POV-Ray : Newsgroups : povray.general : Calculating the normals of a triangle Server Time
21 Jan 2026 00:29:23 EST (-0500)
  Calculating the normals of a triangle (Message 1 to 10 of 14)
Subject: Calculating the normals of a triangle
Date: 11 Sep 2002 08:03:19
Message: <3D7F30C8.9030800@fritschy.de>
i wrote a simple triangulation algo for a noise program to generate
something like a hieghtfield, and i wanted to use this with
smooth_triangles, does anybody knows how to calculate the normals of the
three points from the known triangle?
greetings, Marcus
Subject: Re: Calculating the normals of a triangle
Date: 11 Sep 2002 08:36:12
Message: <qvdunu4kj2h82glmf0i9l824m2t65gov8v@4ax.com>
On Wed, 11 Sep 2002 14:02:16 +0200, Marcus Fritzsch <m### [at] fritschyde> wrote:
It is averaged addition from normals of all triangles in this vertex.
Be aware it can be weighted with angle/area:
http://news.povray.org/povray.binaries.images/13313/
ABX
Date: 11 Sep 2002 08:40:51
Message: <3d7f39d3@news.povray.org>
  There are basically two ways:
  1. If you know the function which was used to generate the mesh and you
can derive the function with respect to x, y and z (or x and y in the
case of a heightfield function f(x,y)), then you can use the gradient
of the function (ie. <df(x,y)/dx, df(x,y)/dy>) to calculate the normal
vector at any point of the function.
  2. If you don't know the function, or the function is not differentiable
(or it's just too difficult to do so), then you can use an approximation
which works quite well for (almost) any mesh: The normal vector at a vertex
point is the sum of all the normal vectors of the triangles sharing that
vertex.
  (The normal vector of a triangle can be calculated with the cross-product
of two of its edges. According to empirical tests, *not* normalizing these
normals gives the best result in the sum described above (because the
dot-product of the two edges of a triangle gives a normal vector which
length is equal to the area of the triangle, and not normalizing this
vector means that a larger triangle has more effect in the normal of the
vertex than other smaller triangles sharing that same vertex, which
reportedly gives better results).)
Date: 11 Sep 2002 09:54:08
Message: <3D7F4AC0.4090901@fritschy.de>
this was exactly what i searched!!
>   1. If you know the function...
Hmm, i guess i don't know the function...
> (or it's just too difficult to do so)...
I'll try this way!
thx a lot :o)
regards, Marcus
Date: 11 Sep 2002 10:20:03
Message: <web.3d7f50003836a27fedbc6d4c0@news.povray.org>
>vertex.
I guess you meant to write 'cross-product' here ;)
Tor Olav
Date: 11 Sep 2002 10:24:43
Message: <3D7F51EA.3080804@fritschy.de>
Hi again...
I have some problems with this part, first you told me about
cross-product of
the edges, than, 2 lines below of the dot-product of the 2 edges...
which one
is right? my maths aren't enough to understand this before have it used
it and
seen the result...
greetings, Marcus
Date: 11 Sep 2002 10:27:18
Message: <3d7f52c2@news.povray.org>
  Yes.
Date: 11 Sep 2002 10:28:15
Message: <3d7f52ff@news.povray.org>
> cross-product of
> which one
> is right?
  Writing "dot-product" was a mistake. It should have been "cross-product".
Date: 11 Sep 2002 10:30:01
Message: <3D7F532A.4080802@fritschy.de>
Hi, :o)
>>cross-product of
>>which one
>>is right?
oops, i wrote my message while the other was postet... :o) ok, now i
know it, thx!
mfg Marcus
Date: 11 Sep 2002 10:45:13
Message: <web.3d7f566a3836a27fedbc6d4c0@news.povray.org>
Warp wrote:
>(because the
Its length is equal to twice the area of the triangle.
Tor Olav
