POV-Ray : Newsgroups : povray.general : Variable demotion Server Time
16 Jul 2026 21:26:05 EDT (-0400)
  Variable demotion (Message 1 to 4 of 4)
Subject: Variable demotion
Date: 9 Nov 2001 08:52:58
Message: <3BEBDF58.4FC45639@aol.com>
I had a scene where I had lots of complex math (okay, sloppy algebra)
going on across several include files. After making a change, I found
that a vector variable I was using in a scale command was giving an
error about "vector expression expected but color found."  I assume this
means I somehow accidentally turned my 3-dimensional vector into a 4 or
5 dimensional one.  (#debugging seemed to confirm this).   Minutes of
scouring my scene files turned up no specific error.  I ended up
starting over with a backed-up version of the file.
Q: How could I have turned it back?  I want the same variable name, just
altered so that pov will think it's a 3 dimensional vector.
Subject: Re: Variable demotion
Date: 9 Nov 2001 08:58:09
Message: <3bebe0f1@news.povray.org>
You should really see where the problem is and fix that. But anyway, if
you want to convert a color vector to a 3D vector, you can do it this way:
#declare Vec = <Vec.x, Vec.y, Vec.z>;
Date: 9 Nov 2001 09:08:09
Message: <poonutk680etmkr12v230losshep378m0r@4ax.com>
On Fri, 09 Nov 2001 08:51:20 -0500, "Greg M. Johnson"
You want something like this ?
#declare V=<1,2,3,4,5>;
#debug str(vlength(V),0,-1) // create parse error
#declare Temp=V;
#declare V=<V.x,V.y,V.z>;
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 9 Nov 2001 16:26:01
Message: <3BEC4A59.5E02E7E1@hotmail.com>
> just altered so that pov will think it's a 3 dimensional vector.
Find where you accidentally put an extra comma into the vector and
take it out.  That's what usually causes my problems of this nature.
ICQ: 46085459
