POV-Ray : Newsgroups : povray.general : POV referenced needed Server Time
15 Jan 2026 12:11:12 EST (-0500)
  POV referenced needed (Message 1 to 7 of 7)
Subject: POV referenced needed
Date: 11 Sep 2000 15:20:18
Message: <39BD305A.FA070C58@alleganisd.org>
I was just thinking that a POV reference would be very helpful.
Specifically, it should list all the parameters and commands in
the POV language, and what the minimum and maximum values are for
each command parameter. It would also list the data type for each
parameter. Ex: turbulence is a float from 0.0 to 1.0. This would
help developers when they are making software to use with POV.
For example, do you need to specify turbulence in order to change
frequency? Turbulence range: 0.0-1.0.
I got some numbers from the existing POV help file but many
numbers are still sketchy. Some commands have no upper limit. But
when you reach a certain max, does the command have any effect?
See my Free stuff page. It compares free website providers, and
lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
Subject: Re: POV referenced needed
Date: 11 Sep 2000 16:02:54
Message: <39BD3A74.227CF8DB@spiritone.com>
A quick test with two spheres, one with ambient 1 and the other with
ambient 10, don't appear to be different, but they would affect
radiosity differently.
I don't know of any index that has all of this information, though.
Josh
> code and hints.
eng### [at] spiritonecom
Date: 11 Sep 2000 16:06:21
Message: <39bd3b3d@news.povray.org>
Well, it's already in the documentation, just scattered around a little...
A compact reference might be useful...
No, it is a vector, and each vector component can be any value, negative
values included.
This: turbulence 0.6
Is a shorthand for this: turbulence <0.6, 0.6, 0.6>
This is also a valid turbulence vector: turbulence <11.4, 0, -3>
> to change frequency?
No. Generally commands are not dependent on each other if it is not
mentioned in the documentation. If they had to mention everything that is
*not* dependent on each other, there would be no end to it!
Not true.
There are really many of the command that have no limits at all. Probably
more than you think (judging from what you said about turbulence).
Greetings,
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated July 23)
/ Also visit http://www.povrayusers.org
Date: 11 Sep 2000 23:04:32
Message: <39bd9d40$1@news.povray.org>
Actually, exploration of unspecified parameter values has been a source for
a number of images in p.b.i
Jim
"Rune" <run### [at] inamecom> wrote in message
news:39bd3b3d@news.povray.org...
> values included.
> Not true.
> Greetings,
> Rune
Date: 12 Sep 2000 01:00:09
Message: <39bdb859$1@news.povray.org>
Chuck Roberts wrote in message <39BD305A.FA070C58@alleganisd.org>...
Most parameters have no limits.  Those that do have limits, the limits are
almost always mentioned in the help file.
Mark
Date: 12 Sep 2000 11:07:22
Message: <39BE4697.B37DC8BE@alleganisd.org>
Thanks. Your comments are what I was looking for. I think I will
make a compact reference and post it here for review.
> values included.
> Not true.
> Greetings,
> Rune
code and hints.
Date: 21 Sep 2000 23:08:12
Message: <39cacd1c@news.povray.org>
"Chuck Roberts" <cro### [at] alleganisdorg> wrote in message
news:39BD305A.FA070C58@alleganisd.org...
Now I have a web site.  Just a simple home page to start with.  My quick
reference document may be found via a link at
http://www.donovansweb.com/~chaffe
Thinking of adding the "default values" to the reference as well.  Might
also be useful.
Enjoy!
rc
