POV-Ray : Newsgroups : povray.general : Feature Request: Easy Iso Server Time
21 Jun 2026 08:19:22 EDT (-0400)
  Feature Request: Easy Iso (Message 1 to 10 of 14)
Subject: Feature Request: Easy Iso
Date: 8 Aug 2000 16:46:05
Message: <3990718d@news.povray.org>
I think one powerful feature of isosurfaces are the ability to add actual
bumps etc. to an object instead of faking it with normals.
However, you need to know the function of the object. While this can be easy
with very simple objects, it can be very complicated with more complicated
objects.
I think it would be really handy if POV-Ray could automatically convert
regular objects into isosurface functions. Like this:
function {
   cone { x, 0.3, <1,2,0>, 0.2 translate z }
If it worked with CSG objects too, it would be *really* handy!
Another and completely different idea would be to add an "iso_normal"
feature to regular objects. Like this:
cone {
   iso_normal { bumps 0.2 scale 0.3 turbulence 0.2 }
   translate z
Using an iso_normal would then convert the object to an iso_surface with a
function according to the mother object, and then it would also add the
iso_normal function to the object function.
These ideas are in no way complete, and I don't know if they are realistic
at all, but I still post them in the hope that they might be, or that they
maybe can inspire someone to make something else, that I hadn't thought of
myself. It doesn't hurt anyway...
Greetings,
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated July 23)
/ Also visit http://www.povrayusers.org
Subject: Re: Feature Request: Easy Iso
Date: 9 Aug 2000 05:26:13
Message: <399123b5@news.povray.org>
Rune <run### [at] inamecom> wrote:
: I think one powerful feature of isosurfaces are the ability to add actual
: bumps etc. to an object instead of faking it with normals.
  I wouldn't say that isosurfaces ADD bumps to ANY object. You can't add
bumps to a sphere using an isosurface. What you can do is make an isosurface
with the shape of a sphere and then modify the surface.
: However, you need to know the function of the object. While this can be easy
: with very simple objects, it can be very complicated with more complicated
: objects.
  There are named functions already (like "sphere", "torus" and so on). Of
course the list could be bigger.
: I think it would be really handy if POV-Ray could automatically convert
: regular objects into isosurface functions. Like this:
: function {
:    cone { x, 0.3, <1,2,0>, 0.2 translate z }
  Yes, it could be handy, but how easy?
  How do you convert a julia_fractal to an isosurface? What about 'text'?
Bicubic patches? Meshes? Polygons?
  What about infinite surfaces like planes and polys? An isosurface can't be
infinite since it has to be contained by a finite object.
: If it worked with CSG objects too, it would be *really* handy!
  Most CSG is easy. However, I don't know how easy is to make a (true) union
of shapes with isosurfaces (the union has the peculiar feature that it has
inner surfaces which are not removed like in merge).
: Another and completely different idea would be to add an "iso_normal"
: feature to regular objects. Like this:
: cone {
:    x, 0.3, <1,2,0>, 0.2
:    iso_normal { bumps 0.2 scale 0.3 turbulence 0.2 }
:    translate z
: Using an iso_normal would then convert the object to an iso_surface with a
: function according to the mother object, and then it would also add the
: iso_normal function to the object function.
  This can be hard for many objects, as described above. And there's also one
problem: How to calculate the contained_by object? Some objects do not have
even bounding boxes (not even finite ones, like polys, quartics or quadrics
with proper parameters).
  You ideas are very good, though.
Date: 9 Aug 2000 06:31:49
Message: <39913315@news.povray.org>
"Warp" wrote:
> : to add actual bumps etc. to an object instead of faking it
> : with normals.
> You can't add bumps to a sphere using an isosurface. What you
> can do is make an isosurface with the shape of a sphere and
I know that what you're saying is correct, but I already knew that; I just
formulated myself a little bit incorrect. Other people would probably know
what I meant.
I've noticed before that you take what other people say very very literally.
Since not everybody like to spend a lot of time constructing 100% correct
sentences, maybe it would be better with a little more "tolerance" when
interpreting sentences? :-)
> and so on). Of course the list could be bigger.
The sphere one is inconsistent with regular spheres because you can't set
the center point.
But more important, a lot of objects like cones, cylinders, boxes, are as
far as I know not build in. It would be nice to have as many as possible of
those supported, and if the syntax could be similar to the syntax of regular
shapes, then that would be preferred.
> about 'text'? Bicubic patches? Meshes? Polygons?
It would still be nice if just some of the object types could be supported.
> isosurface can't be infinite since it has to be contained by
> a finite object.
But the function itself can. Then the user can decide for himself which
container object to use.
> make a (true) union of shapes with isosurfaces (the union
> has the peculiar feature that it has inner surfaces which
It would still be nice if just some of the CSG operations were supported.
And it wouldn't bother me personally if union worked like merge. In regular
CSG I think the only advantage union has over merge, is that it is faster
(for objects that are not transparent).
Greetings,
Rune
Date: 9 Aug 2000 09:54:41
Message: <399162a1@news.povray.org>
: I've noticed before that you take what other people say very very literally.
  I'm sorry. I'm too perfectionist.
Date: 9 Aug 2000 19:27:43
Message: <3991EAB3.767C640E@pilot.msu.edu>
Ha thats funny since it does not sound quite perfect to me.
Date: 9 Aug 2000 21:21:27
Message: <chrishuff-E88127.20223009082000@news.povray.org>
In article <399162a1@news.povray.org>, Warp <war### [at] tagpovrayorg>
That is usually "too much of a perfectionist", or "too perfectionistic".
Sorry, couldn't resist. :-)
Date: 9 Aug 2000 22:07:03
Message: <39920E80.B2D662D0@hotmail.com>
Warp wrote:
<snip>
"object" pattern ? - probably would only work for solid objects
These may not work
I agree
Bye
Pabs
Date: 9 Aug 2000 22:51:12
Message: <chrishuff-F2A71D.21521609082000@news.povray.org>
In article <39920E80.B2D662D0@hotmail.com>, Pabs <pab### [at] hotmailcom>
wrote:
> "object" pattern ? - probably would only work for solid objects'
The object pattern will only work for objects that are solid, and it
isn't very friendly with the isosurface solving method. It is a "block
pattern", and has only one of two states...basically meaning it has an
infinite max_gradient. The isosurface algorithm can't easily cope with
this.
> >   can't be
> These may not work
Bicubic patches might be approximated with a function of some sort,
though you might have to clip the resulting surface yourself. Polygons
wouldn't be possible, but prisms would be. Plane, quadratic, poly,
quartic, etc would work fine, they would just be clipped to the
contained_by object. Meshes...I don't think there is an easy way to
support meshes. Maybe if you used a sort of proximity pattern(optimized
for meshes, of course)...
> I agree
As do I...many of the object *could* have built in functions.
As for the existing built in functions, I really hope their syntax is
changed if they are included. It is really non-standard, non-POV, and
inconsistent.(Parameters in a vector?!? Function names in a string?
Results affected by the size of the bounding box? Etc...)
Date: 10 Aug 2000 12:35:05
Message: <slrn8p5n4f.ht.ron.parker@fwi.com>
I'm pretty sure they'll either be changed or removed.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 10 Aug 2000 21:47:40
Message: <39935B79.F23DA32@hotmail.com>
Ron Parker wrote:
>  removed.
???????????? Why
IMVHO I don't think they should be removed esp the superellipsoid type
one.
Bye
Pabs
