POV-Ray : Newsgroups : povray.general : POV-Tree 1.2 Server Time
12 Jun 2026 17:10:02 EDT (-0400)
  POV-Tree 1.2 (Message 1 to 7 of 7)
Subject: POV-Tree 1.2
Date: 18 Aug 2003 02:25:26
Message: <3F406F3D.3020900@yahoo.com>
New version of POV-Tree 1.2 is available here:
http://propro.ru/go/Wshop/tools/tools.html
See some screenshots in p.b.images.
New features in POV-Tree 1.2:
-  Added blossom generator. It supports original heightfield
   blossoms from TOMTREE and new mesh blossom as well. Created
   6 examples of mesh blossom. Custom mesh blossom can be
   created the same way as custom mesh leaf.
-  'Tree' tab splitted into two new tabs - 'General' and
   'Examples'. 'General' tab has interactive tree image and
   text fields for displaying the number of triangles in mesh
   tree and required disc space for that tree. 'Examples' tab
   has all previous example trees including three new examples:
   'Default' tree. POV-Tree starts with this tree.
   'Cherry' - example of using blossom.
   'Pine'.
-  Added 'Tabs' menu for changing orientation of tabs. There are
   two possible variants: top and bottom. The main purpose of
   'Bottom' orientation was to shorten distance between tabs'
   headers and 'Preview' button.
-  Created 'Randomness' buttons for Roots, Branches and Twigs.
   Now clicking that button you can get next random number.
   There is no need to type it manually anymore.
-  Added Up, Down, Left and Right buttons to foliage/Size&Color
   tab. So, if you need just one color there is no need to type
   RGB values four times. It can be defined just once and than
   copied to another fields using those buttons.
Gena.
Subject: Re: POV-Tree 1.2
Date: 19 Aug 2003 02:12:45
Message: <3F41BDC1.7000609@yahoo.com>
Several people reported problem with saving include files.
I fixed that bug in version 1.2.1. It's available from the same link:
Gena.
Date: 20 Aug 2003 11:52:46
Message: <Xns93DD78DB1E8E3None@204.213.191.226>
Gena Obukhov <gen### [at] yahoocom> wrote in news:3F41BDC1.7000609
@yahoo.com:
Thanks very much!
Date: 20 Aug 2003 14:07:45
Message: <3f43b8f1$1@news.povray.org>
Some minor misbehavior still exists with saving include
(non-mesh) files. For example, if you don't use blossom
(blossom type is not selected) POV-Tree will write to
file:
#declare BLOSSOM=;
Then if you use TOMTREE or TOMTREEm to render the tree
POV-Ray will fail parsing this line. Temporary workaround
can be just comment out this line:
//#declare BLOSSOM=;
I'll fix this problem in next release writing to file
something like:
#declare BLOSSOM="NONE";
It will happen after my vacation somewhere in the end of
September. I'm also planning to add some other
changes/improvements to that release.
Gena.
Date: 22 Aug 2003 03:06:27
Message: <3f45c0f3@news.povray.org>
"Gena" <gen### [at] yahoocom> schreef in bericht
news:3f43b8f1$1@news.povray.org...
> file:
> #declare BLOSSOM=;
Why not just make it:  #declare BLOSSOM=0;    ?  Because that is exactly
what is given in POV-Tree. And it works also as a workaround, by the way.
Otherwise, great applet!!!
Cheers!
Date: 22 Aug 2003 10:37:40
Message: <3F462897.6070004@yahoo.com>
BLOSSOM parameter is a type of blossom. It's not a number of blossoms.
Though I agree that 0 works as well :)
Thanks!
Actually it's a Java application. Applet is a Java program which works
inside of web browser (or applet viewer).
Gena.
Date: 23 Aug 2003 05:44:27
Message: <3f47377b$1@news.povray.org>
"Gena Obukhov" <gen### [at] yahoocom> schreef in bericht
news:3F4### [at] yahoocom...
Oeps! My fault! I thought it was number. But then, I have not yet used
blossoms...
> Thanks!
Oeps, again! Right of course! I should learn to use terms correctly  ;-}
