POV-Ray : Newsgroups : povray.general : Lens Flares? Server Time
19 Jun 2026 18:23:30 EDT (-0400)
  Lens Flares? (Message 1 to 10 of 35)
Subject: Lens Flares?
Date: 6 Nov 2001 18:45:27
Message: <3BE87585.572DA5DB@scifi-fantasy.com>
Something to toy with using photons, perhaps?
The task: cause a lens flare in a rendering without using a plug-in,
and without using objects to simulate the parts of the flare.
Possibly involves building a lens to put in front of the camera...
Tim Cook
Version: 3.12
Subject: Re: Lens Flares?
Date: 6 Nov 2001 19:30:50
Message: <3be880ba$1@news.povray.org>
Heh heh. Of course, then you'd have to give the lens internal reflection,
and make sure it didn't distort the camera's view... I think you're better
off just using NKFlare.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3BE87585.572DA5DB@scifi-fantasy.com...
> Tim Cook
> http://empyrean.scifi-fantasy.com
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Message: <3be880ba$2@news.povray.org>
You found me out!  A while back I started to try to do this (one of many
projects simmering on the back burner for me).  After a week of searching I
finally found some values for a 35mm camera lens system and started working
on it.  Last week I was playing a bit more with it and finally got the
beginnings of successful 'real' lens flares.  Mind you it is quite a render,
with 5 lenses (10 refracting/reflecting surfaces) you have to set the max
trace level quite high to get anything workable with all those reflections
and refractions (During the latest runs at it I was up to 5000 for
max_trace_level).  More on that in the future when I get more time to play
with it.
-tgq
> Tim Cook
> Version: 3.12
Date: 6 Nov 2001 21:03:00
Message: <3BE89675.20409E7F@pacbell.net>
I seem to recall that Dan Farmer was playing around with this idea like
5-6 years ago :)
Ken Tyler
Date: 7 Nov 2001 01:17:53
Message: <3be8d211@news.povray.org>
Strange, I was thinking of the same thing last week...
- Nekar
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3be880ba$2@news.povray.org...
> with it.
> -tgq
> > Tim Cook
> > Version: 3.12
Version: 6.0.286 / Virus Database: 152 - Release Date: 2001/10/09
Date: 7 Nov 2001 02:43:04
Message: <s9phut41huutiblodjutj1auug9alh07sl@4ax.com>
>5-6 years ago :)
Nah, it can't be done without photons so it can't be that long ago.
However, I think Ron made something like that.
Of course, to simulate the flare perfectly, one needs to introduce
diffraction and interference. *sigh*
Peter Popov ICQ : 15002700
Date: 7 Nov 2001 03:46:36
Message: <3be8f4ec@news.povray.org>
"Peter Popov" <pet### [at] vipbg> wrote in message
news:s9phut41huutiblodjutj1auug9alh07sl@4ax.com...
Something to add to Pov-Ray 4 wishlist!
- Nekar
Date: 7 Nov 2001 06:37:14
Message: <3be91cea@news.povray.org>
Timothy R. Cook <tim### [at] scifi-fantasycom> wrote:
: The task: cause a lens flare in a rendering without using a plug-in,
: and without using objects to simulate the parts of the flare.
  Why? (Except for just the sake of achieving it, even it's extremely slow
and not very useful.)
  It's like making a raytracer with the SDL of POV-Ray. It's slow and not
very useful. It may be fun, but not useful.
  With the include files you get good-looking lensflares of all shapes and
colors easily and it's really fast to render. Not everything has to be
physically correct to look really good.
Date: 7 Nov 2001 06:47:54
Message: <fm7iutcmne52j18edut85r22snvl4ogo5m@4ax.com>
I don't remember content of lens flare include file but does it work correct
with radiosity ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 7 Nov 2001 08:15:58
Message: <slrn9uid0f.gff.ron.parker@fwi.com>
>>5-6 years ago :)
Not that I remember.
But it really doesn't require photons, so it's possible Dan was playing
with it that long ago.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
