POV-Ray : Newsgroups : povray.general : undocumented isosurfaces functions Server Time
28 Oct 2024 13:21:13 EDT (-0400)
  undocumented isosurfaces functions (Message 1 to 4 of 4)
Subject: undocumented isosurfaces functions
Date: 27 Jul 2000 04:38:58
Message: <397FF3F8.1CD236F3@skynet.be>
Could someone explain to me, briefly, the meaning of the following
isosurfaces functions :
r, s, %, min(), max().
Thank you very much.
Fabien.
Subject: Re: undocumented isosurfaces functions
Date: 27 Jul 2000 08:15:22
Message: <398026F5.1A04EED9@inapg.inra.fr>
min and max : see the file texture1.pov in the megapov demos, for
instance :
#declare GRID1=    function  {min(min(abs(cos(z)),
abs(cos(y))),abs(cos(x)))}
r,s : something from the isoblob ?
G.
> Fabien.
Date: 27 Jul 2000 09:10:08
Message: <slrn8o0dsu.udn.ron.parker@fwi.com>
>instance :
% is the modulo operator, I'd guess.  (a%b) is the remainder when you divide
a by b.
I think r and s are reserved words but they don't actually do anything.  It
was a feature that was never completely implemented or something.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 27 Jul 2000 11:07:24
Message: <chrishuff-29B6FF.10080727072000@news.povray.org>
In article <397FF3F8.1CD236F3@skynet.be>, Fabien Mosen
min() and max() take two parameters, and return the lesser and greater
of the two respectively. min(A, B) will return A if it is lower than B,
and B if it is lower than A, max() does the opposite, returning the
greater value.
% is modulus
! is factorial
^ is exponentiation
t is the clock value, according to the function pattern documentation,
however, the isoblob functions also use r, s, and t. In isoblobs, they
are the coordinates of something...I'm not sure what, though. Looking at
the code, it seems to be coordinates in "component space", after the
transformations are done, while x, y, and z would be absolute,
non-transformed coordinates.
Take this with a grain of salt though...I find this portion of the code
difficult to read(argh, more global variables!).
