POV-Ray : Newsgroups : povray.general : Matrix and angles Server Time
29 Nov 2026 23:23:22 EST (-0500)
  Matrix and angles (Message 1 to 3 of 3)
Subject: Matrix and angles
Date: 1 May 2001 13:37:07
Message: <3AEEF370.15166208@skynet.be>
I'm doing this :
box {<-10,0,-7>,<10,7,7>
     matrix <  1, -.5, 0,
               0,  1,  0,
               0,  0,  1,
               0,  0,  0 >
..which shears the box so the top is no more parallel to the ground
plane.  However, I have a problem determining at which angle it is now !
I would have tought that this gives a 30 degrees angle (arcsinus 0.5),
but placing a 30-degrees rotated object on top of the box proves it
wrong !  How do I calculate the exact angle ?
Fabien.
Subject: Re: Matrix and angles
Date: 1 May 2001 13:48:03
Message: <3AEEF4D5.5D4BF9B2@spiritone.com>
Fabien Mosen wrote:
> I'm doing this :
>      matrix <  1, -.5, 0,
>                0,  1,  0,
>                0,  0,  1,
>                0,  0,  0 >
> Fabien.
It's not arcsin, but arctangent. If you rotate another object by
degrees(atan2(-0.5,1))*z you will get the right angle.
Josh English
eng### [at] spiritonecom
Date: 1 May 2001 15:19:51
Message: <3AEF0B84.A479274B@skynet.be>
Ooops ! Right !  Why did I use sinus ?  Now that I think about
it, I know that I pictured (in my mind) the trigonometric circle
with the tangent drawn in dots.
Fabien.
 ..slapping myself..
