![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm trying to figure out how to arrage a spherical iris...any ideas?
Tim Cook
Version: 3.12
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm reminded of a sort of ornament/toy thing a friend of mine has. I'll
try and do a render later today to show you what I mean. Where is it to
be used? (If you don't mind)
signature{
"Grey Knight" contact{ email "gre### [at] yahoo com" }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Grey Knight wrote:
> Where is it to be used? (If you don't mind)
I need a submarine for my ORCA scene, and because I'm having difficulty
importing other file formats, I'm building one myself.
Tim Cook
Version: 3.12
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm still working on it, but I need to go to a lecture now. Here's the
code for a flat iris extracted from my archives, maybe you can modify it
while I'm away.
I'll try and finish it later.
#macro ensure_vector(Input)
Input+< 0, 0, 0>
#macro rotate_to(iVector)
#local Vector=ensure_vector(iVector);
#if (vlength(Vector)=0)
#warning "rotate_to:\f!WARNING! Trying to rotate onto null vector
!WARNING!\n\n"
#if (Vector.x=0 & Vector.z=0)
#local RotY=0;
#else
#local RotY=degrees(atan2(Vector.x,Vector.z));
#local RotX=degrees(acos(vnormalize(Vector).y));
rotate <RotX,RotY,0>
#macro disc_iris(iCenter,iNormal, Radius, NumPetals, Open, UseUnion)
//Original macro by Michael Andrews
#declare Center=ensure_vector(iCenter);
#declare Normal=ensure_vector(iNormal);
intersection{
cylinder{ -0.05*z, 0.05*z, 1 }
#if(UseUnion)
union{
#else
merge{
#local c=0;#while(c<NumPetals)
cylinder{ -0.01*z, 0.01*z, 1
rotate -3*y
translate y
rotate 60*z
translate -y rotate -Open*Open*120*z translate y
rotate 360*(c/NumPetals)*z
#local c=c+1;#end
scale Radius
rotate 90*x
rotate_to(Normal-Center)
translate Center
signature{
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Grey Knight wrote:
> Here's the code for a flat iris extracted from my archives, maybe
> you can modify it while I'm away.
Er? Point 1: I use Moray to make my scenes, and don't really get
into hand coding... Point 2: However, I do see some math in there
that might be helpful to have a straight explanation of what you're
doing to accomplish the task with some simple formulas (of the
'plug in this number and out comes this other number' variety)
Maybe a nice diagram...
Tim Cook
Version: 3.12
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorry I forgot to say the disc_iris macro was originally written by
someone else, then dumped into my personal archives. Here's a quick
breakdown, but I have to run soon, so I can't be more specific. I'm sure
the other guys can help you analyse the transforms if you're having
trouble.
//^syntax is like that of disc{}, but with 3 extra values;
// NumPetals: integer: number of segments in iris
// Open : 0->1 : amount by which iris is open
// UseUnion : boolean: union petals or merge them?
//^ someone else wrote this
//^ these just make sure we hae vector values!
intersection{
//^ Comment out this line to see what happens
//^ It restricts each petal to the region inside the disc
#if(UseUnion)
union{
#else
merge{
cylinder{ -0.01*z, 0.01*z, 1 // a petal
rotate -3*y
translate y
rotate 60*z
translate -y
translate y
//^ These transformations are what move the petal to it's proper
// position. I haven't time to parse the whole thing right now,
// but just consider each transform in turn to get a feel for what
// they do. You could even try commenting out all but the first line,
// render, uncomment second line, render, etc to see visually what
// each line does.
#local c=c+1;#end
scale Radius
rotate 90*x
translate Center
//^ these transforms just adjust the radius and position of the iris
// to that specified. rotate_to(Vect) just rotates an object pointing
in
// the +y direction to point in the Vect direction.
signature{
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
