POV-Ray : Newsgroups : povray.general : Playing around with ior and found some weird results... Server Time
17 Jul 2026 14:35:06 EDT (-0400)
  Playing around with ior and found some weird results... (Message 1 to 3 of 3)
Subject: Playing around with ior and found some weird results...
Date: 11 Feb 2001 15:48:05
Message: <3a86fa85@news.povray.org>
I tried negative numbers on ior and got some strange results... Anyone care
to explain?
Ambis
/*  Code... pov 3.1g  */
global_settings { max_trace_level 30 }
light_source {<2,2,2>,rgb 1}
light_source {<0,0,0>,rgb 2}
   location <2,2,2>
   look_at  <0,0,0>
#declare Epfinish =
                pigment {rgbt <0,0,0,1>}
                finish { ambient 0 diffuse 0 }
#declare Etexture =
texture {Epfinish}
#declare EMaterial =
material {
 texture { Etexture }
 interior {ior 1 }
/* interior {ior 0 }       /* Why did the sphere diapear here */
/* interior {ior -1 }      /* What happens here, it looks weird   */
/* interior {ior -10 }     /* What happens here, it looks weird   */
/* interior {ior -100 }    /* What happens here, it looks weird   */
sphere { <0,0,0>,1
   material { EMaterial }
   hollow }
plane {z,-4 pigment {checker  rgb 0, rgb 1}}
plane {x,-4 pigment {checker  rgb 0, rgb 1}}
plane {y,-4 pigment {checker  rgb 0, rgb 1}}
cylinder {<-4,-4,-4><4,-4,-4>,.5 pigment {checker  rgb 0, rgb 1 scale .5}}
cylinder {<-4,-4,-4><-4,4,-4>,.5 pigment {checker  rgb 0, rgb 1 scale .5}}
cylinder {<-4,-4,-4><-4,-4,4>,.5 pigment {checker  rgb 0, rgb 1 scale .5}}
Subject: Re: Playing around with ior and found some weird results...
Date: 12 Feb 2001 00:46:15
Message: <3A8778A0.568BE384@pacbell.net>
> to explain?
I guess an important question is what do you expect it to look like
when using negative values ?  I think I brought up this question a
few months ago in one of the other groups but don't recall much about
it at the moment other than the feature wasn't designed to use negative
numbers so you are lucky you get any results at all - good or bad.
Ken Tyler
Date: 12 Feb 2001 13:48:22
Message: <3a882ff6@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3A8778A0.568BE384@pacbell.net...
care
> > to explain?
It was just a test to see if it took negative numbers , I did not really
know what to expect.
Ambis
