POV-Ray : Newsgroups : povray.general : The Transmit Value Server Time
28 Nov 2025 23:17:47 EST (-0500)
  The Transmit Value (Message 1 to 10 of 10)
Subject: The Transmit Value
Date: 3 Nov 2000 16:45:33
Message: <3a0331fd@news.povray.org>
Could someone who knows the inner workings of POV-Ray (and MegaPOV) please
tell me why transmit values outside the range of 0 to 1 work as they do?
And why does it work differently in MegaPOV than in POV-Ray 3.1?
In povray.binaries.images I have posted some graphs that show how the
transmit value seem to work in POV-Ray 3.1, in MegaPOV 0.6, and how I would
like it to work.
The reason I would like the transmit value to work different is that if it
works my way (which is more simple), it can be used for many different
special-effects such as inverting pigments and contrast-enhancing pigments.
My suggested change will most probably not brake any old scenes because it's
not very common to use transmit values outside the range of 0 to 1. Values
between 0 and 1 will work the same way as it currently does.
I have brought up this subject before, but not got the response I hoped for.
This time I *really* hope for some feedback - especially from people who
know what they're talking about! ;)
If you don't want to use my suggested change, could you at least tell me
*why* it should work as it currently does?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 9)
/ Also visit http://www.povrayusers.org
Subject: Re: The Transmit Value
Date: 4 Nov 2000 17:26:18
Message: <3A048D05.DD02CCE7@merlin.net.au>
> like it to work.
> Rune
So you're saying that the colour should be simply (1-t)*pigment +
t*background ?
Sounds good to me.  I've used strange transmit values to modify the
background colour but in that case I usually use rgbt of
<0,0,0,SomeOddValue> so the change would not affect me.
BTW I don't know why MP clamps negative values to zero.
PoD.
Date: 4 Nov 2000 18:53:29
Message: <3a04a179@news.povray.org>
> (1-t)*pigment + t*background ?
Yep. Just like it is for values between 0 and 1.
> to modify the background colour but in that case I
> usually use rgbt of <0,0,0,SomeOddValue> so the change
Here's an inverting pigment:
pigment {color rgb 0.5 transmit -1}
It works in official POV-Ray, but not in MegaPOV.
Here's a contrast-enhancing pigment:
pigment {color rgb 0.5 transmit 2}
However, it doesn't work. It would only work if the transmit value was
changed to work the way I suggest...
Neither do I and I would *really* like someone to explain it to me...
Rune
Date: 5 Nov 2000 12:40:31
Message: <chrishuff-C97976.12402905112000@news.povray.org>
In article <3a04a179@news.povray.org>, "Rune" <run### [at] inamecom>
Perhaps because it was intended to simulate transparency and was only
designed to work in the range of 0-1?
As far as I can tell, MegaPOV does it the way it is supposed to work. I
do think there needs to be a more powerful way of specifying
transparency, and a separate way for specifying transparence in layered
textures.
Christopher James Huff
Date: 5 Nov 2000 18:01:28
Message: <3a05e6c8@news.povray.org>
> was only designed to work in the range of 0-1?
> to work.
If it is supposed to be used in the range of 0 to 1 only, then using values
outside this range should generate an error or at least a warning.
However, there is no reason to confine the valid values to be from 0 to 1.
Being able to use values outside this range will be *very* useful - not for
realism, but for many other things.
Anyway, values outside the 0 to 1 range *can* be used; the question is why
it works in such a strange way. Is there an actual senseful reason behind,
or was it coded this way for no particular reason?
I would find it very annoying if I am prevented from effectively using a
powerful feature for "no particular reason". I'm not saying that there isn't
a good reason for the way it works, but it really bothers me not to know
what it is, or if there is one at all.
That's why I would *reeeaally* like to be told *why* *it* *works* *as* *it*
*does*!
(Both for official POV-Ray and for MegaPOV).
Oh well, I guess that if you want to have something changed, you gotta do it
yourself.
And if you can't - sigh...
Rune
Date: 6 Nov 2000 02:32:59
Message: <3a065eaa@news.povray.org>
I have to admit that Rune's suggestion (in p.b.i) looks rational and makes
sense. It certainly can be useful that way.
Date: 6 Nov 2000 08:49:07
Message: <3A06B6D6.E83EF82E@atos-group.com>
Me too :-)
Does Rune already have the patch to do it that new way?
Date: 6 Nov 2000 10:58:04
Message: <3a06d50c@news.povray.org>
"J. Grimbert" wrote:
> > rational and makes sense. It certainly can be useful that way.
> Me too :-)
Nope, unfortunately not, it's more like a feature request.
Maybe if this thread grows big enough the right people will begin to notice
it! ;)
Rune
Date: 13 Nov 2000 03:58:36
Message: <3A0FAD43.4DC0A12C@atos-group.com>
> it! ;)
Well, I'm not the right people, but I have done the patch.
(see p.b.i for illustration).
As it is really easy for 3.1g (and short), I give it inline here
in lighting.c, find the line in comment and replace with the next:
      /* Att = Trans * (1.0 - min(1.0, LayCol[FILTER] + LayCol[TRANSM])); */
      Att = Trans * (1.0 - (LayCol[FILTER] + LayCol[TRANSM]));
As I do not have the MegaPov sources, it is left as an exercise
for the MegaPov maintainers...
P.S. : I stated the patch was easy, well, not that easy. The computation
of the colour applies to layered textured, so I had to understand the code
first.
Date: 13 Nov 2000 16:14:57
Message: <chrishuff-72E4DE.16150813112000@news.povray.org>
In article <3a05e6c8@news.povray.org>, "Rune" <run### [at] inamecom>
> is why it works in such a strange way. Is there an actual senseful
> reason behind, or was it coded this way for no particular reason?
> *as* *it* *does*! (Both for official POV-Ray and for MegaPOV).
Because it was designed to work for values between 0 and 1, and
apparently someone didn't take into account the use of values outside
that range. Someone probably noticed that although it only works
properly in the [0, 1] range, it allowed values outside that range, so
they "fixed" it, not realizing values outside that range had any use.
Or maybe it messes up layered textures or something...
