POV-Ray : Newsgroups : povray.general : New Bug Server Time
31 Dec 2025 22:45:32 EST (-0500)
  New Bug (Message 1 to 5 of 5)
Subject: New Bug
Date: 17 Nov 2000 14:32:09
Message: <3a1587b9@news.povray.org>
I had an orthographic camera pointed at a height field so that the hf just
managed to fill the screen.  The camera was perpendicular to the hf.  POV
got to the last line and then crashed.  Does anyone know what is going on?
Subject: Re: New Bug
Date: 17 Nov 2000 15:40:55
Message: <3A15A5FE.F2957D3@yahoo.com>
Hmm... I don't know... maybe something in your height field image?
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Date: 17 Nov 2000 17:51:34
Message: <3a15b676@news.povray.org>
Possible a precision error of some sort (which seem to be reasonably common
with height-fields) - you could try finishing the rendering using the +C
command line option.  Failing that, cropping the image (and giving thanks
that POV-Ray allows you to buffer the output to disk!) should be fine in
this case.  Generally, moving the camera position/look_at very slightly
should stop the crash.
Date: 20 Nov 2000 05:28:35
Message: <3a18fcd2@news.povray.org>
Crashing is ALWAYS a bug.
  It doesn't matter how wrong the input is, the program should never crash
(if the input is wrong, the correct behaviour is to issue an error, not
crashing).
  A concrete example scene could be good for testing this bug.
Date: 20 Nov 2000 14:19:12
Message: <3a197930@news.povray.org>
I tried making an example file but I couldn't reproduce the bug, the file
worked perfectly!  The program decided to make a liar out of me.  At least
now I can use this to make my maps for Virtual Sailor.
