![](/i/fill.gif) |
I am rendering one instance of this object, nothiung else and it's taking
5 mins. But other (lathe) objects take around 1 min under teh same
lighting conditions, and same texture...
#local Scol = difference
#local Count=0;
#while (Count < 50)
object
torus {6.3,1.2}
translate <0,0.1 * Count,0>
#local Count=Count+1;
box {<-10,-10,-10>,<10,10,0>}
texture
Cowling
Rob Brown-Bayliss
---======o======---
![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3BBA73DF.9E8759E3@pacbell.net>, "Ken" <tyl### [at] pacbell net>
wrote:
>> taking 5 mins. But other (lathe) objects take around 1 min under teh
>> same lighting conditions, and same texture...
>> #local Count=0;
>> #while (Count < 50)
> You are differencing 50 torus objects from each other. Reduce that
> number to 2 and it will render considerably faster. Considering what you
> were doing 5 min. is not at all out of line.
huh, Idiot, I ment to to a union... Bummbr, I have since changed my
design to this:
#local Outer = difference
intersection
sphere {<0, 0, 0>, 8.3}
box {<0,-3,-1>,<10,3,5>}
sphere {<0, 0, 0>, 6.3}
difference
object {Outer}
difference
intersection
sphere {<0, 0, 0>, 8.2}
box {<0,-2.9,-1.5>,<10,2.9,5>}
sphere {<0, 0, 0>, 6.4}
Rob Brown-Bayliss
---======o======---
![](/i/fill.gif) |
![](/i/fill.gif) |
> intersection
> difference
> object {Outer}
> difference
> intersection
union{
intersection{
sphere {<0, 0, 0>, 8.2 inverse}
intersection{
sphere {<0, 0, 0>, 6.3 inverse}
intersection{
box {<0,2.9,-1.5>,<10,3,5>}
intersection{
box {<0,-2.9,-1.5>,<10,-3,5>}
works a little bit faster when you have automatic bounding turned on.
- Micha
![](/i/fill.gif) |
