POV-Ray : Newsgroups : povray.general : What exactly is.... Server Time
17 Jul 2026 15:53:27 EDT (-0400)
  What exactly is.... (Message 1 to 3 of 3)
Subject: What exactly is....
Date: 16 Jan 2001 06:51:57
Message: <3a6435dd@news.povray.org>
What exactly is an isosurface?????
Subject: Re: What exactly is....
Date: 16 Jan 2001 06:59:29
Message: <3A6437A2.950441F9@gmx.de>
In mathematical terms it's the equipotential surface of a 3d function f(x,
y, z)
Not sure if that helps you much. :-)
followup to p.u.p.
Date: 16 Jan 2001 11:06:26
Message: <3a647182@news.povray.org>
Saadat Saeed <saa### [at] hotmailcom> wrote:
: What exactly is an isosurface?????
  As Christoph already answered, is the equipotential surface of a function
f(x,y,z).
  What does this mean?
  This means that the isosurface is an object with the following properties:
  1. A point <x,y,z> is outside the object if the value of f at that point
     is larger than a certain (constant) value 'n'.
  2. A point <x,y,z> is inside the object if the value of f at that point
     is smaller than 'n'.
  3. A point <x,y,z> is exactly at the surface of the object if the value
     of f at that point is exactly 'n'.
  In other words, the isosurface is a surface in space where the function f
has the same value at each point.
  It's the same principle as in isobar lines (the air pressure is the same
along the line) or height lines in a height map (the height of the ground
is the same along the line), but with a surface instead of a line.
  f(x,y,z) can be any mathematical function.
  Example: To get a spherical surface, define:
  f(x,y,z) = sqrt(x*x+y*y+z*z)
with 'n' being the radius of the sphere.
  (sqrt(x*x+y*y+z*z) is actually the distance of the point <x,y,z> to the
origin.)
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
