POV-Ray : Newsgroups : povray.general : post disappeared? Server Time
26 May 2026 23:42:36 EDT (-0400)
  post disappeared? (Message 1 to 10 of 11)
Subject: post disappeared?
Date: 16 Jul 2000 11:51:32
Message: <3971d977.2235143@news.povray.org>
Is it really true that my post on Height Fields has disappeared from
this group? I can't find it anymore neither with OE5 nor with Free
Agent... :~(
Subject: Re: post disappeared?
Date: 16 Jul 2000 12:04:55
Message: <3971DD30.A71AF6FE@kivisalo.net>
> this group?
I can see it with netscape. Ken replied with a link :)
K.K.
Date: 16 Jul 2000 12:06:54
Message: <3971DD9E.57956C64@schunter.etc.tu-bs.de>
> Agent... :~(
Is it the following:
Height fields (Sat, 15 Jul 2000 23:50:20)
> Where would I find easy-to-understand examples of what can and cannot be
> done with height fields? My results are unsatisfactory up till now: lots of
> black dots and very little smooth hills and valleys.. :(
I have it as a reply to:
Height fields (Mon, 16 Nov 1998 09:05:19)
that's a quite old message, so that's probably the reason you can not find your
one.
Date: 16 Jul 2000 13:24:07
Message: <3971efb7@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in message
news:3971DD9E.57956C64@schunter.etc.tu-bs.de...
your one.
Same name troubles then huh?  Seems a rare occurrence but maybe thinking up
unique subject headings should be considered.  Just to note: OE 5.5 isn't
having that problem, although I do recall one time in the past year when this
happened to someone else and it was shown in reply to the older unrelated
thread.  Not anymore I suppose under the latest IE update.  Unless it's
something to do with how your list is set, by date or subject.
Date: 16 Jul 2000 14:23:53
Message: <3971fdb9@news.povray.org>
In article <3971d977.2235143@news.povray.org> , rig### [at] wrongorg (Sander)
> Agent... :~(
Looks like the subject line is equal to that of a very old post.  The
simplest solution is to reduce the number of message subjects you download
by default.  Usually setting this number to 500 or 1000 is sufficient to see
all the recent messages of the past month.  Reducing the number also reduces
the download time and makes access to the groups faster.
Just see the online help of your newsreader(s) where to find the appropriate
setting.
     Thorsten
Date: 16 Jul 2000 16:38:01
Message: <39721d29@news.povray.org>
Thanks you all for resolving this mystery for me, I finally found it now
and, as Thorsten suggests it's high time I did something about it!
Regards,  Sander
Thorsten Froehlich <tho### [at] trfde> schreef in berichtnieuws
3971fdb9@news.povray.org...
> > Agent... :~(
see
reduces
appropriate
> setting.
>      Thorsten
Date: 17 Jul 2000 00:10:08
Message: <slrn8n52f6.nb.ron.parker@linux.parkerr.fwi.com>
>| From: "Michael A. Metheny" <lon### [at] vtedu>
>your one.
That's an ugly solution for a buggy newsreader.  A better idea is to dump
the piece o' crap newsreader and get something that works.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 17 Jul 2000 02:28:08
Message: <pv35nsgludp9s2ur1h9366ll33cifmjrol@4ax.com>
>Agent... :~(
I don't know if OE has such functionality but Agent can be instructed
whether to thread messages by their header or not (if not, they are
still threaded properly by the X-Ref header or something akin). Turn
this option off and you should see your message in a separate thread.
Peter Popov ICQ : 15002700
Date: 17 Jul 2000 05:32:33
Message: <3972d2b1@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] linuxparkerrfwicom...
You're right, although since I'm not having troubles enough to matter I can
manage to get by okay, especially if I don't need anything more than OE to read
and post.  Going through several other newsreaders just to see which I might
like more doesn't appeal to me at the moment.
That of course isn't of any help to Sanders, unless upgrading can work out
okay.  I have found that the earlier report of the file:// problem is //gone
(second pair on purpose to show) from OE 5.5 when IE 5.5 has been installed, I
can happily confirm.
Date: 17 Jul 2000 09:52:49
Message: <slrn8n64k0.th.ron.parker@linux.parkerr.fwi.com>
>>Agent... :~(
References:
