POV-Ray : Newsgroups : povray.general : pov3.0 halo - anybody remembers? Server Time
20 Jun 2026 15:35:52 EDT (-0400)
  pov3.0 halo - anybody remembers? (Message 1 to 5 of 5)
Subject: pov3.0 halo - anybody remembers?
Date: 26 Jan 2001 15:32:50
Message: <3A71DED3.8CFCD3B1@gmx.net>
I want to render an old scene I had written for pov 3.1. Because I want to change
some things and use 3.1 features I need to convert the halo to a media.
The old scene has following code:
halo {
    emitting
    spherical_mapping
    linear
    lambda 2
    turbulence <0.3,1,0.3>*1.2
    color_map {
      [ 0.0 color rgbt<1,0,0,1>]
      [ .5 color rgbt<1.75,1,0,0>]
      [ 1.0 color rgbt<2,2,0,-1>]
    jitter 0.1
    frequency 1
    samples 20
    scale 0.4
My problem is that I don't remember what kind of pattern the two lines
spherical_mapping
linear
mean. Unfortunatley I have no more 3.0 docs. Does anybody of you remember the
meaning of this and know how to translate that to a density_map?
- Micha
Subject: Re: pov3.0 halo - anybody remembers?
Date: 26 Jan 2001 16:01:20
Message: <chrishuff-BF7307.16020926012001@news.povray.org>
In article <3A71DED3.8CFCD3B1@gmx.net>, Micha Riser <mri### [at] gmxnet>
> spherical_mapping
> linear
> remember the meaning of this and know how to translate that to a
> density_map?
Well, I would start with the "spherical" pattern... ;-)
An attempt at translating is below. (Note: I never did much with halo,
and have no way to check to see how similar the media is, so this is
just a guideline for the syntax.)
media {
    emission color White
    method 3// Use this if using MegaPOV, if not,
            // remove this and use more intervals.
    intervals 1// using 2 or 3 may help, I almost always use 1, but
               // the official version requires much more.
    samples 20, 20
    density {spherical// ramp_wave and frequency 1 are default
        turbulence <0.3,1,0.3>*1.2 lambda 2
        scale 0.4
        color_map {// media ignores transmit and filter and uses the
                   // brightness of the color to determine density
                   // use the color for "emission" to specify the overall
                   // density
            [0.0 color rgb < 0, 0, 0>]
            [0.5 color rgb < 1.75, 1, 0>]
            [1.0 color rgb <-2,-2, 0>]// I don't know what was intended
                                      // with the negative transmit...
Christopher James Huff
Date: 27 Jan 2001 11:37:17
Message: <3A72F93D.83FBF593@gmx.net>
Thank you Chris! This gave the same pattern as with the halos. I just had to play
a little around with the color strengths in the color_map and now it looks nearly
the same.
- Micha
Date: 27 Jan 2001 12:41:21
Message: <3A730841.432BCFFB@gmx.net>
Here's another one where I have big problems converting it:
 halo{
    emitting
    planar_mapping
    poly
    exponent 2.5
    omega 1.07
    lambda 1.6
    turbulence <6,1,6>
    color_map{
     [0 color  rgbt<0.5,0,0,1>]
     [.5 color rgbt<1.75,1,0,0>*0.5]
     [1 color rgbt<2,2,0,0>*0.4]
    translate<5,0,0>
    scale <1,0.7,1>
    samples 20
Any help is appreciated.
- Micha
Date: 27 Jan 2001 13:28:17
Message: <chrishuff-AB3FDD.13290827012001@news.povray.org>
In article <3A730841.432BCFFB@gmx.net>, Micha Riser <mri### [at] gmxnet>
>  halo{
>     emitting
>     planar_mapping
>     poly
>     exponent 2.5
Try "planar poly_wave 2.5" as the pattern. The other changes should be
similar to your previous example...put pattern and color_map stuff in a
density {} block, remove filter/transmit values and adjust color_map,
etc...
