POV-Ray : Newsgroups : povray.general : [announce] HCR-Edit 0.2 Server Time
21 Aug 2025 08:04:07 EDT (-0400)
  [announce] HCR-Edit 0.2 (Message 1 to 5 of 5)
Subject: [announce] HCR-Edit 0.2
Date: 28 Jun 2002 15:37:14
Message: <3D1CBAEA.22F35C29@gmx.de>
New features:
 * undo function for modifications.
 * saving of program settings when exiting.
 * color curve adjustment function.
 * focal blur post processing.
Both the color curves and the focal blur function use a new spline control
component i wrote.  It's not tested very much so there could be bugs.  I
would be grateful for feedback concerning usability of this control.
The focal blur function is quite slow because it directly evaluates the
spline function every time.  Precalculating the values would probably be a
good idea.  Also the blur radius does not depend on the distance right now
which would be good to change too.  An example of the focal blur function
can be found in p.b.i.
http://www.tu-bs.de/~y0013390/hcredit/
Last updated 28 Jun. 2002 _____./\/^>_*_<^\/\.______
Subject: Re: [announce] HCR-Edit 0.2
Date: 28 Jun 2002 17:01:45
Message: <Xns923BEADA3162Cseed7@povray.org>
in news:3D1CBAEA.22F35C29@gmx.de Christoph Hormann wrote:
Christoph,
The help is not accessable from within the program. It worked fine with
the previous version.
Thanks, seems to work well. Only did some quick tests so far.
Nice feature, especialy when you can implement the variable blur radius.
> control component i wrote.
What I've done with them so far works good.
Ingo
Date: 29 Jun 2002 06:11:38
Message: <3D1D87D9.9F905F10@gmx.de>
Found the problem, will be fixed in next version.
Great, thanks for commenting.
Subject: version 0.3
Date: 30 Jun 2002 12:17:05
Message: <3D1F2F00.EB09031A@gmx.de>
Version 0.3 is available with various fixes and improved focal blur (see
p.b.i.)
Last updated 30 Jun. 2002 _____./\/^>_*_<^\/\.______
Subject: Re: version 0.3
Date: 30 Jun 2002 17:58:29
Message: <cmvuhuggrla5dpsccm0ielgqi3fta7adh8@4ax.com>
>p.b.i.)
  ...v0.3 of HCR-Edit :)
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
