POV-Ray : Newsgroups : povray.general : random numbers Server Time
24 Apr 2026 23:04:36 EDT (-0400)
  random numbers (Message 1 to 10 of 20)
Subject: random numbers
Date: 7 Feb 2001 10:47:27
Message: <3a816e0f$1@news.povray.org>
Does the seed for random numbers make any difference (apart from generating
a diff. sequence)? Are big numbers better than small numbers? Are fractional
numbers better than integers?
(by "better" I suppose I mean "a longer, more random, sequence")
Also, is the random number sequence a fixed sequence, with the seed just
controlling the point at which you join the sequence. If it is a fixed
sequence, how long is it?
Subject: Re: random numbers
Date: 7 Feb 2001 12:13:15
Message: <3A8182D3.B378D2C3@pacbell.net>
> a diff. sequence)?
No.
See above.
> Are fractional numbers better than integers?
See above.
Yes.
> If it is a fixed sequence, how long is it?
I don't know.
Ken Tyler
Date: 7 Feb 2001 12:24:32
Message: <3a8184d0@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
: Does the seed for random numbers make any difference (apart from generating
: a diff. sequence)? Are big numbers better than small numbers? Are fractional
: numbers better than integers?
  I have never heard that it would make any difference.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 7 Feb 2001 15:02:40
Message: <3a81a9e0@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3A8182D3.B378D2C3@pacbell.net...
> Yes.
This resolves all the other questions.
> I don't know.
Except this one.
Date: 7 Feb 2001 15:16:11
Message: <3A81AD0B.42C66E2D@gmx.de>
> > I don't know.
> Except this one.
I don't know about this particular random number generator, but a good one
should have a period of at least several millions.
According to the comments in the HF-Lab/gforge source code, the best
existing random number generator has a period of 10^600 while the one used
there has 2^144.
Date: 7 Feb 2001 16:47:39
Message: <slrn983gk5.5lm.ron.parker@fwi.com>
The generator function is
next_rand[stream] = next_rand[stream] * 1812433253L + 12345L;
which doesn't look particularly well-chosen to me.  But if it's done right,
I'd guess that the period is pretty large (i.e. at least 1812433253).
Perhaps someone who's read volume 3 of Knuth more recently than I can
confirm or deny.  Or perhaps I can dig out my copy of volume 3 and try to
find a better PRNG for 3.5, since we've all seen some of the bad results
you can get from the current one.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 7 Feb 2001 18:03:01
Message: <slrn983kp1.pho.hjp-usenet@teal.h.hjp.at>
2^32.
	hp
   _  | Peter J. Holzer    | All Linux applications run on Solaris,
|_|_) | Sysadmin WSR       | which is our implementation of Linux.
| |   | hjp### [at] wsracat      |
__/   | http://www.hjp.at/ |	-- Scott McNealy, Dec. 2000
Date: 7 Feb 2001 18:43:59
Message: <3a81ddbf@news.povray.org>
If you look around you will find lots of generators better than the one used
in POV. By the way (and this is an official request to POVTeam) even without
switching to the best currently known even the Park-Miller minimal standard
is better ...and YES, they are not significantly slower.
Some URLs:
*) A place to start: http://csrc.nist.gov/rng/
*) Park Miller Minimal Standard
http://htm4.ee.queensu.ca:8000/ling/minrng.html
*) Mersenne Twister, currently the best known
http://www.math.keio.ac.jp/~matumoto/emt.html,  period is 2**19937-1 it's
not a typo... about 10**6000!!!
Alessandro Coppo
a.c### [at] iolit
Date: 8 Feb 2001 00:12:58
Message: <3A822B32.E4BBE34E@rsp.com.au>
..bad results ??
i use the function a whole lot - what do i need to look out for?
Date: 8 Feb 2001 03:04:47
Message: <3a82531f@news.povray.org>
If you use it to randomly locate objects on a square, they look somewhat
"gridded". I noticed this creating scenes with lots (1000's) of "simple
trees" viewed from above. Anyway, this generator is known from a long time
not to pass several simple tests (well, apart from the infamous RANDU, it is
actually one of the worst).
Alessandro Coppo
a.c### [at] iolit
