POV-Ray : Newsgroups : povray.general : orthographic camera 3.5 beta 10 Server Time
19 Oct 2024 08:22:04 EDT (-0400)
  orthographic camera 3.5 beta 10 (Message 1 to 9 of 9)
Subject: orthographic camera 3.5 beta 10
Date: 15 Jan 2002 08:32:53
Message: <3C442F92.38DF7824@pandora.be>
I often use "orthographic" in the camera definition. In the latest
release beta 10 this results in an error: Parse error: Expected
'camera-modifier', orthographic found instead.
In the help I don't find anything about this change.
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Subject: Re: orthographic camera 3.5 beta 10
Date: 15 Jan 2002 08:43:06
Message: <q8c84u8jfk0cer5lv0pmpotvt7urf5bbi5@4ax.com>
On Tue, 15 Jan 2002 14:33:06 +0100, Herman Serras <Her### [at] pandorabe>
Below is parsed ok:
camera{orthographic up y}
but below returns your message
camera{up y orthographic}
For me it is expected behaviour becous documentation says in 6.4.2 : "In general
the CAMERA_TYPE should be the first item in a camera statement."
If you want old behaviour just change version befor and after camera definition.
Below works fine:
#version 3.1;
#version 3.5;
ABX
Date: 15 Jan 2002 08:43:14
Message: <3c4431f2@news.povray.org>
In article <3C442F92.38DF7824@pandora.be>, "Herman Serras"
> 'camera-modifier', orthographic found instead. In the help I don't find
Try moving "orthographic" to the first line of the camera definition.
I'm not sure the syntax changes made it into the docs.
-Mark Gordon
Date: 15 Jan 2002 09:52:07
Message: <3C444225.E2BC336F@pandora.be>
Thank you, this works.
However as you express, this syntax change isn't made in the docs (as
far as I see).
> -Mark Gordon
Herman Serras
Gent (Belgium)
Date: 15 Jan 2002 11:22:53
Message: <vml84ukt39dusbukpbkpk5oqn4c66j4bis@4ax.com>
On Tue, 15 Jan 2002 15:52:21 +0100, Herman Serras <Her### [at] pandorabe>
> far as I see).
If there is any hole in 3.5 documentation then you should report it in
povray.beta-test group with [doc] prefix in subject, however I pointed you in
this thread documentation says in 6.4.2 : "In general
ABX
Date: 15 Jan 2002 11:40:29
Message: <3C445B8C.A1AB46EF@pandora.be>
> > far as I see).
That's true but in the same paragraph I read:
"If you add the orthographic keyword after all other parameters of a
perspective camera you'll get an orthographic view with the same image
area"...
So you can understand my confusion.
> ABX
Herman Serras
Gent (Belgium)
Date: 15 Jan 2002 11:47:01
Message: <h4n84us3od79siafoc4maap01racbjn8ht@4ax.com>
On Tue, 15 Jan 2002 17:40:44 +0100, Herman Serras <Her### [at] pandorabe>
Also in 6.4 is sentence: "CAMERA_ITEMs may legally appear in any order but the
order of some items is critical to the proper functioning of the camera."
So you should make doc-bug-report in povray.beta-test definietly.
ABX
Date: 15 Jan 2002 16:49:17
Message: <3c44a3dd$1@news.povray.org>
I always used orthographic as the last word in camera definition cause this
is the only way I can guess the visible area. How do I easily swap between
perspective and orthographic??
Hugo
Date: 15 Jan 2002 17:05:09
Message: <3c44a795$1@news.povray.org>
In article <3c44a3dd$1@news.povray.org> , "Hugo" <hua### [at] post3teledk> wrote:
By either using perspective or orthographic...
    Thorsten
e-mail: tho### [at] trfde
