POV-Ray : Newsgroups : povray.general : Could not create image buffer? Server Time
28 Nov 2025 20:13:06 EST (-0500)
  Could not create image buffer? (Message 1 to 10 of 23)
Subject: Could not create image buffer?
Date: 1 Dec 2000 15:54:03
Message: <3A280FEA.E7FCB538@mac.com>
I was putting decals on my fighter's fuselage.  Anyone who has ever
built a model airplane knows that there are several markings in the
cockpit area, and I was using layers of mostly transparent pigments,
derived from Josh English's bottle labeling code.
Two layers were okay, but when I added the third, I got this message
when I tried to render:
Creating vista buffer.
Creating light buffers....
Displaying...
File init error.
Could not create image buffer. (Error: -108)
Reclaiming memory
-- [Stack] Total Stack space used = 5296 bytes
-- [Finish]  File=fusilage.pov,  Time=1/12/00  1:46:00 PM
What does this mean?  What am I doing wrong?  Is there a limit to the
number of transparent layers you can put on an object?
Dawn McKnight      | "Who cares what the hipbone's connected to? I'm in Neurology!"
McK### [at] maccom   |					-- Justine Devlin, M.D.
Subject: Re: Could not create image buffer?
Date: 1 Dec 2000 16:10:15
Message: <3A2813B4.4E277C2E@spiritone.com>
If I remember, you are using a Mac, right? If so, the image may be open by another
application. I also noted in some versions, that if you render to a PICT file, even if
the file is closed, POV-Ray won't let you write over the file, citing a similar error.
Josh
> Displaying...
> File init error.
> Reclaiming memory
eng### [at] spiritonecom
Date: 1 Dec 2000 19:26:58
Message: <3a2841d2$1@news.povray.org>
In article <3A280FEA.E7FCB538@mac.com> , Dawn McKnight <mck### [at] maccom>
You are out of memory.  Turning of preview will help you reduce needs for
memory.  If you had read the documentation, you would know that the what the
image buffer is and that it has nothing do do with your scene directly.
     Thorsten
PS: POV-Ray Mac issues best fit in the "povray.macintosh" newsgroup.  If you
don't want to post there (I can't think of a reason), at least let other
people know which platform you are using...
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 1 Dec 2000 20:55:58
Message: <chrishuff-73A2A7.20563601122000@news.povray.org>
In article <3a2841d2$1@news.povray.org>, "Thorsten Froehlich"
> for memory.  If you had read the documentation, you would know that
> the what the image buffer is and that it has nothing do do with your
> scene directly.
I have also had this file init error when running two copies of POV-Ray
at once.
Christopher James Huff
Date: 1 Dec 2000 21:03:36
Message: <3a285878$1@news.povray.org>
In article <chrishuff-73A2A7.20563601122000@news.povray.org> , Chris Huff
> at once.
This most likely is not a file init error. It says error code -108, go and
look it up ;-)
    Thorsten
Thorsten Froehlich
Date: 1 Dec 2000 22:31:19
Message: <3A286D04.A7BD3287@mac.com>
I beg your pardon, sir.  I have read the documentation fairly
thoroughly; I do not recall seeing a listing of cryptic error codes such
as -108 listed anywhere in it.  If you would be kind enough to point out
to me where that is, I shall refrain from bothering you in the future.
Again, I beg your pardon.  I did not realize this was a macintosh
specific question; I believed it to be generated by POV's renderer, and
thus, to be a platform independent question.  Add to that the fact that
p.macintosh is used /very/ sparsely, and perhaps you will perceive my
reluctance to post this question there.
However, I realize that you are a busy person, and I therefore excuse
you from reading any further posts from me, as no doubt, they will turn
out to be horrendous wastes of your time, just as this one was.
Date: 1 Dec 2000 23:41:50
Message: <3a287d8e@news.povray.org>
In article <3A286D04.A7BD3287@mac.com> , Dawn McKnight <mck### [at] maccom>
> thoroughly;
Unfortunately I cannot grand your request for a full pardon.  Let me quote
the POV-Ray Mac documentation, page 26:
Output Image Memory
POV-Ray tries to store the output Preview image entirely in application RAM
memory while rendering.  Because the image requires approximately Width x
Height x 4 bytes of memory, sometimes this is not possible.  For example, a
640 x 480 pixel image needs about 1.25 megabytes of RAM.  When POV-Ray
finds that it can not hold the image in RAM, it will start saving parts of
it in a temporary disk file, and swap it in to a smaller RAM buffer in
rectangular chunks.  This lets you create very large images with limited
RAM, at the cost of slower rendering time and more disk I/O.  This is
referred to in POV-Ray Mac as the "Image Buffer" or IB.  To avoid increased
wear and tear on your hard disk, and to speed up rendering times on large
images, you can allocate more application memory to POV-Ray, to reduce the
use of the Image Buffer disk swapping. If you do not have enough memory in
your Mac and the IB is used heavily, you can speed things up a lot and
reduce RAM and disk space usage a lot by turning off the Preview Window when
it renders.  You can do this by opening the Render Settings dialog, and
going to the Preview pane, and turning  off "Show Preview."
As the error message you cite clearly states "Could not create image
buffer.", you obviously never read the documentation, or looked in the
Render Preferences dialog Preview pane where you find a "Image buffer cache
size" slider.
Thus, I stand to my earlier "RTFM".
You can download the whole list here:
<http://developer.apple.com/techpubs/macos8/ResultCodeTable/ResultCodes.pdf>
Further, you may have noticed that I did not refer to "(Error: -108)", which
is just a hint for me in case of a real problems to find out where exactly
the error is happening if I cannot reproduce it on my system.
In your case there are actually two errors because you are out of memory.
First the "File init error." which simply says that the internal buffer for
the output image file and thus the file itself could not be created. Second
the display image buffer, which requires a lot of memory as well, cannot be
created.
Thus, I stand to my earlier "RTFM", or maybe even "RTFD" (D for Dialog box).
And maybe the - 20 or so? - clear explanations in the documentation how lack
of memory assigned to POV-Ray will cause complex scenes to fail to render
were not enough?  RTFM!!!
Yes, because it is for Mac issues, not general discussion!  If you do not
post Mac issues there (through people have always received helpful responses
there, haven't they?), how are there going to be any responses there?
I assumed you have been to these groups long enough to have read
povray.announce.frequently-asked-questions "Welcome To the POV-Ray News
Groups".  In case you have not (which seems to be the case), I strongly
suggest to read all the messages in that group - it also explains why it
helps if you let people know the platform you are running POV-Ray on...
Thank you for being so generous!  After all, all the team did was develop,
compile, debug and distribute it to you for free, in our spare time - so we
really appreciate user feedback like yours, it motivates us every day to
spend our free time and continue our development.
    Thorsten
Thorsten Froehlich
Date: 2 Dec 2000 06:23:41
Message: <3A28DB9B.4F10A3A1@onwijs.com>
Gee, what a friendly forum this has become!
The way I read the message I would have assumed that the problem was in the
scenefile but then again, I did read the documentation (for 3.0 that is) but I
didn't memorize it.
I've had similar problems with scenes on my Windows-system but I admit I don't
recall the exact error-message. Most of the time I tried closing some other
applications (mostly POV-Ray too) and rerendering the scene, which seemed to
help.
Kind regards,
Remco
Date: 2 Dec 2000 14:23:45
Message: <3A294D87.F5DE990C@unforgettable.com>
You appear to be speaking for the team. Is that correct?
-Xplo
Date: 2 Dec 2000 16:56:27
Message: <3a29700b$1@news.povray.org>
In article <3A294D87.F5DE990C@unforgettable.com> , Xplo Eristotle
I am pointing out that we as a team developed it, and that user "feedback"
like this is very de-motivating, which is a thought shared by the team.
Nevertheless, this is only a summary of general thoughts and I speak for
myself, so this is of course as usual no official POV-Team statement.
Oh, and as you have already noticed, only the last paragraph refers to the
team, everything preceding it is only my personal statement.
    Thorsten
Thorsten Froehlich
