POV-Ray : Newsgroups : povray.general : Mesh: merging nodes and unifying normals Server Time
10 Sep 2025 17:31:12 EDT (-0400)
  Mesh: merging nodes and unifying normals (Message 1 to 2 of 2)
Subject: Mesh: merging nodes and unifying normals
Date: 1 Jun 2001 01:30:03
Message: <3B1728DA.D221BC0C@yahoo.com>
Hy,
I have large meshes with single nodes at the triangles. Now I want to
merge identical nodes in order to generate smooth triangles. Do you know
know a fast (!) algorithm for this and do you know in addition a fast
(!) algorithm for unifying the normals in direction ("inside/outside") ?
Thanks
Subject: Re: Mesh: merging nodes and unifying normals
Date: 1 Jun 2001 07:43:19
Message: <3b177fd7@news.povray.org>
chris <chr### [at] yahoocom> wrote:
: I have large meshes with single nodes at the triangles. Now I want to
: merge identical nodes in order to generate smooth triangles. Do you know
: know a fast (!) algorithm for this and do you know in addition a fast
: (!) algorithm for unifying the normals in direction ("inside/outside") ?
  I think my triangle mesh smoother does exactly that. It's not the fastest
possible, but the algorithm should be well documented.
http://iki.fi/warp/PovUtils/smooth.html
