![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: 3D file formats, including Warps PCM format
Date: 18 Jul 2000 23:25:50
Message: <39751fbe@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Notice the effect that Warps mesh compressor had on the file size of the
POV file... dropped it from 12.6M to 3.12M... a 75% decrease in size.
Strata StudioPro (.vis) 1.29M
3D Studio (.3ds) 1.35M
TrueSpace (.cob) 1.88M
Imagine (.iob) 2.64M
DirectX (.x) 2.75M
Warps PCM (.pcm) 3.12M <======
Renderman (.rib) 3.64M
VRML (.wrl) 4.67M
Wavefront (.obj) 5.04M
Renderware (.rwx) 5.54M
AutoCAD (.dxf) 6.04M
Alias (.tri) 7.40M
OpenGL C code (.c) 7.68M
QuickDraw 3D (.3dm) 8.13M
stereolithography (.stl) 11.8M
POV (.pov) 12.6M
Pro/E (.slp) 16.8M
Lightscape (.lp) 19.1M
-Doug Eichenberg
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What about the POV mesh2 format ? It should be around 4-5 M I guess.
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: 3D file formats, including Warps PCM format
Date: 19 Jul 2000 19:08:26
Message: <397634ea@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there a utility to convert to Mesh2 format? I haven't really looked
into it yet...
- Doug Eichenberg
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> into it yet...
There are several of them (at least 3DS2POV, objuvpov, pose2pov). You can
look at this page here for more info :
http://www.mediaport.net/Artichaud/Tran/sources/tutuve.htm
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 20 Jul 2000 11:11:54
Message: <397716ba@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
By the way, did you use the default compression or the extra compression?
Could you try both? I'm interested in the size difference between the two
in this case.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 20 Jul 2000 17:17:44
Message: <39776c78$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Default.
> Could you try both? I'm interested in the size difference > between the
two in this case.
Sure. I'll check it out within the next couple days, along with mesh2.
- Doug Eichenberg
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 20 Jul 2000 17:19:28
Message: <39776ce0$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks. I'll check out the mesh2 size and post it here.
- Doug Eichenberg
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
