POV-Ray : Newsgroups : povray.general : generating surface with X,Y,Z-axis coordinates Server Time
26 May 2026 22:19:10 EDT (-0400)
  generating surface with X,Y,Z-axis coordinates (Message 1 to 3 of 3)
Subject: generating surface with X,Y,Z-axis coordinates
Date: 2 Aug 2000 10:05:49
Message: <39882abd$1@news.povray.org>
Hi ...
I would like generate smooth sufrace with X,Y,Z -axis coordinates. But I can
see any example showing how can I create it.
Any advice for my problem ?
Subject: Re: generating surface with X,Y,Z-axis coordinates
Date: 2 Aug 2000 11:00:00
Message: <3988376f@news.povray.org>
oto <oto### [at] kramaresavbask> wrote:
: I would like generate smooth sufrace with X,Y,Z -axis coordinates. But I can
: see any example showing how can I create it.
  You should be more specific.
  What do you mean by "with X,Y,Z -axis coordinates"?
  Do mean that you would like to specify a f(x,y,z) function from which the
surface is calculated?
  Or do you mean that you would supply a series of points from which the
surface is formed?
  Something else?
Date: 2 Aug 2000 18:12:34
Message: <qk6hosk3p735upbqa228u1o2dv1cop6r7g@4ax.com>
  Reading oto's original post, it almost sounds like a simple plane is
all they are looking for...
  If so, oto, I would suggest reading the POV-Ray documentation,
specifically section 2.2.4.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
