POV-Ray : Newsgroups : povray.general : Architexture working? Server Time
25 Apr 2026 10:01:00 EDT (-0400)
  Architexture working? (Message 1 to 8 of 8)
Subject: Architexture working?
Date: 13 Oct 2000 12:51:24
Message: <39E73D9E.36E1D60@alleganisd.org>
Has anyone gotten Architexture to work?
http://www.sourceforge.net/projects/ute
See my Free stuff page. It compares free website providers, and
lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
Subject: Re: Architexture working?
Date: 13 Oct 2000 14:50:40
Message: <39E758AD.4C212597@psu.edu>
Nope, not yet.... I still can't preview....
-paul
> code and hints.
Paul Daniel Jones
The Pennslyvania State University
pdj### [at] psuedu
http://research.chem.psu.edu/glassgrp/paul
       C            The way is near, but men
     // \           seek it afar. It is in the
    N    N          easy things, but men seek it
    |    ||         in the difficult things.
    C    C          -Menicius
       C
Date: 13 Oct 2000 14:58:00
Message: <39E75743.17AEAFD8@global2000.net>
I can't see all of the buttons in 800x600.
Brendan
> code and hints.
Date: 13 Oct 2000 15:42:35
Message: <39e765ab@news.povray.org>
Can't get preview most else seems to work.
Mick
"Chuck Roberts" <cro### [at] alleganisdorg> wrote in message
news:39E### [at] alleganisdorg...
> code and hints.
Date: 13 Oct 2000 17:19:36
Message: <39e77c68$1@news.povray.org>
Sorry Chuck,
I tried while I was in Haiti to no avail. I was going to write you about it
tonight, but since you asked....
I do get the App to start up, but that is were it ends. I have not been able
to generate even basic colors. I get an error. I'll have let you know what
it is later.
C.J. - POV User
Chuck Roberts <cro### [at] alleganisdorg> wrote in message
> code and hints.
Date: 14 Oct 2000 08:27:59
Message: <39e8514f$1@news.povray.org>
Nope....
1st, prefs, POV Location is set.
Simple test.  Open program, click on Texture, Add new Texture, key in a name
in the Texture box.
Attempted save as and received message "mnuSaveAs: 76 Path not found"
appears it did save it tho.  Open appears to open the saved object as well.
Can't move the slides for custom colors.  Nothing happens there.
Can click on pre-defined colors and select those.
Click on Refresh Preview button, nothing happens.  Noted in doc that POV
must be started by hand.  Did this and received message "cmdPreview: 53 File
not found".
Texture transforms appears to work, saves and clears
Clear picture does nothing, no picture to clear.
You can select the object types Sphere, Plane, Box, Cone, Cylinder
Transform button is same as transform above.
Turbulance button, gives a screen, appears to work.
Pattern button gives a new window, unsure what you want entered in the
fields????  Slide works here, gives me up to 5 fields under a set of
protected fields that are gray in color ???
Select delete texture, prompted, "Are you sure you want to delete this?",
say OK, message is: "mnuTexDelete: 5 Invalid procedure call"
Need I go on?
Robert J Becraft
aka cas### [at] aolcom
> code and hints.
Date: 16 Oct 2000 02:40:44
Message: <39eaa2ec@news.povray.org>
I've got it working on a Win 95 machine but the interface does
not appear to be designed for 800*600 so I haven't played much with it.
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 20 Oct 2000 15:21:53
Message: <39F09B6B.1060600@worldshare.net>
Try downloading the newest version. I think I fixed the preview.
