POV-Ray : Newsgroups : povray.general : Collision detection: will this work? Server Time
26 Mar 2026 01:05:17 EDT (-0400)
  Collision detection: will this work? (Message 1 to 4 of 4)
Subject: Collision detection: will this work?
Date: 6 Sep 2000 11:21:46
Message: <39B65FC4.4A8EB992@my-dejanews.com>
Would this work? I am afraid that it will not because povray (megapov),
I fear, is very lazy about giving true information in the min &
max_extent functions....
#declare CollisionVolume=
    intersection{
        object{Object_A}
        object{Object_B}
#declare DiagCollVolume=
    <0,0,0>+max_extent(CollisionVolume)-min_extent(CollisionVolume);
#if(vlength(DiagCollVolume >0)
    BOOM!
Subject: Re: Collision detection: will this work?
Date: 6 Sep 2000 11:31:09
Message: <slrn8rcpkb.1f7.ron.parker@fwi.com>
You are right; it will not work, and for (essentially) the reasons you
note.  You wouldn't want it to not be lazy, by the way: it would get
much much slower if it did.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 6 Sep 2000 12:15:35
Message: <chrishuff-42A7BC.11171806092000@news.povray.org>
In article <39B65FC4.4A8EB992@my-dejanews.com>,
It isn't "being lazy", those functions just return the min and max
extents of the bounding box. You shouldn't expect it to give the actual
extents of the object.
Maybe these functions should be called min_bbox() and max_bbox()
instead, and the *_extent() functions should attempt to find the true
extents by tracing a bunch of rays at the object. This will be slower,
but still useable(it is useable even when implemented in POV-Script).
There may be portions of the objects that don't get hit, but if you need
a bounding box that is guaranteed to enclose the whole object, you
should use the *_bbox() functions.
Christopher James Huff
Date: 6 Sep 2000 12:48:09
Message: <39B6740D.6C2354A8@my-dejanews.com>
#declare Precision=100;  //  sqrt( number of samples you want to take)
    intersection{
        object{Object_A}
        object{Object_B}
#declare Norm=<0,0,0>;
#declare Corn1=max_extent(CollisionVolume);
#declare Corn2=min_extent(CollisionVolume);
#declare BOOM=false;
#declare nx=0;
#while(nx<Precision)
#declare ny=0;
#while(ny<Precision)
#declare
Tracer=trace(CollisionVolume,<Corn1.x+(Corn2.x-Corn1.x)*nx/Precision,Corn1.y+(Corn2.y-Corn1.y)*ny/Precision,Corn1.z-100>,z,Norm;)
#if(vlength(Norm) >0)
    #declare BOOM=true;
#declare ny=ny+1;
#declare nx=nx+1;
#if (BOOM=true)
    //do something here
// Yes, we need a separate function to do this for us!
// I would actually prefer a function:
#declare Volumey= volume(CollisionVolume)
#if(Volumey>0)
    //do something here
This would also be of use in my flocking animations where I want to avoid
collisions with objects. I propose that the best feedback for goodness of an
algorithm would be a simple measure of the volume of the intersection between
my flock and the object to be avoided.  Instead, I often have to compose a
bunch of pictures and look to see if there have been any intersections.  This
is of course using povray--"the Raytracer, Not a Modeller".
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
