POV-Ray : Newsgroups : povray.general : Correct model? Server Time
12 Sep 2025 05:32:54 EDT (-0400)
  Correct model? (Message 1 to 6 of 6)
Subject: Correct model?
Date: 24 Aug 2000 18:04:51
Message: <39a59c03@news.povray.org>
Does Povray offer the correct model of light, intersecting a transparent
surface, where it divides into one refracted beam and one reflected beam,
whose strenght are varied depending on the incoming angle?
If this is an available feature, how do I set "correct" values? ie.
realworld values for different materials.
/R
Subject: Re: Correct model?
Date: 24 Aug 2000 18:25:05
Message: <chrishuff-0CD763.17263024082000@news.povray.org>
In article <39a59c03@news.povray.org>, "ZeroBlue" <zer### [at] swipnetse>
It depends on what you mean by "correct"...there is no such thing as a
perfect simulation of light. POV does not simulate polarization,
interference, diffraction, etc. When it hits an object which is partly
transparent and partly reflective, it traces a reflective ray and a
refracted ray, whose directions and intensities depend on the
characteristics of the texture at the intersection point.
If you are asking about angle-dependant reflection: standard POV does
not support this (yet), but MegaPOV, an unofficial version, does include
it. MegaPOV is available here: http://nathan.kopp.com/patched.htm
The documentation covers this feature, you should read it for an
explanation of the new reflection features.
POV-Ray 3.5 (which should be released sometime this year) will support
many of the new MegaPOV features, possibly including angle-dependant
reflection.
Christopher James Huff
Date: 25 Aug 2000 00:03:49
Message: <39A5F03A.2F1C4E74@hotmail.com>
You seem to be talking about forwards ray-tracing where rays act just like
streams of photons.
POV-Ray does reverse/backwards ray-tracing where since you are only
interested in light that hits the camera you trace the path of light hitting
the cameras back to its origin so that you may determine the colour of the
ray as it hits the camera.
Bye
Pabs
Date: 25 Aug 2000 07:30:04
Message: <39A65890.4D3CFAC4@kyrre.net>
reflection_type 1 in MegaPov does this (if I understand you correctly) An
incoming ray will then be reflected if its incident angle is steep enough,
determined by the material's IOR.
sig
ICQ 74734588
Date: 25 Aug 2000 07:46:02
Message: <39A65C4E.EA94C418@kyrre.net>
Eh, the opposite of steep of course :) (Narrow? Shallow?)
ICQ 74734588
Date: 25 Aug 2000 10:57:51
Message: <chrishuff-87510A.09591825082000@news.povray.org>
In article <39A5F03A.2F1C4E74@hotmail.com>, Pabs <pab### [at] hotmailcom>
> like streams of photons.
> hitting the cameras back to its origin so that you may determine the
> colour of the ray as it hits the camera.
However, there is a POV-Ray patch by Nathan Kopp which does photon
mapping, which is a sort of forward ray tracing: some of the
illumination is calculated by tracing photons through the scene from the
light sources, so it can do refractive and reflective caustics, but
rendering the actual scene is done as it is now. This patch is available
in MegaPOV: http://nathan.kopp.com/patched.htm
There are a couple small bugs(cylinder lights don't work as expected,
for example), but it works very well and is reasonably fast.
