POV-Ray : Newsgroups : povray.general : 4.0 Feature discussion Server Time
18 Jul 2026 02:47:54 EDT (-0400)
  4.0 Feature discussion (Message 1 to 10 of 94)
Subject: 4.0 Feature discussion
Date: 7 Sep 2000 09:51:40
Message: <39B79C30.E480F2D9@my-dejanews.com>
1) PROGRESSIVE RENDER.
The one thing I like about Bryce is that it does a progressive render:
first shows you a 40 x 30 render of your scene, then a 160 x 120, and so
on up to the resolution you're asking for. When positioning my camera, I
often want to do something like this. If I have a really complex object
or special effect, I have to wait a long time to see the "feet" of my
image just to see if it's positioned right.   I suppose I could change
my quickres.ini file to include these scenes and do the extra dozen
mouseclicks each time to see a progressively greater resolution, but
isn't that what we have computers for?
2) VOLUME
I'd like to be able to know the volume of an object.
Subject: Re: 4.0 Feature discussion
Date: 7 Sep 2000 09:57:52
Message: <39B79DE0.53E39FA4@skynet.be>
You will be happy : it's already there !! Command-line options
+SP +EP ..
> 2) VOLUME
For simple primitives, knowing the volume is easy.  For more
complex stuff, you could write a #macro that samples the volume
of an object, using the "object" pattern (in MegaPOV).
Fabien.
Date: 7 Sep 2000 10:07:18
Message: <39B79FDF.16E6555D@my-dejanews.com>
> +SP +EP ..
Could you please tell me the menu for the Windows version and the phrase
I could add to POVRAY.INI?
> > 2) VOLUME
> Fabien.
I can imagine how to do this with a few zillion trace calls and counting
cubes, but not immediately how to do with object pattern.
Date: 7 Sep 2000 10:46:42
Message: <39b7aa52@news.povray.org>
Ian
Inkwell: Ian's Homepage
http://www.topcities.com/cartoon/inkwell/index.htm
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:39B79C30.E480F2D9@my-dejanews.com...
What's wrong with mosaic preview?? from memory its +sp in the .ini file
followed by a multiple of 4.  +sp 32 for example.
Ian
Date: 7 Sep 2000 11:15:56
Message: <39B7AFF0.B38E4942@my-dejanews.com>
Wow! This is neat!
For us non-switch-typing mortals, we would add
Preview_Start_Size=4
to POVRAY.INI,
Date: 7 Sep 2000 12:14:55
Message: <39B7BF02.96081D7D@yahoo.com>
that's why it's a good idea to have a printed version of the docs and to
read them once a month.  there's always something new to learn.
> Wow! This is neat!
> to POVRAY.INI,
Date: 7 Sep 2000 12:49:14
Message: <39b7c70a$1@news.povray.org>
news:39B7AFF0.B38E4942@my-dejanews.com...
> Wow! This is neat!
> to POVRAY.INI,
In megaPov, Mosaic preview doesn't work with radiosity enabled.... and even
if you turn radiosity off, the preview won't work until you restart MegaPov.
I'd call that a bug ;-)
sorry just a random rant.....
Ian
Date: 7 Sep 2000 16:11:03
Message: <39b7f657$1@news.povray.org>
I would really like that POV-4 had associative arrays of heterogeneous
elements. For example:
arr["location"] = <1,1,1>;
arr["texture"] = texture { ... }
arr["show"] = true;
etc.
Why?
Well, with this kind of containers it would be possible to fake object
oriented programming. For example
#macro MySmartBox_Create(this)
    this = assoc_array();
    this["location"] = 0;
    this["side"] = 1;
#macro MySmartBox_Display(this)
    object {
        this["location"] - <Side/2, Side/2, Side2>,
        this["location"] + <Side/2, Side/2, Side2>
            this["texture"]
etc.
Having associative heterogeneous arrays + macros is all that is needed for
OOP in POVRay.
Date: 7 Sep 2000 16:15:18
Message: <slrn8rfuir.rb.ron.parker@fwi.com>
>OOP in POVRay.
Careful there, you'll get Warp all revved up again.  What you're talking
about is structured programming, not OOP.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 7 Sep 2000 16:37:52
Message: <chrishuff-B14C76.15393807092000@news.povray.org>
In article <39B79FDF.16E6555D@my-dejanews.com>,
Use eval_pattern() with the object pattern, using the object you are
calculating the volume of as the control object for the pattern. Check
eval_pattern() multiple times in a 3D grid and use the results to
calculate the volume.
Christopher James Huff
