POV-Ray : Newsgroups : povray.general : Scaling macros? Server Time
2 Feb 2026 12:09:56 EST (-0500)
  Scaling macros? (Message 1 to 10 of 15)
Subject: Scaling macros?
Date: 29 Jul 2003 13:05:37
Message: <3F26A95E.4D3834F1@hotmail.com>
Let's say I design a scene using centimeters.  You design a model using
meters, or some English unit.
Who would find a set of relatively automatic scale converters
useful?
The way I envision them, the scene builder calls one macro early in
the scene:
  ExpectMeters()
while the model maker calls another macro in their code:
union {
  sphere { pHere,rSize }
  // etc
  UseCentimeters()
The two macros work together to make sure that the latter item is
scaled properly (in this example, by 1/100).
Except for models using IK, the macros are pretty easy to do.  Any
takers?
John
PS:  Pardon me if this has been done.
Subject: Re: Scaling macros?
Date: 29 Jul 2003 13:41:45
Message: <cjameshuff-DE318D.12414529072003@netplex.aussie.org>
In article <3F26A95E.4D3834F1@hotmail.com>,
> useful?
What I do is just define cm, mm, m, km, etc at the beginning of the
scene. Then I just do something like "15.7*m" when specifying a
dimension. A macro version could also work, something like: "km(45)"
I do use lowercase identifiers here, but I don't think a collision is
likely for these and it helps separate them from the rest of the code.
> union {
>   // etc
>   UseCentimeters()
I think this is a bit harder to read, putting the units separate from
the values, and it might slow things down by forcing transformations to
be evaluated unnecessarily, especially in the case of CSG.
union {
  sphere { pHere*cm, rSize*cm }
  // etc
union {
  sphere { pHere, rSize scale cm}
  // etc
http://tag.povray.org/
Date: 29 Jul 2003 15:40:00
Message: <web.3f26cd289c12b5437196f5900@news.povray.org>
>dimension.
What a simple, convenient, smart, clean way to do things.  How come I don't
think like that?
As long as others do, and I copy your ideas, I guess I'm ok.
Thanks for the tip.
I'll be using it a lot.
Dave Matthews
Date: 29 Jul 2003 17:05:01
Message: <web.3f26e01d9c12b543a0c272b50@news.povray.org>
>useful?
>the scene:
>  ExpectMeters()
>union {
>  // etc
>  UseCentimeters()
Well, being UScentric, I have been using (usually) 1 pov unit = 1 Ft.  I
don't usually use other people's models so haven't had a problem, but as my
model collection grows I've been thinking about posting some of them to the
Pov-Ray object library, so I suppose others might find that useful.
I usually do basically what Chris described, defining my units at the start
of the file like #declare Ft = 1; #declare In = Ft/12; etc and using
something like 'translate x*14.25*Ft' or '#declare Rad = 5.5*In'.  Not sure
how your macro would handle that.
But this is something I have been wondering myself, how others deal with
different scalings and unit sizes.  I've tried to keep all of mine together
and right at the top of the file so if someone wanted to do their own
conversion it shouldn't be too difficult.
How do all you POV masters handle your units?
RG
Date: 29 Jul 2003 17:53:22
Message: <cjameshuff-BD125F.16532229072003@netplex.aussie.org>
In article <web.3f26e01d9c12b543a0c272b50@news.povray.org>,
You could also base them all off of one value:
#declare m = 1;
#declare cm = m/100;
#declare mm = m/1000;
#declare km = m*1000;
#declare in = m/0.0254;
#declare ft = in*12;
#declare yd = ft*3;
#declare mi = km/1.607347;
This way, you only have one constant to change...the number of units in
a meter, in this case. If everyone uses the same unit names, all you
have to do is change that value. (or just remove it and place it
elsewhere, such as in a "units.inc" file)
Date: 29 Jul 2003 20:03:40
Message: <pan.2003.07.30.00.07.09.69031@THISSHOULDBEREMOVEDhotmail.com>
Hmmm... Are you sure about this Christopher ?
Tor Olav
Date: 29 Jul 2003 20:11:54
Message: <cjameshuff-2BF323.19115429072003@netplex.aussie.org>
In article
<pan### [at] THISSHOULDBEREMOVEDhotmailcom>,
 "Tor Olav Kristensen" <tor### [at] THISSHOULDBEREMOVEDhotmailcom>
Ah...I guess that should be multiplication, shouldn't it...
Date: 29 Jul 2003 20:45:13
Message: <pan.2003.07.30.00.48.41.771613@THISSHOULDBEREMOVEDhotmail.com>
On Tue, 29 Jul 2003 19:11:54 -0500, Christopher James Huff wrote:
> In article
Yes (Unless you have very long inches in the US)
Tor Olav
Date: 30 Jul 2003 04:59:39
Message: <3F2788FA.1050401@spam.fr>
Cool thread, it's always interesting to see how others handle common
problems.
I use to define all my models in meters. And when it is not appropriate
I define the object in centimeters for example and then I scale the
whole model to meters. I do the same with models I get from outside.
JC
> useful?
> the scene:
>   ExpectMeters()
> union {
>   // etc
>   UseCentimeters()
> takers?
> Regards,
> John
Date: 30 Jul 2003 21:06:20
Message: <3f286b8c@news.povray.org>
> #declare m = 1;
I strongly suggest to use MUCH larger values if possible; see my
thread "Small is NOT BEAUTIFUL" in p.g, 11 Feb. 2003. Especially
transparency, almost-coincident surfaces and shadows are highly
problematic. For indoor scenes of "normal" scale I suggest to
use 1 POV-unit = 1 mm or less.
   Sputnik
P.S. If the sphere in the second "Small is NOT BEAUTIFUL" demo scene
     is removed, then all errors are reduced by about three orders
     of magnitude -- try with scale 0.004!
