POV-Ray : Newsgroups : povray.general : ?how to make spirals? Server Time
25 Apr 2026 01:00:06 EDT (-0400)
  ?how to make spirals? (Message 1 to 6 of 6)
Subject: ?how to make spirals?
Date: 23 Jan 2001 09:25:52
Message: <3a6d9470$1@news.povray.org>
Any have a formula for constructing spirals......I am, unfortunately
mathematically challenged!!
thanks in advance...
Subject: Re: ?how to make spirals?
Date: 23 Jan 2001 09:41:12
Message: <3a6d9808@news.povray.org>
RWard <rmw### [at] swbellnet> wrote:
: Any have a formula for constructing spirals......I am, unfortunately
: mathematically challenged!!
  It depends on where and how do you plan to use it.
  Are you going to, for example, arrange a set of objects in a spiral shape?
Do you want a smooth surface with a certain radius and a spiral shape (like
a torus with increasing main radius)?
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 23 Jan 2001 10:39:16
Message: <3a6da5a4$1@news.povray.org>
I am not quite sure, I think what I want right now, is a shape with a spiral
texture.  I would like to try constructing various objects on a spiral
theme.
thanks
news:3a6d9808@news.povray.org...
shape?
(like
Date: 23 Jan 2001 11:18:24
Message: <3A6DAED0.1F1AF4CA@datacomm.ch>
See
 http://www.povworld.de/cgi-bin/objects/Geometrical_Objects/
for a macro that generates spirals.
Or go to
 http://members.nbci.com/quadhall/isoi.html
see a formula for an isofunctional implementation of spirals. You will need
megapov to render isorufaces though.
- Micha
Date: 23 Jan 2001 12:00:42
Message: <3a6db8b9@news.povray.org>
: I am not quite sure, I think what I want right now, is a shape with a spiral
: texture.
  There are two spiral patterns already in povray (spiral1 and spiral2).
Look in the documentation for details.
Subject: Re: Simple:
Date: 23 Jan 2001 14:54:54
Message: <3A6DE144.4B4514A2@netvision.net.il>
This should look like a spring.
for a spiral, change RadiusAdder to something positive;
and change ProgressPace to 0.
#declare Radius= 3
#declare CurrentAngle= 0
#declare SpinCount= 4
#declare ProgressPace= 15
#declare RadiusAdder= 0.001
#while (CurrentAngle < SpinCount*360)
  sphere {
    0,0.5
    translate Radius*y
    rotate CurrentAngle*z
    translate ProgressPace*(CurrentAngle / 360)*z
    pigment {color rgb CurrentAngle/(360*SpinCount)}
  #declare CurrentAngle = CurrentAngle + 1
  #declare Radius = Radius + RadiusAdder
This should work out pretty well.
play with the values for a desired result.
hope I helped you out! :-)
