POV-Ray : Newsgroups : povray.general : POV Benchmark Windows ME - big difference between command line and GUI Server Time
25 Apr 2026 06:28:40 EDT (-0400)
  POV Benchmark Windows ME - big difference between command line and GUI (Message 1 to 10 of 15)
Subject: POV Benchmark Windows ME - big difference between command line and GUI
Date: 20 Nov 2000 18:34:59
Message: <3a19b523@news.povray.org>
Just got a new computer with Windows ME and was trying the POV benchmark
(skyvase.pov).  I ran it two ways using the Standard download of v3.1g with
the following results:
1) Windows ME command line   34 sec
2) POV  GUI                             43 sec
Quite a large difference!
The command line used in 1) was run from a DOS window in the bin directory.
The command line was:
pvengine -i skyvase.pov +v1 +ft -x +mb25 +a0.300 +j1.000
+r3 -q9 -w640 -H480 -S1 -E480 -k0.000 -mv2.0 +b1000 > results.txt
In 2) the command line section was modified per POVBench instructions:
Edit settings/Render (or press Alt+C) and pasted:
+v1 -d +ft -x +a0.300 +r3 -q9 -w640 -h480 -mv2.0 +b1000
into the "Command line options" box.  Skyvase.pov was already loaded (and
was the only file loaded),
I also set the GUI priority to lowest and the Render priority to highest.
Anybody got any ideas why the difference was so large?
Jim
Subject: Re: POV Benchmark Windows ME - big difference between command line and GUI
Date: 21 Nov 2000 04:15:46
Message: <3a1a3d42@news.povray.org>
Did you try with the MSVC compile of povray?
Date: 21 Nov 2000 04:38:08
Message: <3A1A427F.5843FFB8@ij.net>
> 2) POV  GUI                             43 sec
	The usual answer is the difference is the overhead of running a windows
OS. About 25% and a bit high but that may be the new ME. It runs so many
things as cycle consuming processes that you have to expect this sort of
thing.
	Object oriented. The entire GUI screen is an object. That little PPS
number in the bottom right is a daughter process. The entire screen is
updated for that little change. I didn't make it that way, Gates did.
When roads are removed from national parks it
discriminates against the handicapped.
	-- The Iron Webmaster, 146
Date: 21 Nov 2000 07:43:25
Message: <3a1a6dec@news.povray.org>
>> 2) POV  GUI                             43 sec
> thing.
Was the first run in a dos window or in Dos (ie, restart computer in Dos
only mode)?  Also, was the image displaying?  I've found that image display
takes up a large chunk of time for no reason that I can see, so I've taken
to turning it off and only doing spot checks.
Geoff
Date: 21 Nov 2000 08:10:15
Message: <slrn91kt1o.dgt.ron.parker@fwi.com>
Is not.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 21 Nov 2000 09:03:07
Message: <3A1A7F49.67C5DCF1@my-dejanews.com>
Can you also cite a benchmark between the new and old PC's, along with chip
type & speed, and RAM?
> 2) POV  GUI                             43 sec
Date: 21 Nov 2000 12:55:11
Message: <3a1ab6ff$1@news.povray.org>
I ran it in a DOS window under Windows ME.  I did not reboot to DOS.
Jim
"Geoff Wedig" <wed### [at] darwinepbicwruedu> wrote in message
news:3a1a6dec@news.povray.org...
benchmark
with
> >> 2) POV  GUI                             43 sec
windows
> > thing.
PPS
display
> Geoff
Date: 21 Nov 2000 12:56:06
Message: <3a1ab736$1@news.povray.org>
I used the standard downloaded executable from povray.org.  I did not
compile the source code.
Jim
news:3a1a3d42@news.povray.org...
Date: 21 Nov 2000 12:56:41
Message: <3a1ab759$1@news.povray.org>
Both runs were from the same (new) PC, one right after the other.
Jim
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:3A1A7F49.67C5DCF1@my-dejanews.com...
chip
> > 2) POV  GUI                             43 sec
Date: 21 Nov 2000 13:47:28
Message: <3A1AC1EF.7391EC80@my-dejanews.com>
Yes I figured, but could you run it on your old PC and then tell us specs
for old & new PC?
