<7084844682857967,32787982,826975826580>#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Subject: Re: Test
Date: 8 May 2001 10:58:48
Message: <3af809a8@news.povray.org>
Thanks.
I now remember that I have seen it in the docs, but I couldn't remember where.
Nekar Xenos
Subject: Re: Test
Date: 8 May 2001 11:03:45
Message: <slrn9fg2mm.ik2.ron.parker@fwi.com>
On Tue, 8 May 2001 17:02:06 +0200, Nekar Xenos wrote:
>Thanks.
The first excerpt was from the blob docs, and was a hint as to a way you can
make your sig even shorter (not my idea, though, just something you missed
in Warp's adaptation.)
The second excerpt was from the "float operators" docs.
The third excerpt was from the "vector operators" docs.
Subject: Re: Test
Date: 8 May 2001 11:28:20
Message: <3af81094@news.povray.org>
: #local Q=seed(7);#local B=<-2,2,5>;#local E=<2,-2,5>;blob{threshold 1#while((E
: -B).x>.1)#local S=B;#local B=B+<rand(Q),rand(Q),rand(Q)>/20;#local B=(vlength(
: B-E)<vlength(S-E)?B:2*S-B);sphere{<B.y,-B.x,B.z>,.1,1}sphere{B,.1,1}#end
: pigment{rgb<8,16,24>}}// nekar Xenos
  If a bit wider version of the "X" doesn't bother you, you can make it
a three-liner:
#local Q=seed(7);#local B=<-2,2,5>;#local E=<2,-2,5>;union{#while((E-B).x>.1)
#local S=B;#local B=B+<rand(Q),rand(Q),rand(Q)>/20;#local B=(vlength(B-E)<
vlength(S-E)?B:2*S-B);sphere{<B.y,-B.x,B.z>,.1}sphere{B,.1}#end pigment{rgb 9}}
Subject: Re: test
Date: 26 Sep 2002 06:37:06
Message: <3d92e352@news.povray.org>
In article <3d92e2e8@news.povray.org> , "Timothy R. Cook"
<tim### [at] scifi-fantasycom> wrote:
> ok, that works...
> why the heck can't I cancel my message using Mozilla 1.1?!?!?!?
Don't worry, it will be taken care of.
e-mail: tho### [at] trfde
Subject: Re: test
Date: 26 Sep 2002 06:46:32
Message: <3d92e588$1@news.povray.org>
Which, my ability to cancel messages with Moz 1.1, or the actual
cancellation of this particular message?
Tim Cook
Version: 3.12
