POV-Ray : Newsgroups : povray.general : Media Server Time
25 Apr 2026 06:20:34 EDT (-0400)
  Media (Message 1 to 4 of 4)
Subject: Media
Date: 16 Nov 2000 22:16:05
Message: <3A14A2F2.7A599C3E@flash.net>
I'm working on my annual Christmas card, and I'm trying to use media to
simulate a string of Christmas lights.  It looks pretty good so far, but
two questions have arisen:
1)  Are the media effects dependent on the scale of the container?  For
example, if my light bulb is contained by a 5 inch or a 50 inch sphere,
should I expect different results?
2)  Can I have more than one media container in a scene?  I have tried
to surround each bulb with its own container (a sphere),  but it seems
that only one of the containers works.  The rest don't do anything.
Any thoughts?
Thanks,
Eric
Subject: Re: Media
Date: 16 Nov 2000 23:17:48
Message: <3A14B1A5.12CE70D3@peak.edu.ee>
Media density (per unit of volume) remains constant no matter how you scale the
container. This means the same media in a smaller container will look more
transparent, because there is less media to "see through".
If you want the transparency of the media to appear the same after scaling, you
can do this: let's say Si is the initial scale of your media(container), Sf is
the final scale, and D is the initial density. The new density for the scaled
media is:
(pow((Si.x * Si.y * Si.z) / (Sf.x * Sf.y * Sf.z), 1/3) * D)
Of course you can have multiple containers. Are you sure you did it right? All
containers need to be hollow, and they all must have a media attached. Here's a
simple example, with two media containers:
sphere{
  <-1,0,0>,1
  pigment{rgbf 1}
  interior{media{emission 1}}
  hollow
sphere{
  <1,0,0>,1
  pigment{rgbf 1}
  hollow
Margus Ramst
Subject: Re: Media
Date: 16 Nov 2000 23:30:11
Message: <3A14B454.8E7E0775@flash.net>
Thanks.  I appreciate the input!
> media is:
> sphere{
>   <-1,0,0>,1
>   pigment{rgbf 1}
>   hollow
> sphere{
>   <1,0,0>,1
>   pigment{rgbf 1}
>   hollow
> Margus Ramst
> Personal e-mail: mar### [at] peakeduee
> TAG (Team Assistance Group) e-mail: mar### [at] tagpovrayorg
Subject: Re: Media
Date: 17 Nov 2000 21:22:04
Message: <chrishuff-61EFBB.21222117112000@news.povray.org>
> to simulate a string of Christmas lights.
Hmm, are you using MegaPOV? If so, you might want to check out the glow
patch. It might be a good alternative to media for this.
Yes. The appearance of media is determined by the distance you see
through it. If you scale something up by 2, everything will appear twice
as bright, shadows cast by scattering or absorbing media will be twice
as dark, etc. because there is twice as much media between any two
points.
You can have as many containers as you want, they are just ordinary
objects. Are you making sure that all the containers have "hollow"
specified and are not in any non-hollow objects?
Christopher James Huff
