POV-Ray : Newsgroups : povray.general : Sorting algorithms comparison with POV-Ray Server Time
31 Dec 2025 17:00:16 EST (-0500)
  Sorting algorithms comparison with POV-Ray (Message 1 to 3 of 3)
Subject: Sorting algorithms comparison with POV-Ray
Date: 4 Jan 2001 08:07:04
Message: <3a547577@news.povray.org>
There was a thread about sorting some days ago in this groups, so I decided
to explore a bit array sorting in POV-Ray. This is the result of the
research.
  The idea was to test different sorting algorithms made with POV-script
(as #macros) and see how fast they are with different amount of items.
  I made a pov-scene which makes some tests and outputs information about
them in the #debug channel.
  Some comments about the sorting algorithms:
  - Quick sort: Or actually randomized quick sort. The basic fast sorting
algorithm. It performs very well with all the input types (due the the
"randomized" part). Fast, simple and reliable. Not the best for sorting
very short arrays, though. A positive thing is that it only requires one
#macro.
  - Hybrid sort: A hybrid between quick sort and insertion sort. It applies
quick sort down to sub-blocks of 10 items at max, and then it sorts this
semi-sorted array by calling the insertion sort.
  This "trick" takes advantage of the fact that insertion sort is faster
with very small arrays than quick sort, so it first makes small sub-blocks
(which are ordered with respect to each other) and then just calls the
insertion sort. Due to the insertion sort algorithm, it automatically
sorts each sub-block separately (and since the sub-blocks are very small,
10 items at max, it does it very fast).
  As seen in the results, this algorithm is clearly the fastest one of all.
  It requires three #macros, though.
  - Merge sort: Regular recursive merge sort. It's surprisingly fast taking
into account that it uses an additional array and makes lots of "extra" copies
from one array to the other. It's, however, quite slower than quick sort.
  Requires two #macros.
  - NR-Merge sort: A non-recursive version of the merge sort algorithm. It
performs better than the recursive version, almost as fast as quick sort.
  Another advantage over the recursive version is that it requires only
one #macro.
  - Insertion sort: Added to the test more for comparison reasons than anything
else. Although it's one of the fastest O(n^2)-algorithms, it's still O(n^2),
which means that it's extremely slow with large arrays.
  Because of the simplicity of the algorithm, it's the fastest with very
small arrays (some tens of items) and a bit bigger arrays which are almost
sorted. This fact is used in the hybrid sort described above.
  However, as the size of the array grows, the execution time grows rapidly
until it's just too slow (as seen in the test, it's about 44 times slower
than quick sort with an array of 2000 random numbers).
  - Bubble sort: I originally tested this horrible algorithm, but it was
so slow that I had to drop it out (sorting an array of 2000 items took
about 15 minutes).
  If someone wants to test it, the test code is commented in the MakeTest()
macro.
  The test was done in an Sun Ultra 5 (UltraSparc 333MHz, 128MB RAM). If
someone wants to make the test with other systems, please be welcome. I'm
interested (and I'm sure many other people are as well).
  The table contains three values for each algorith:
  - The first value is a rough estimate of the amount of seconds it took for
the algorithm to sort the array. Since it's resolution is 1 second, it's not
very accurate with small arrays.
  - The second value is the number of ticks that it took. This is a bit more
accurate, but still not very accurate with small arrays (it seems that in
this system the tick resolution is 10000 ticks, with about 500000 being one
second, so the resolution is about 1/50 seconds). These resolutions probably
depend a lot in the system used.
  - The third value is a speed factor with respect to quick sort (hence quick
sort itself has this value always set to 1.00). A value of eg. "2.00" means
that the algorithm took twice the time it took for quick sort. Again, with
small arrays the value is less accurate.
  The results (as output by the test scene to the #debug channel):
* An array containing random numbers:
Sorting 16 items:
                   ~Secs      Ticks  Speed factor
      Quick sort:      0      30000  1.00
     Hybrid sort:      0      20000  0.67
      Merge sort:      0      40000  1.33
   NR-Merge sort:      0      40000  1.33
  Insertion sort:      0      30000  1.00
Sorting 80 items:
      Quick sort:      0     200000  1.00
     Hybrid sort:      0     140000  0.70
      Merge sort:      0     280000  1.40
   NR-Merge sort:      0     210000  1.05
  Insertion sort:      0     470000  2.35
Sorting 400 items:
      Quick sort:      1    1100000  1.00
     Hybrid sort:      1     840000  0.76
      Merge sort:      2    1710000  1.55
   NR-Merge sort:      1    1260000  1.15
  Insertion sort:     12   11680000  10.62
Sorting 2000 items:
      Quick sort:      6    6220000  1.00
     Hybrid sort:      5    4880000  0.78
      Merge sort:     10   10210000  1.64
   NR-Merge sort:      7    7270000  1.17
  Insertion sort:    277  277450000  44.61
* An array containing almost ordered numbers:
(186 values out of 2000 random, rest consecutive)
Sorting 16 items:
   NR-Merge sort:      0      30000  1.00
  Insertion sort:      0      10000  0.33
Sorting 80 items:
      Quick sort:      0     180000  1.00
     Hybrid sort:      0     130000  0.72
      Merge sort:      0     280000  1.56
   NR-Merge sort:      0     200000  1.11
  Insertion sort:      0     120000  0.67
Sorting 400 items:
      Quick sort:      1    1060000  1.00
     Hybrid sort:      1     770000  0.73
      Merge sort:      2    1690000  1.59
   NR-Merge sort:      1    1210000  1.14
  Insertion sort:      2    1670000  1.58
Sorting 2000 items:
      Quick sort:      6    5980000  1.00
     Hybrid sort:      4    4470000  0.75
      Merge sort:      9    9440000  1.58
   NR-Merge sort:      7    6510000  1.09
  Insertion sort:     33   33360000  5.58
* An array containing almost reverse-ordered numbers:
(202 values out of 2000 random, rest reversely consecutive)
Sorting 16 items:
Sorting 80 items:
      Quick sort:      0     190000  1.00
     Hybrid sort:      0     120000  0.63
      Merge sort:      0     260000  1.37
   NR-Merge sort:      0     190000  1.00
  Insertion sort:      1     820000  4.32
Sorting 400 items:
     Hybrid sort:      1     760000  0.72
      Merge sort:      2    1570000  1.48
   NR-Merge sort:      1    1090000  1.03
  Insertion sort:     20   19780000  18.66
Sorting 2000 items:
      Quick sort:      6    5900000  1.00
     Hybrid sort:      4    4230000  0.72
      Merge sort:      9    9450000  1.60
   NR-Merge sort:      7    6520000  1.11
  Insertion sort:    512  512190000  86.81
  The sorting macros and the test scene:
---------8<---------8<---------8<---------8<---------8<---------8<----------
// Bubble sort
#macro BubbleSort(Array, FirstInd, LastInd)
  #local Sorted = false;
  #while(!Sorted)
    #local Sorted = true;
    #local Ind = FirstInd;
    #while(Ind < LastInd)
      #local NextInd = Ind+1;
      #if(Array[Ind] > Array[NextInd])
        #local Tmp = Array[Ind];
        #declare Array[Ind] = Array[NextInd];
        #declare Array[NextInd] = Tmp;
      #declare Ind = NextInd;
// Insertion sort
#macro InsertionSort(Array, FirstInd, LastInd)
  #local Ind1 = FirstInd+1;
  #while(Ind1 <= LastInd)
    #local Ind2 = Ind1;
    #while(Ind2>0)
      #local NextInd2 = Ind2-1;
      #if(Array[Ind2] < Array[NextInd2])
        #local Tmp = Array[Ind2];
        #declare Array[Ind2] = Array[NextInd2];
        #declare Array[NextInd2] = Tmp;
        #local Ind2 = NextInd2;
      #else
        #local Ind2 = 0;
    #local Ind1 = Ind1+1;
// Merge sort
#macro MergeSort(Array, FirstInd, LastInd)
  #local HelpArray = array[LastInd+1]
  MergeSortStep(Array, HelpArray, FirstInd, LastInd)
#macro MergeSortStep(Array, HelpArray, FirstInd, LastInd)
  #if(FirstInd < LastInd)
    #local Mid = int((FirstInd+LastInd)/2);
    MergeSortStep(Array, HelpArray, FirstInd, Mid)
    MergeSortStep(Array, HelpArray, Mid+1, LastInd)
    #while(Ind <= LastInd)
      #declare HelpArray[Ind] = Array[Ind];
      #local Ind = Ind+1;
    #local I = FirstInd; #local J = FirstInd; #local K = Mid+1;
    #while(J <= Mid & K <= LastInd)
      #if(HelpArray[J] <= HelpArray[K])
        #declare Array[I] = HelpArray[J];
        #local J = J+1;
      #else
        #declare Array[I] = HelpArray[K];
        #local K = K+1;
      #local I = I+1;
    #local K = (J>Mid ? 0 : Mid-LastInd);
    #local J = I;
    #while(J <= LastInd)
      #declare Array[J] = HelpArray[J+K];
      #local J = J+1;
// NR-Merge sort
#macro NRMergeSort(Array, FirstInd, LastInd)
  #local OrigToHlp = true;
  #local Step = 2;
  #local Size = (LastInd-FirstInd+1)*2;
  #while(Step < Size)
    #local FInd = FirstInd;
    #local LInd = FInd+Step-1;
    #local Mid = int((FInd+LInd)/2);
    #while(Mid < LastInd)
      #if(LInd > LastInd) #local LInd = LastInd; #end
      #local I = FInd; #local J = FInd; #local K = Mid+1;
      #if(OrigToHlp)
        #while(J <= Mid & K <= LInd)
          #if(Array[J] <= Array[K])
            #declare HelpArray[I] = Array[J];
            #local J = J+1;
          #else
            #declare HelpArray[I] = Array[K];
            #local K = K+1;
          #local I = I+1;
      #else
            #local J = J+1;
          #else
            #local K = K+1;
          #local I = I+1;
      #local K = (J>Mid ? 0 : Mid-LInd);
      #local J = I;
      #if(OrigToHlp)
        #while(J <= LInd)
          #declare HelpArray[J] = Array[J+K];
          #local J = J+1;
      #else
        #while(J <= LInd)
          #local J = J+1;
      #local FInd = FInd+Step;
    #if(Mid >= LastInd)
      #if(OrigToHlp)
        #while(FInd <= LastInd)
          #declare HelpArray[FInd] = Array[FInd];
          #local FInd = FInd+1;
      #else
          #declare Array[FInd] = HelpArray[FInd];
    #local Step = Step*2;
    #local OrigToHlp = (OrigToHlp ? false : true);
  #if(!OrigToHlp)
    #while(FirstInd <= LastInd)
      #declare Array[FirstInd] = HelpArray[FirstInd];
      #local FirstInd = FirstInd+1;
// Quick sort
#declare QuickSortSeed = seed(0);
#macro QuickSort(Array, FirstInd, LastInd)
  #while(FirstInd < LastInd)
    #local RInd = FirstInd+rand(QuickSortSeed)*(LastInd-FirstInd);
    #local Tmp = Array[FirstInd];
    #declare Array[FirstInd] = Array[RInd];
    #declare Array[RInd] = Tmp;
    #local X = Array[FirstInd];
    #local I = FirstInd-1; #local J = LastInd+1; #local Mid = -1;
    #while(Mid < 0)
      #local J = J-1; #while(Array[J] > X) #local J = J-1; #end
      #local I = I+1; #while(Array[I] < X) #local I = I+1; #end
      #if(I<J)
        #local Tmp = Array[I];
        #declare Array[I] = Array[J];
        #declare Array[J] = Tmp;
      #else
        #local Mid = J;
    QuickSort(Array, FirstInd, Mid)
    #local FirstInd = Mid+1;
// Hybrid quick sort
#macro HybridQuickSort(Array, FirstInd, LastInd)
  HybridQuickSortStep(Array, FirstInd, LastInd)
#macro HybridQuickSortStep(Array, FirstInd, LastInd)
  #while(FInd < LastInd-10)
    #local RInd = FInd+rand(QuickSortSeed)*(LastInd-FInd);
    #local Tmp = Array[FInd];
    #declare Array[FInd] = Array[RInd];
    #local X = Array[FInd];
    #local I = FInd-1; #local J = LastInd+1; #local Mid = -1;
    #while(Mid < 0)
      #if(I<J)
      #else
        #local Mid = J;
    HybridQuickSortStep(Array, FInd, Mid)
    #local FInd = Mid+1;
// Test sort algorithm speeds
#version Unofficial MegaPov 0.6;
#declare ArraySize = 2000;
#declare TestArray = array[ArraySize]
#declare ArrayCopy = array[ArraySize]
#macro CopyArray(Dest, Src, FirstInd, LastInd)
    #declare Dest[FirstInd] = Src[FirstInd];
#macro CheckArray(Array, FirstInd, LastInd, Name)
    #if(Array[Ind] > Array[Ind+1])
      #debug concat("Ooops! ", Name, " doesn't work...\n")
      #error ""
    #local Ind=Ind+1;
#macro MakeTest()
  #local Amnt = 16;
  #while(Amnt <= ArraySize)
    #debug concat("\nSorting ", str(Amnt,0,0), " items:\n")
    #debug "                   ~Secs      Ticks  Speed factor\n"
    CopyArray(ArrayCopy, TestArray, 0, Amnt-1)
    #local STime = start_chrono;
    #local QSTicks = tick_count;
    QuickSort(ArrayCopy, 0, Amnt-1)
    #local QSTicks = tick_count-QSTicks;
    #local ETime = current_chrono;
    CheckArray(ArrayCopy, 0, Amnt-1, "Quick sort")
    #debug concat("      Quick sort: ", str(ETime, 6, 0), " ", str(QSTicks,10,0), "
1.00\n")
    #local Ticks = tick_count;
    HybridQuickSort(ArrayCopy, 0, Amnt-1)
    #local Ticks = tick_count-Ticks;
    CheckArray(ArrayCopy, 0, Amnt-1, "Hybrid quick sort")
    #debug concat("     Hybrid sort: ", str(ETime, 6, 0), " ", str(Ticks,10,0), "  ",
str(Ticks/QSTicks,0,2), "\n")
    MergeSort(ArrayCopy, 0, Amnt-1)
    CheckArray(ArrayCopy, 0, Amnt-1, "Merge sort")
    #debug concat("      Merge sort: ", str(ETime, 6, 0), " ", str(Ticks,10,0), "  ",
    NRMergeSort(ArrayCopy, 0, Amnt-1)
    CheckArray(ArrayCopy, 0, Amnt-1, "NR-Merge sort")
    #debug concat("   NR-Merge sort: ", str(ETime, 6, 0), " ", str(Ticks,10,0), "  ",
    InsertionSort(ArrayCopy, 0, Amnt-1)
    CheckArray(ArrayCopy, 0, Amnt-1, "Insertion sort")
    #debug concat("  Insertion sort: ", str(ETime, 6, 0), " ", str(Ticks,10,0), "  ",
    BubbleSort(ArrayCopy, 0, Amnt-1)
    CheckArray(ArrayCopy, 0, Amnt-1, "Bubble sort")
    #debug concat("     Bubble sort: ", str(ETime, 6, 0), " ", str(Ticks,10,0), "  ",
    #local Amnt = Amnt*5;
#debug "* An array containing random numbers:\n"
#debug "  ----------------------------------\n"
#declare R=seed(0);
#declare Ind=0;
#while(Ind<ArraySize)
  #declare TestArray[Ind] = rand(R)*1000;
  #declare Ind=Ind+1;
MakeTest()
#debug "\n* An array containing almost ordered numbers:\n"
#debug   "  ------------------------------------------\n"
#declare Cnt=0;
#declare Ind=0;
  #if(rand(R) < .1)
    #declare Cnt = Cnt+1;
  #else
    #declare TestArray[Ind] = Ind;
  #declare Ind=Ind+1;
#debug concat("(",str(Cnt,0,0)," values out of ",str(ArraySize,0,0)," random, rest
consecutive)\n")
MakeTest()
#debug "\n* An array containing almost reverse-ordered numbers:\n"
#debug   "  --------------------------------------------------\n"
#declare Cnt=0;
#declare Ind=0;
  #if(rand(R) < .1)
  #else
    #declare TestArray[Ind] = ArraySize-Ind;
  #declare Ind=Ind+1;
reversely consecutive)\n")
MakeTest()
Subject: Re: Sorting algorithms comparison with POV-Ray
Date: 5 Jan 2001 04:32:34
Message: <mz7l4atkdd.fsf@tango.peace.co.nz>
Warp <war### [at] tagpovrayorg> writes:
I've added heap sort to the mix.
  - Heap sort: The other basic fast sorting algorithm.  IIRC it should
theoretically be better than quick sort on the almost-reverse ordered
array.  Against the randomized quick sort, however, it doesn't seem to
have that behaviour.  Requiring only one #macro it's almost as concise
as quick sort and faster on short arrays.
Note that the array goes from 1 to size rather than 0 to size-1 and
stomps on the location just *before* the start of the array; that
simplifies the math required.  The same algorithm ajusting for 0 to
size-1 ran more than 20% slower in all cases.
The tests were done on (one cpu of) an Origin 2000 (32 * MIPS R10000
195 MHz, 7808MB RAM).
Sorting 16 items:
      Quick sort:      0      50000  1.00
     Hybrid sort:      0      30000  0.60
      Merge sort:      0      50000  1.00
   NR-Merge sort:      0      40000  0.80
       Heap sort:      0      20000  0.40
  Insertion sort:      0      30000  0.60
Sorting 80 items:
      Quick sort:      0     250000  1.00
     Hybrid sort:      0     160000  0.64
      Merge sort:      0     340000  1.36
   NR-Merge sort:      0     260000  1.04
       Heap sort:      0     190000  0.76
  Insertion sort:      1     550000  2.20
Sorting 400 items:
      Quick sort:      1    1350000  1.00
     Hybrid sort:      1    1010000  0.75
      Merge sort:      2    2110000  1.56
   NR-Merge sort:      2    1530000  1.13
       Heap sort:      1    1270000  0.94
  Insertion sort:     14   14160000  10.49
Sorting 2000 items:
      Quick sort:      8    7560000  1.00
     Hybrid sort:      6    5920000  0.78
      Merge sort:     12   12450000  1.65
   NR-Merge sort:      9    9180000  1.21
       Heap sort:      8    7760000  1.03
  Insertion sort:    336  335770000  44.41
(186 values out of 2001 random, rest consecutive)
Sorting 16 items:
      Quick sort:      0      40000  1.00
     Hybrid sort:      0      20000  0.50
      Merge sort:      0      50000  1.25
   NR-Merge sort:      0      40000  1.00
       Heap sort:      0      30000  0.75
  Insertion sort:      0      30000  0.75
Sorting 80 items:
      Quick sort:      0     230000  1.00
     Hybrid sort:      0     160000  0.70
      Merge sort:      0     340000  1.48
   NR-Merge sort:      0     240000  1.04
       Heap sort:      0     210000  0.91
  Insertion sort:      0     140000  0.61
Sorting 400 items:
      Quick sort:      1    1300000  1.00
     Hybrid sort:      1     990000  0.76
      Merge sort:      2    2070000  1.59
   NR-Merge sort:      1    1480000  1.14
       Heap sort:      1    1360000  1.05
  Insertion sort:      2    2000000  1.54
Sorting 2000 items:
      Quick sort:      7    7030000  1.00
     Hybrid sort:      5    5360000  0.76
      Merge sort:     11   11490000  1.63
   NR-Merge sort:      8    8170000  1.16
       Heap sort:     10   10100000  1.44
  Insertion sort:     41   40520000  5.76
(202 values out of 2001 random, rest reversely consecutive)
Sorting 16 items:
  Insertion sort:      0      40000  1.00
Sorting 80 items:
      Quick sort:      0     240000  1.00
     Hybrid sort:      0     160000  0.67
      Merge sort:      0     320000  1.33
   NR-Merge sort:      0     240000  1.00
       Heap sort:      0     180000  0.75
  Insertion sort:      1     960000  4.00
Sorting 400 items:
      Quick sort:      1    1320000  1.00
     Hybrid sort:      1     930000  0.70
      Merge sort:      2    1910000  1.45
   NR-Merge sort:      1    1380000  1.05
       Heap sort:      1    1200000  0.91
  Insertion sort:     24   23870000  18.08
Sorting 2000 items:
      Quick sort:      7    7350000  1.00
     Hybrid sort:      6    5620000  0.76
      Merge sort:     12   11530000  1.57
   NR-Merge sort:      8    7920000  1.08
       Heap sort:      8    7550000  1.03
  Insertion sort:    600  599840000  81.61
The new/modified code:
// Heap Sort
#macro HeapSort(Array, FirstInd, LastInd)
  #declare Array[FirstInd-1] = 9999999999999999999;
  #while (I <= LastInd)
    #local X = Array[I];
    #local J = I;
    #while (Array[div(J,2)] <= X)
      #declare Array[J] = Array[div(J,2)];
      #local J = div(J,2);
    #declare Array[J] = X;
    #local I = I + 1;
  #local End = LastInd;
  #while (FirstInd < End)
    #local X = Array[End];
    #declare Array[End] = Array[FirstInd];
    #local I = FirstInd; #local J = I*2;
    #while (J < End)
      #if (J+1 < End & Array[J] < Array[J+1])
        #local J = J + 1;
      #if (X <= Array[J])
        #local I = J; #local J = I*2;
      #else
        #local J = End;
    #declare Array[I] = X;
    #local End = End - 1;
// Have to tweak the size for the heap
#declare ArraySize = 2001;
// original code...
// alternate array copy to setup the heap
#macro CopyHeap(Dest, Src, FirstInd, LastInd)
    #declare Dest[FirstInd+1] = Src[FirstInd];
// original code...
#macro MakeTest()
// original code...
    CopyHeap(ArrayCopy, TestArray, 0, Amnt-1)
    HeapSort(ArrayCopy, 1, Amnt)
    CheckArray(ArrayCopy, 1, Amnt, "Heap sort")
    #debug concat("       Heap sort: ", str(ETime, 6, 0), " ", str(Ticks,10,0), "  ",
// original code...
// etc, etc...
roh### [at] peacecom
Date: 5 Jan 2001 08:53:13
Message: <3a55d1c9@news.povray.org>
Rohan Hart <roh### [at] peacecom> wrote:
: I've added heap sort to the mix.
  Cool.
  I tried heap-sort as well, but for some reason it was extremely slow.
It was even slower then insertion sort in all cases.
  I decided that it should not be that slow and that I probably made some
bug in it, but didn't find it. Thus, I didn't include it in my test.
  It seems that I was right. I had some bug in there. Heap sort seems as
fast as it should.
  Thanks for the heap sort code.
