POV-Ray : Newsgroups : povray.general : Disc which is not flat Server Time
19 Oct 2024 12:18:35 EDT (-0400)
  Disc which is not flat (Message 1 to 10 of 61)
Subject: Disc which is not flat
Date: 29 Nov 2001 07:29:01
Message: <3C0629CF.B3EABB60@radiok2r.de>
Hello! How can I make a disc which is not infinite flat?!
Martin
Subject: Re: Disc which is not flat
Date: 29 Nov 2001 07:36:24
Message: <3c062bc8@news.povray.org>
Do you mean something like this?
sphere{0,1 scale y*.1}
or maybe this?
cylinder {y,-y,1 scale y*.1}
- Nekar
http://nekar_xenos.tripod.com/metanoia/
"Martin Thoma" <mar### [at] radiok2rde> wrote in message
news:3C0629CF.B3EABB60@radiok2r.de...
> Martin
Version: 6.0.298 / Virus Database: 161 - Release Date: 2001/11/13
Date: 29 Nov 2001 18:24:34
Message: <3C06C487.19BEFCB2@faricy.net>
That should be scale <1,.1,1>
Date: 30 Nov 2001 01:49:22
Message: <3c072bf2@news.povray.org>
news:3C06C487.19BEFCB2@faricy.net...
I didn't know there's a difference. Can you please explain that to me?
Thanks,
- Nekar
Date: 30 Nov 2001 02:37:33
Message: <3c07373d$1@news.povray.org>
y*.1 is equivalent to <0,.1,0>. You can't scale an object by zero in any
direction - it's like squishing it to zero thickness, and there are
mathematical reasons why the concept doesn't work (it relates to division by
zero). You'll notice that when you use something like that, POV-Ray gives
you a warning saying that you can't scale by zero, and it's replacing the
zeros with ones. That's usually the intended behavior, as you just
demonstrated. I usually don't worry about the warnings, since it's pretty
obvious what my intent is when I say scale y*.1, but if you want to be
really correct about it, use scale <1,.1,1> or scale y*.1 +x+z.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3c072bf2@news.povray.org...
> "David Fontaine" <dav### [at] faricynet> wrote in message
> Thanks,
> - Nekar
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
Date: 30 Nov 2001 03:41:41
Message: <3c074645@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3c07373d$1@news.povray.org...
Thanks. I've always wondered about all those warnings...   ;)
- Nekar
Date: 30 Nov 2001 08:41:05
Message: <3c078c70@news.povray.org>
Slime <noo### [at] hotmailcom> wrote:
: y*.1 is equivalent to <0,.1,0>. You can't scale an object by zero in any
: direction - it's like squishing it to zero thickness, and there are
: mathematical reasons why the concept doesn't work (it relates to division by
: zero).
  The exact reason is that POV-Ray doesn't actually transform the object at
all, but it instead transforms the ray with the inverse transformation when
the ray-object intersection is tested.
  The inverse transformation of scale <0, .1, 0> is scale <1/0, 1/.1, 1/0>.
Date: 30 Nov 2001 11:50:10
Message: <3c07b8c2@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3c078c70@news.povray.org...
What are the chances of having this warning removed?
Date: 30 Nov 2001 12:15:50
Message: <9hff0ukmosl6k7thmfmi1nlvsdkkgd9q6v@4ax.com>
On Fri, 30 Nov 2001 16:50:05 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
Personally I prefer when software inform me when he know better what shuld be
passed and change values. But if you don't like it you can check "-GW" ini
switch.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 30 Nov 2001 12:36:52
Message: <3c07c3b4@news.povray.org>
100%. Use the command line setting -gw.
Seriously, I don't want it to be removed. I've encountered lots of cases
where the correction of the 0's to 1's were not desired. For example if I
have a matrix that due to an error scales the object by 0 in one direction.
If not I was warned it would be extremely difficult to find out what's going
on. It also happens often that a while loop or similar that scales an object
smaller and smaller reaches 0 due to a bug in the script, and then the
object is suddenly scaled by 1. I want to be warned about that.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
