POV-Ray : Newsgroups : povray.general : Re: explanation of a blob bug Server Time
21 Jun 2026 05:06:19 EDT (-0400)
  Re: explanation of a blob bug (Message 1 to 8 of 8)
Subject: Re: explanation of a blob bug
Date: 7 Sep 2000 21:13:04
Message: <39B83BD7.105FFC75@online.no>
"J. Grimbert" wrote:
> Someone recently post an image with an image with two broken blobs
> (I'm unable to see the thread).
> I think I have found the origin of the bug.
> In get_element_bounding_sphere from blob.c, if an element has
> any transformation, the bounding sphere is also transformed.
> ... 8< ...Snip !
> The bug nature is odd:
> With only rotate, it is ok
> With only scale (uniform or not), it is ok
> With a mix of uniform scale and rotate, it is ok
> With a mix of non-uniform scale and rotate, it MAY be ok or NOT, according to
> the parameters
> (mainly of the transformations)
Thank you very much Grimbert for looking into
this problem.
I too found that the defects appeared when doing
some combinations of non uniform scaling and
rotations.
(This problem has been BUGGING me some time now)
And to any programming TAG members (E.g. Chris ?):
Should this problem be discussed further in
poray.general or can this now be considered to
be a bug ?
Tor Olav
mailto:tor### [at] hotmailcom
Date: 7 Sep 2000 21:23:41
Message: <39B83E5C.EC65AB0D@online.no>
Tor Olav Kristensen wrote:
> > ... 8< ...Snip !
> be a bug ?
I'm not sure why this message ended up in povray.general
(I only replied to J. Grimbert's post in povray.binaries.images.)
Is this because of a "follow-up" setting that Grimbert applied
to his message ?
If so: How can that be done in Netscape ?
Tor Olav
Date: 8 Sep 2000 03:28:25
Message: <39B8952C.65D9A48B@atos-group.com>
> > the parameters
> this problem.
> rotations.
> be a bug ?
I am not a TAG member, but hereafter is my bugfix
but we need a consensus before being allowed to post in bug-report.
--- blob.c.old  Thu Sep  7 18:41:28 2000
+++ blob.c      Thu Sep  7 18:44:55 2000
@@ -2468,7 +2468,8 @@
 static void get_element_bounding_sphere(BLOB_ELEMENT *Element, VECTOR Center,
DBL *Radius2)
   DBL r, r2 = 0.0;
-  VECTOR C, H;
+  VECTOR C;
+  BBOX local_BBox;
   switch (Element->Type)
@@ -2514,12 +2515,10 @@
     MTransPoint(C, C, Element->Trans);
-    Make_Vector(H, r, r, r);
-    MTransDirection(H, H, Element->Trans);
-    r = max(max(fabs(H[X]), fabs(H[Y])), fabs(H[Z]));
+    Make_BBox(local_BBox ,0,0,0,r,r,r);
+    Recompute_BBox(&local_BBox, Element->Trans);
+    r= max(max(fabs(local_BBox.Lengths[X]),fabs(local_BBox.Lengths[Y])),
+               fabs(local_BBox.Lengths[Z]));
     r2 = Sqr(r) + EPSILON;
Date: 8 Sep 2000 03:32:20
Message: <39B89616.BC2C1C59@atos-group.com>
Follow-up set to povray.off-topic
> > > ... 8< ...Snip !
> > be a bug ?
> to his message ?
Yes.
Like I did !
In the address sub-panel, where you have the Group:  and other,
simply change the combo of the empty line to Follow-Up and then
fill in the line.
Date: 8 Sep 2000 11:30:00
Message: <39b905f8@news.povray.org>
Could someone please tell me in which group the original post of this is?
In article <39B83BD7.105FFC75@online.no> , Tor Olav Kristensen
>> ... 8< ...Snip !
>> the parameters
> this problem.
> rotations.
> be a bug ?
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
e-mail: tho### [at] trfde
Date: 8 Sep 2000 11:32:12
Message: <39B9060F.2773BD2C@pacbell.net>
I'm pretty sure that it was in .binaries.images.
Date: 8 Sep 2000 11:39:46
Message: <39b90842@news.povray.org>
Subject : Two broken Blobs (Bug ?) (8KB)
Date : 04 September 2000 21:30
Kev
Pov-Gallery & Homepage: http://web.libertysurf.co.uk/kevin.ellis
Date: 9 Sep 2000 10:56:17
Message: <39ba4f91$1@news.povray.org>
In article <39B9060F.2773BD2C@pacbell.net> , Ken <tyl### [at] pacbellnet>
In article <39b90842@news.povray.org> , "Kevin Ellis"
> From : Tor Olav Kristensen
Thanks!   I have been able to verify the bug and bug fix with a problem that
was on our list of outstanding 3.5 bugs, and I have posted the bug report
and bug fix in povray.bugreports.
Thanks J. Grimbert, you helped getting 3.5 out a few days sooner!
      Thorsten
