POV-Ray : Newsgroups : povray.general : Feature: iso-bels Server Time
28 Nov 2025 21:46:53 EST (-0500)
  Feature: iso-bels (Message 1 to 10 of 11)
Subject: Feature: iso-bels
Date: 22 Nov 2000 09:11:11
Message: <3a1bd3ff@news.povray.org>
When someone who is hiding around a corner shouts at me, I don't look AT
them, I look at the area of maximal density of soundwaves that have (?)
for this or to accomplish it with current syntaxes?
the density function might look like this....
10 10 9 8 7 6 5 4 3 2|
11 10 9 8 7 6 5 4 3 2|
--------------+ 4 3 2|
This could be useful for explosions that go down a hallway or a few
other eclectic applications that only I might use ;)
Subject: Re: Feature: iso-bels
Date: 22 Nov 2000 11:37:37
Message: <8FF4BFF2Fseed7@povray.org>
Makes me think of df3 or the i_dat3d stuff in megapov. Have a look at the
idat3darray.pov sample file for megapov, maybe it leads you to something.
Ingo
Date: 22 Nov 2000 13:38:16
Message: <chrishuff-EC25EE.13384122112000@news.povray.org>
In article <3a1bd3ff@news.povray.org>, "Greg M. Johnson"
I think this would be a good application of a particle system, having
the particles bounce through the hallway to simulate the path of the
explosion. With MegaPOV, it would be easy to code one using the trace()
function, and use that to place components of a blob pattern to get the
final result.
With MegaPOVPlus, you could try the particle_system object to do the
simulation, which should be much faster, but isn't complete yet and is
less flexible than doing things directly in the scene file. Also, MP+ is
based on an older MegaPOV and I don't have the updated version done yet,
and it won't be ready for a while.
Christopher James Huff
Date: 24 Nov 2000 00:03:18
Message: <mhtr1tcav803aeg1aufat5cmlp2hrrvo4t@4ax.com>
On Wed, 22 Nov 2000 13:38:41 -0500, Chris Huff <chr### [at] maccom>
>explosion.
Does your particle system account for mass? If so, does it compute the
De Broigle wavelength of a particle? Does it then use its duality to
compute wave effects?
Sorry, couldn't resist... but really, it's wave behaviour Greg needs
to model.
Peter Popov ICQ : 15002700
Date: 24 Nov 2000 04:23:01
Message: <3a1e3375$1@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote in message
news:mhtr1tcav803aeg1aufat5cmlp2hrrvo4t@4ax.com...
Mummy, the petey-poppy man is making my ears bleed....
Date: 24 Nov 2000 07:21:14
Message: <chrishuff-6182BF.07214124112000@news.povray.org>
In article <mhtr1tcav803aeg1aufat5cmlp2hrrvo4t@4ax.com>, Peter Popov
Yes.
> If so, does it compute the De Broigle wavelength of a particle? Does
> it then use its duality to compute wave effects?
Um, no...but you can probably do something like that yourself, using the
age of the particle. I don't know what the "De Broigle wavelength" is,
so I can't tell for sure...
> to model.
I don't think that is necessary. He said he wanted to use it for things
like explosions going through hallways, a particle system should be fine
for that. If he wanted to simulate acoustics, it would be
different...but that type of explosion is more like a fluid(gas or
liquid) flowing through a pipe than wave behavior.
It might be possible to do something that goes the other way, sort of a
cross between radiosity and the proximity pattern. You would specify a
target object and a recursion level, and it would send out samples to
determine the visibility of the object from any point, even the effect
around corners. However, this would be incredibly slow...though a sort
of cache could be used for reusing data, like radiosity has, I don't
know how to implement that. And the particle system approach could
probably come closer to simulating wave behavior.
Hmm, maybe some sort of 3D grid, similar to a voxel image, could be set
up around the immediate area containing all the "free" space, this could
then be used in waveform simulations...it could be faster, because no
recursive tracing would need to be done, but would eat memory like crazy
in large spaces with high resolution. An octree-like structure could be
optimized for large areas, but areas that are mostly "free" would
probably use memory best when a simple array is used.
Date: 24 Nov 2000 11:35:43
Message: <MPG.1488a233174790f89896b2@news.povray.org>
in povray.general, Chris Huff says...
De Broglie [correct spelling] (a French prince, Nobel prize physics 1929)
proved that electrons have an inherent wavelength, depending on their
energy. This is what PP was referring to. It was the first step that was
leading to the development of quantum mechanics. A clever prince he was!
Regards,  Sander
Date: 24 Nov 2000 20:45:49
Message: <chrishuff-1D2D47.20461724112000@news.povray.org>
In article <MPG.1488a233174790f89896b2@news.povray.org>, Sander
> energy.
Well, I don't think we need to be simulating stimulated emission of
radiation by electrons changing energy levels, just to do an
explosion... :-)
I'm not sure what this has to do with acoustic simulations either...
Date: 26 Nov 2000 12:22:02
Message: <3a2146ba$1@news.povray.org>
> explosion.
positions after time t, *but then* use blob pattern.
Date: 26 Nov 2000 12:53:16
Message: <chrishuff-AFA8C6.12534626112000@news.povray.org>
In article <3a2146ba$1@news.povray.org>, "Greg M. Johnson"
> Your suggestion is half ingenious.? Set up bouncing particles, record the
I thought that was exactly what I was suggesting...I must have
misunderstood, could you clarify what you meant?
Which was the "ingenious" part? The blob pattern, the trace() function,
or using the particle_system to do the work for you instead of writing
your own particle system?
"...code one using the trace() function"
Many people have talked about using trace() for collision detection for
particles, and it has been done several times...that certainly isn't a
new idea.
"...place components of a blob pattern to get the final result."
I have suggested the blob pattern for this type of thing from it's
creation. In fact, it is designed as a media density pattern with fire
and smoke in mind...
"...you could try the particle_system object to do the simulation..."
This last one can't be it, since the ability to use the particle_system
only to do the simulation is one of it's main features. Again, nothing
new...
