POV-Ray : Newsgroups : povray.general : Math help Server Time
23 Mar 2026 06:01:25 EDT (-0400)
  Math help (Message 1 to 7 of 7)
Subject: Math help
Date: 12 Aug 2002 14:05:12
Message: <3D57F8D6.3000604@scifi-fantasy.com>
#declare Seed=seed(10000);
#declare N=1;
#while(N<=600)
#declare Theta=rand(Seed)*360;
#declare Z=(N/600)+1.2;
#declare R=(rand(Seed)*0.25)+((Z-1.2)*(Z-1.2)*2);
#declare X=R*cos(Theta);
#declare Y=R*sin(Theta);
<X, Y, Z> 0.02
#declare N=N+1;
Ok, with this I get the general external shape I
want, but the internal points aren't as mixed up
as I'd like...how do I compute a random point in
the shape such that all parts of the sphere_sweep
stay within the shape?  As it stands, if I change
Z to a random number I get the jumbled-up mess I
want, but it leaves parts of the sphere_sweep on
the outside of the shape.  Solution?
Tim Cook
Version: 3.12
Subject: Re: Math help
Date: 13 Aug 2002 00:11:54
Message: <3D588708.1030104@scifi-fantasy.com>
I am told that I need 3d integrals to figure out the
points to fill a given space with random lines with-
out going outside that space...looking on Google, I
see a few sites that seem relevant, but are beyond
my understanding.  Anyone care to give me a quick
rundown on what exactly is involved here?
Tim Cook
Version: 3.12
Date: 13 Aug 2002 08:16:25
Message: <3d58f899@news.povray.org>
Really.  Well, why not simply generate random number pairs in 3space?
Assume a box enclosing your given space and then generate a point within that
volume and a vector associated with the point.  This will give you a pretty
uniform scattering of said random lines.
Cheers!
Chip Shults
Date: 13 Aug 2002 10:35:33
Message: <Xns9269A9780A1DBseed7@povray.org>
VRand_In_Obj(Object, Stream) in rand.inc can be of help here.
Ingo
Date: 13 Aug 2002 10:40:58
Message: <bf6ilucifl7kv31dt4dc0t0gd65jig7bq8@4ax.com>
It can help but can't solve.
As I understand he wants sphere_sweep in object, not only control points.
ABX
Date: 13 Aug 2002 10:51:17
Message: <chrishuff-D317FE.09393713082002@netplex.aussie.org>
In article <Xns### [at] povrayorg>, ingo <ing### [at] homenl>
For random points, it won't be very useful for random lines unless the
shape is guaranteed to be convex. For example, if you have a torus, it
is very easy to have a line with the end points inside but which goes
outside the shape. You need to check the end points and a lot of points
along the line using the inside() function, or (faster and more
accurate) use the trace() function to trace a ray along the line from
one end point and check for an intersection closer than the other end
point.
http://tag.povray.org/
Date: 13 Aug 2002 12:56:59
Message: <3D593A59.7080008@scifi-fantasy.com>
Exactamally.  I can fill the space with random spheres easy.
It's when you connect random ones that it doesn't work nice.
Tim Cook
Version: 3.12
