POV-Ray : Newsgroups : povray.general : Stupid math error Server Time
29 Dec 2025 19:58:39 EST (-0500)
  Stupid math error (Message 1 to 5 of 5)
Subject: Stupid math error
Date: 1 Apr 2002 22:51:49
Message: <3CA92B31.5E72FE6A@unforgettable.com>
Okay, this is driving me nuts. I have a bunch of 4 x .5 x 1 boxes which
are stacked corner to corner in a stair pattern. Given their layout, I
thought/assumed that they make a 30 degree angle with the ground (a
plane), but when I added another box on the side and rotated it up 30
degrees, it didn't line up with the blocks!
I'm stumped. Barring some kind of bug, I can't imagine why I'm having
this problem; the math isn't particularly complicated here. Can anyone
help me with this? Code follows:
#declare stair_row = union
	#declare stair_row_members = 1;
	#declare stair_row_count = 0;
	#while (stair_row_count < stair_row_members)
		box { <0, 0, 0> <4, .5, 1> }
		#declare stair_row_count = stair_row_count + 1;
#declare stair_block = union
	#declare stair_rows = 10;
	#while (stair_row_count < stair_rows)
		object { stair_row translate <0, stair_row_count/2, stair_row_count> }
#declare stair_rail = union
	box { <0, -in, 0> <in*1, 0, 15> rotate <-30, 0, 0> }
(An image demonstrating the problem has been posted in p.b.i.)
I'm using MacMegaPOV 0.7 (I don't care for the present interface of the
official beta) on Mac OS 8.6, if anyone cares.
-Xplo
Subject: Re: Stupid math error
Date: 2 Apr 2002 04:28:36
Message: <pan.2002.04.02.03.39.07.320562.23227@ednet.rvc.cc.il.us>
<snip>
> -Xplo
ok, one of you math geniuses can correct me if I'm wrong here, but I
think your problem is that the boxes do not form a 30 degree angle with
the ground...
taking a corss-section from the side view, you essentially are stacking
.5 x 1, and let's place the first one so the bottom left corner is at the
origin, like so:
  |   __
  |__|__|
ok, the upper right corner of the second box is at (1,2), which gives you
a triange with sides of length 1, 2, sqrt(5).  Manipulating
the pythagorean theorem, you get something similar to the following:
1=sqrt((1/sqrt(5))^2+(2/sqrt(5))^2).  So on the unit circle, you have an
x value of 1/sqrt(5), and a y value of 2/sqrt(5), and acos(1/sqrt(5)) is
approximately equal to 63.435.  I haven't tried this in your code, so I'm
not sure if this will work, but I'm pretty sure I didn't make any
mistakes.  Though, you never know at 3:30 in the morning.  Hope this
helps!
David
smuchrusher <at> ameritech <dot> net
ICQ#: 118347772
3:10am up 4 days, 11:48, 4 users, load average: 3.80, 3.33, 3.11
Date: 2 Apr 2002 04:44:58
Message: <pan.2002.04.02.03.55.33.418120.23227@ednet.rvc.cc.il.us>
> <snip>
>> -Xplo
> the ground...
> the origin, like so:
>   |   __
>   |__|__|
> you a triange with sides of length 1, 2, sqrt(5).  Manipulating the
> I'm not sure if this will work, but I'm pretty sure I didn't make any
> helps!
oops... jsut saw everyone's response in p.b.i, though I am still curious
if this is logically correct....
David
ICQ#: 118347772
Date: 2 Apr 2002 13:48:10
Message: <3ca9fcea$1@news.povray.org>
Without taking a long time to look at your math, I'd say that yes you are
correct, since you came up with the number
63.435
and I came up with the number
26.565
in my own post, and those numbers added together make 90.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 2 Apr 2002 14:51:02
Message: <3CAA0C02.ADFC7CC2@unforgettable.com>
> 63.435
> 26.565
Yeah. Thanks for the help, guys.
-Xplo
