![](/i/fill.gif) |
I tried to use POV variables inside function declaration in
paramatric surface primitive and it told me, that
another variable than u and v in function definition.
I'am doing something bad or its normal?
I want to use it in curved stairway macro, where I
need "spiral tube" to represent railing.
Disnel
![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Vaclav Cermak who wrote:
>Hi,
You can predefine your function using any kind of variable you like. If
you don't predefine the function you can't used "parametric" variables
(such as x, y, z and r) but you can use other scalar variables.
E.g. you can't say:
parametric {
function sin(z), . . .
because you can't use a parametric variable in that position.
You *can* say
#declare A = 0.5;
parametric {
function sin(A*u), . . .
because non-parametric variables are allowed.
You can also say
#declare F1=function(sin(z))
parametric {
function F1(u,v,0), . . .
but the result probably won't behave in the way you expect.
I guess that what you probably want for the handrail to a spiral
staircase is something like the following: R1 is the radius of the
staircase; R2 is the radius of the handrail tube; F controls the
frequency of the helical turns.
#declare R1=1;
#declare R2=0.1;
#declare F=5;
parametric {
function R1*sin(F*v)+R2*sin(u),
v,
R1*cos(F*v)+R2*cos(u)
<-pi,-1>,<pi,1>
<-R1-R2,-1,-R1-R2>,<R1+R2,1,R1+R2>
But you could have achieved this result more easily with the built-in
"helix1" isosurface.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
