POV-Ray : Newsgroups : povray.general : How to place a warp on a sphere? Server Time
12 Aug 2025 13:54:16 EDT (-0400)
  How to place a warp on a sphere? (Message 1 to 4 of 4)
Subject: How to place a warp on a sphere?
Date: 10 Apr 2003 13:04:29
Message: <3E95C069.BA9CA59B@tiscalinet.de>
High!
I have a problem with warps on a texture (in this case, a slightly
turbulated gradient y texture, it's intended to be a cloud
texture for a gas giant) assigned to a sphere:
When the sphere is at <0, 0, 0> with a radius of 1, and the camera at,
let's say <0, 0, -3> looking at <0, 0, 0>, a warp
visible at the center of the sphere side facing the camera should have
the position <0, 0, -1>... I tried this, but the warp
doesn't show up at all! What went wrong?
See you in Khyberspace!
Yadgar
Subject: Re: How to place a warp on a sphere?
Date: 10 Apr 2003 13:17:08
Message: <3e95a714$1@news.povray.org>
> High!
Thats difficult to say without source.
Date: 10 Apr 2003 13:25:13
Message: <3e95a8f9@news.povray.org>
you could make a test on a disc with different values of z for your warp
Marc
news: 3E95C069.BA9CA59B@tiscalinet.de...
> High!
> Yadgar
Date: 10 Apr 2003 15:56:51
Message: <3E95E8D0.7A9ED045@tiscalinet.de>
High!
O.k., here's the source - different values, but the problem is essentially
the same!
light_source
  0
  color rgb <1, 0.95, 0.9>
sphere
  0, 1
  texture
    pigment
      gradient y
      color_map
        [0.02     rgb <0.7, 0.45, 0.2>]
        [0.078  rgb <0.64, 0.46, 0.18>]
        [0.09  rgb <0.3, 0.03, 0>]
        [0.105 rgb <0.3, 0.03, 0>]
        [0.1136 rgb <0.8, 0.76, 0.26>]
        [0.153 rgb <0.9, 0.8, 0.35>]
        [0.208 rgb <0.78, 0.69, 0.12>]
        [0.223 rgb <0.95, 0.71, 0.02>]
        [0.265 rgb <0.94, 0.72, 0.05>]
        [0.275 rgb <0.24, 0.17, 0.01>]
        [0.28  rgb <0.25, 0.16, 0.02>]
        [0.305  rgb <0.65, 0.57, 0.2>]
        [0.357 rgb <0.7, 0.54, 0.12>]
        [0.364 rgb <0.9, 0.87, 0.76>]
        [0.412 rgb <0.95, 0.86, 0.74>]
        [0.438 rgb <0.87, 0.43, 0.12>]
        [0.491 rgb <0.87, 0.45, 0.09>]
        [0.505 rgb <0.27, 0.19, 0>]
        [0.563 rgb <0.25, 0.18, 0.01>]
        [0.578 rgb <0.89, 0.89, 0.65>]
        [0.588 rgb <0.90, 0.89, 0.65>]
        [0.609 rgb <0.26, 0.17, 0.01>]
        [0.65  rgb <0.25, 0.19, 0>]
        [0.659 rgb <0.76, 0.5, 0.11>]
        [0.682 rgb <0.75, 0.43, 0.09>]
        [0.694 rgb <0.89, 0.78, 0.24>]
        [0.78  rgb <0.91, 0.8, 0.21>]
        [0.8 rgb <0.68, 0.32, 0.1>]
        [0.825 rgb <0.12, 0.09, 0>]
        [0.831 rgb <0.11, 0.11, 0.01>]
        [0.855 rgb <0.7, 0.56, 0.03>]
        [0.876 rgb <0.72, 0.57, 0.06>]
        [0.911 rgb <0.9, 0.85, 0.43>]
        [0.934 rgb <0.97, 0.9, 0.53>]
        [0.953 rgb <0.81, 0.72, 0.45>]
        [0.964 rgb <0.82, 0.702, 0.42>]
        [0.982 rgb <0.98, 0.92, 0.6>]
        [0.984 rgb <0.97, 0.9, 0.62>]
        [0.991 rgb <0.915, 0.84, 0.52>]
        [0.995 rgb <0.967, 0.904, 0.59>]
      phase 0.5
      turbulence 0.03
      octaves 6
      omega 0.75
      // lambda 6
      scale <1, 1, 1.3333>
      warp
        black_hole
        <0, 0, -1>, 1
        strength 5
        falloff 2
        inverse
      warp
        black_hole
        <0.1, 0, 1.2>, 0.09
        strength 5
        falloff 2
        inverse
      warp
        black_hole
        <0.3, 0, -0.1>, 0.15
        strength 5
        falloff 2
        inverse
      scale <1, 1, 0.75>
    finish
      ambient 0.01
      diffuse 1
    scale 2
    translate -z
  scale <94.23, 91.7, 94.23>
  translate <0, 0, 120000>
camera
  location <0, 0, 119000>
  look_at <0, 0, 120000>
  angle 20
