POV-Ray : Newsgroups : povray.general : Handedness Server Time
23 Apr 2026 18:22:32 EDT (-0400)
  Handedness (Message 1 to 10 of 33)
Subject: Handedness
Date: 4 Dec 2001 07:08:27
Message: <3C0CBC37.B78DA0F4@scifi-fantasy.com>
I still don't quite get why math (and hence POV) 3D coords use
left-hand rule; apart from most people being right-handed, CAD
programs use right-hand, being based on architectural design which
draws a floorplan along the XY plane with Z being the elevation,
which is what you get when you draw a floorplan on a standard
cartesian grid with 0,0 being the origin in the lower-left.
Tim Cook
Version: 3.12
Subject: Re: Handedness
Date: 4 Dec 2001 07:21:15
Message: <3C0CBFC9.761DAEB6@atosorigin.com>
> left-hand rule;
Because when you have the pencil in the right hand, only
the left hand is available for fancy manipulation !
Moreover, on computer, you need the right hand for the numeric pad.
(especially when typing pov-vector in script)
And last: Pov is not left-handed. It is half-ambidextrous* :
 default to left hand, but can work without problem with right hand.
* half-ambidextrous: just similar to half-duplex, can be both but not
at the same time.
Date: 4 Dec 2001 07:38:51
Message: <3C0CC3FF.7417E63B@gmx.de>
It's no problem at all to do right-handed geometry in POV, just have a
look at what Moray generates for example.
Date: 4 Dec 2001 08:16:01
Message: <3C0CCC35.8374430B@aol.com>
One may represent the three axes as they appear in povray with one's right
hand, but your coworkers and family members would complain about you
flipping them the bird.
Date: 4 Dec 2001 08:30:21
Message: <slrna0pjvi.bkd.ron.parker@fwi.com>
Math uses the right-hand rule too.  POV uses the left-hand rule by
default because that's how it was created.  Call it a historical
accident.  To change it now would just be wrong.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 4 Dec 2001 08:39:26
Message: <3C0CD18A.968961E9@scifi-fantasy.com>
> one's right hand, but your coworkers and family members would
> complain about you flipping them the bird.
...actually I never understood why people even needed to
represent the axes with their hand except for demonstrating
to people who didn't know about them; I have no trouble
picturing the axes in my head.
Tim Cook
Version: 3.12
Date: 4 Dec 2001 08:43:28
Message: <3c0cd300$1@news.povray.org>
    It's a learning tool... there was a time when you needed to learn it
too, whether you remember it or not.
Date: 4 Dec 2001 08:43:52
Message: <slrna0pkot.bkd.ron.parker@fwi.com>
The "right hand rule" is most useful for visualizing which way a
cross product (or, by extension, a rotation) goes.  If you can do that
in your head, great, but many otherwise talented people can't.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 4 Dec 2001 09:01:12
Message: <3c0cd728$1@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3C0CD18A.968961E9@scifi-fantasy.com...
>I have no trouble
Sounds painful, have you been arguing with Bill?
Date: 4 Dec 2001 09:19:01
Message: <3c0cdb55@news.povray.org>
This isn't quite true. Lots of the primitives have the y-axis hardcoded as
the "vertical" axis.
