POV-Ray : Newsgroups : povray.general : bug or trivial mistake ? Server Time
25 Mar 2026 03:46:01 EDT (-0400)
  bug or trivial mistake ? (Message 1 to 9 of 9)
Subject: bug or trivial mistake ?
Date: 26 Apr 2001 08:17:14
Message: <3ae811ca@news.povray.org>
What is wrong with below syntax ?
#declare P=.5;
#declare C=texture{pigment{color rgb 1}finish{ambient.5}}
#declare B=texture{pigment{color rgb 0}finish{ambient 0}}
#declare A=texture{average texture_map{[(1-P) C][P B]}}
texture{gradient y texture_map{[0 B][.5 A][1 C]}}
it causes error: ] expected but undeclared identifier 'A' found instead.
noticed in POV-Ray 3.1g and MegaPOV 0.7
ABX
#local A="000114120001121034130151142153134064180060195"#local B=0;#macro G()
#declare B=B+1;val(substr(A,B,1))#end#local S=seed(1);light_source{10,1}blob{
threshold.6#local U=z;#local Y=0;#while(Y<15)#local E=G()*.7+.1e-3;#local V=<
3.5-G(),G()-2.5,-1>;#local X=0;#while(X<1)sphere{<12*X+rand(S)-6,Y+rand(S)-5,
-1>1,1}sphere{U+X*(V-U)+rand(S)E,.3}#local X=X+.01;#end#local U=V;#local Y=Y+
1;#end texture{pigment{rgb 1}normal{agate}}}camera{location z*8look_at 0}
Subject: Re: bug or trivial mistake ?
Date: 26 Apr 2001 09:09:21
Message: <3ae81e01@news.povray.org>
Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote:
: #declare P=.5;
: #declare C=texture{pigment{color rgb 1}finish{ambient.5}}
: #declare B=texture{pigment{color rgb 0}finish{ambient 0}}
: #declare A=texture{average texture_map{[(1-P) C][P B]}}
: texture{gradient y texture_map{[0 B][.5 A][1 C]}}
: it causes error: ] expected but undeclared identifier 'A' found instead.
  The problem is that two contiguous textures define a layered texture.
So you are defining a layered texture names 'A' and you are using 'A'
inside it.
  Defining a texture alone is an error in itself anyways, so you can get rid
of both errors by defining the last line like:
#declare MyTexture = texture{gradient y texture_map{[0 B][.5 A][1 C]}}
#local D=array[6]{11117333955,7382340,3358,3900569407,970,4254934330}
#local I=0;#macro M()<mod(D[I],13)-6,mod(div(D[I],13),8)-3,10>#end
#while(I<6)cylinder{M()#local D[I]=div(D[I],104);M().1
pigment{rgb M()}}#local I=(D[I]>99?I:I+1);#end              /*- Warp -*/
Date: 26 Apr 2001 09:12:13
Message: <slrn9eg7le.7fd.ron.parker@fwi.com>
Ambiguity.  There's no way for POV to know that the last line isn't an
extra layer on the line before it, so as far as POV knows you're still
declaring A.
The workaround is to put something else in between.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 26 Apr 2001 09:13:06
Message: <slrn9eg7n4.7fd.ron.parker@fwi.com>
Not if it's the result of a macro, or if it's inside of an object definition.
Date: 26 Apr 2001 09:18:37
Message: <3ae8202c@news.povray.org>
This is one reason why semi-colons should be required in all #declares.
Date: 26 Apr 2001 09:47:05
Message: <3ae826d9@news.povray.org>
Ron Parker wrote in message ...
> Ambiguity.
Thanks, that was reason.
I moved declarations outside object but I agree that it could be possible write
";" after any declaration to finish it
ABX
Date: 28 Apr 2001 01:58:55
Message: <3AEA5CFF.28BE232B@erols.com>
> #declares.
And why the syntax for declaring a layered texture should be altered.
John
ICQ: 46085459
Date: 28 Apr 2001 12:44:28
Message: <3aeaf36c@news.povray.org>
John VanSickle <van### [at] erolscom> wrote:
: And why the syntax for declaring a layered texture should be altered.
  It doesn't have to be if semicolons are used. A semicolon would end
the declaration, period.
Date: 28 Apr 2001 23:05:54
Message: <3aeb8512$1@news.povray.org>
or rather. . .
"It doesn't have to be if semicolons are used. A semicolon would end
the declaration, semicolon."
:D
Batronyx ^"^
bat### [at] cadronhsacom
http://www.batronyx.com
Bhuddist monk to hotdog vendor:
     "Make me one with everything."
