POV-Ray : Newsgroups : povray.general : Plane equitation Server Time
31 Dec 2025 12:21:37 EST (-0500)
  Plane equitation (Message 1 to 8 of 8)
Subject: Plane equitation
Date: 28 Nov 2000 11:39:47
Message: <3A254D86.8080805@home.nl>
I was reading the manual about planes, and I saw that povray uses the
equitation: A*x + B*y + C*z = D*sqrt(sqr(A) + sqr(B) + sqr(C))
Now I was wondering, why that sqrt(sqr(A) + sqr(B) + sqr(C))? Isn't it
enough to have A*x + B*y + C*z = D?
Remco Poelstra
Subject: Re: Plane equitation
Date: 28 Nov 2000 13:39:05
Message: <3a23fbc9$1@news.povray.org>
hello,
they both describe plane but the one used in pov-ray allows to describe the
*real* distance from the origin to the plane with the 'D' value, while in
the other it describes the distance from origin to where the plane cut axis
Baillp
ps : you should say "equation" not "equitation" ;)
3A2### [at] homenl...
> Hi,
> Remco Poelstra
Date: 28 Nov 2000 13:47:44
Message: <3A23FDCC.1C2252B5@spiritone.com>
Normally you wouldn't need it, but POV-Ray describes a plane a bit
differently and normal geometry would. In POV-Ray, D is the minimum
distance from the origin to the plane. It is envsioned by going D units
along the normal vector of the plane <A,B,C> and putting the plane there
In normal mathematical circumstance, D is not the mininum distance from
the origin to the plane, it has a different meaning.
For instance, mathematically, if you have a plane with normal vector
<1,1,2> and it goes through point <2,1,3>, it satisfies the equation 1*2 +
1*1 + 2*3 = D, so D= 9.
In POV-Ray, the same plane would have the same normal vector, but the
disatance from the plane is less than 9.
Josh
Remco Poelstra wrote:
> Hi,
> Remco Poelstra
eng### [at] spiritonecom
Date: 28 Nov 2000 14:43:39
Message: <3A240B2C.197A2B45@freenet.de>
...and I already have thought, it has something to do with horses (from
equus (lat.) = horse).
ReVerSi
Date: 28 Nov 2000 15:38:43
Message: <3A258585.5030900@home.nl>
Thanks both!
Where I need this information for, is a little program I'm writing,
which does some calculations at points/planes. I want to calculate the
distance of a point to a plain, with :
abs(A*x+B*y+C*z-D)/sqrt(sqr(A)+sqr(B)+sqr(C)). I use that distance for
some things and want the result being displayed by povray, but when
povray uses another equation, the graphic would be false. How do I have
to calculate the distance in my program, so that my calculations are
correct with what povray displays?
Date: 28 Nov 2000 19:52:58
Message: <3a24536a@news.povray.org>
abs((A*x+B*y+C*z)/sqrt(sqr(A)+sqr(B)+sqr(C))-D)
will do the job
Baillp
> Thanks both!
Date: 29 Nov 2000 09:23:23
Message: <3A267F0F.2070308@home.nl>
> will do the job
Ok, thanks!
Remco
Date: 29 Nov 2000 10:53:38
Message: <3A252682.39DA686B@spiritone.com>
Thank you, I was thinking this, but I didn't have a chance to answer last
night.
Josh
> will do the job
> Baillp
> > Thanks both!
