POV-Ray : Newsgroups : povray.general : Math / macro programming question Server Time
31 Dec 2025 14:33:36 EST (-0500)
  Math / macro programming question (Message 1 to 4 of 4)
Subject: Math / macro programming question
Date: 18 Oct 2001 05:10:33
Message: <3BCEAA66.8090602@yahoo.fr>
For once, I don't want to re-invent the wheel, so :
I'd like to write a macro to replace a difference of boxes (plain
vanilla box, no transform, not even translate) with a spacially
equivalent union of boxes.
(1) does it already exist ?
if not
(2) there are many possible solutions, how to find an optimal one ? And
what would be optimum speed-wise ? (I guess less boxes, size
irrevelant). I suppose this problem must have been studied already...
Can anybody give me a link ?
TIA
Philippe
Subject: Re: Math / macro programming question
Date: 19 Oct 2001 09:24:10
Message: <3bd0297a@news.povray.org>
Hi philippe, I'm not certain to really understand what you are looking for.
I don't understand why union is better than difference. In this case, as
there are many
coincident surfaces, I would use a merge.
Anyway I wrote this, it seems to work.
Chaps
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.5
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 15, -15>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#macro DiffToUnion (C1,C2,C3,C4)
//C1,C2 are the corner of the "+" box
//C3,C4 are the corner of the"-" box
#local UP1 = max(C1.y,C2.y);
#local BOT1 = min(C1.y,C2.y);
#local LEFT1 = min(C1.x,C2.x);
#local RIGHT1 = max(C1.x,C2.x);
#local FRONT1 = min(C1.z,C2.z);
#local REAR1 = max(C1.z,C2.z);
#local UP2 = max(C3.y,C4.y);
#local BOT2 = min(C3.y,C4.y);
#local LEFT2 = min(C3.x,C4.x);
#local RIGHT2 = max(C3.x,C4.x);
#local FRONT2 = min(C3.z,C4.z);
#local REAR2 = max(C3.z,C4.z);
#local NewObj = union {
 // is there a Top
 #if (UP1 > UP2)
  box { <LEFT1,UP1,FRONT1>,<RIGHT1,UP2,REAR1>}
 // is there a bottom
 #if (BOT1 < BOT2)
  box { <LEFT1,BOT2,FRONT1>,<RIGHT1,BOT1,REAR1>}
 // is there a right
 #if (RIGHT1 > RIGHT2)
  box { <RIGHT2,UP1,FRONT1>,<RIGHT1,BOT1,REAR1>}
 #if (LEFT1 < LEFT2)
  box { <LEFT1,UP1,FRONT1>,<LEFT2,BOT1,REAR1>}
 // is there a rear
 #if (REAR1 > REAR2)
  box { <LEFT1,UP1,REAR2>,<RIGHT1,BOT1,REAR1>}
 // is there a front
 #if (FRONT1 < FRONT2)
  box { <LEFT1,UP1,FRONT1>,<RIGHT1,BOT1,FRONT2>}
object { NewObj}
#declare A1 = <-2,2,2>;
#declare A2 = <2,-2,-2>;
#declare A3 = <-1,-1,-3>;
#declare A4 = <1,1,3>;
difference {
        box { A1,A2 }
        box { A3,A4 }
        pigment { color Blue }
        translate -4*x
object {
        DiffToUnion(A1,A2,A3,A4)
        pigment { color Red }
        translate 4*x
"Philippe Debar" <phd### [at] yahoofr> wrote in message
news:3BC### [at] yahoofr...
> if not
> TIA
> Philippe
Date: 21 Oct 2001 19:03:37
Message: <3bd35449@news.povray.org>
"Chaps" <cha### [at] yahoocom> wrote in message
news:3bd0297a@news.povray.org...
for.
> there are many
Speed.
Coincident surfaces are a problem indeed. I still do not knwo how I will
solve that.
Thanks.
I was actually thinking about something more general. I am working (slowly)
on an explanatory example...
Povingly,
Philippe
Date: 23 Oct 2001 20:59:55
Message: <3bd6128b$1@news.povray.org>
Example file in p.b.s-f
Philippe
