POV-Ray : Newsgroups : povray.general : Torus/Camera Angle Bug??? Server Time
18 Jul 2026 12:58:26 EDT (-0400)
  Torus/Camera Angle Bug??? (Message 1 to 4 of 4)
Subject: Torus/Camera Angle Bug???
Date: 21 May 2000 11:58:59
Message: <392807c3@news.povray.org>
Hey all,
Here's the code which causes the problem with the torus.  It seems that if
the camera is too far from a torus, the torus falls apart.  This problem
appears in official POV (3.1g.watcom.win32, Pentium 133, Windoz 98).
//       Version: POV 3.1 official
//   Description: possible bug when viewing a torus from a distance
//        Author: Eric L. Freeman
//        E-Mail: eri### [at] datasynccom
//      HomePage: www.datasync.com/~ericfree
file://#version unofficial MegaPov 0.5;
#declare CamNum = 1;  // 1 = close-up camera, no problem
                      // 2 = distant camera, torus problem
global_settings {max_trace_level 167}
#declare ThingPig = rgb <0,0,1>;
background {rgb <0.556,0.419,0.137>}
light_source {
  <100,200,-300> rgb <1,1,1>
  #switch (CamNum)
  #case (1)
    location <0,0,-100>
    look_at <0,0,0>
    angle 10
  #break
  #case (2)
    location <0,0,-10000>
    look_at <0,0,0>
    angle 0.1
  #break
cylinder {
  <-0.8,0,0>,
  <0.8,0,0>
  2
  pigment {ThingPig}
  rotate y*-45
sphere {
  <-5,0,0>, 2
  pigment {ThingPig}
torus {
  1.3, 0.7
  sturm
  pigment {ThingPig}
  rotate z*90
  rotate y*-45
  translate <5,0,0>
Eric
Subject: Re: Torus/Camera Angle Bug???
Date: 22 May 2000 03:57:42
Message: <3928e876@news.povray.org>
Eric Freeman <eri### [at] datasynccom> wrote:
: It seems that if
: the camera is too far from a torus, the torus falls apart.
  You should know that floating point numbers are not infinitely accurate.
Date: 22 May 2000 15:27:19
Message: <39298B43.F480FB23@mitre.org>
Eric Freeman wrote:
> Hey all,
> camera {
> torus {
>   1.3, 0.7
Size of distance from eye to torus ~ 10000.  After substitution into
fourth order equation, yields values ~1.0e16.  Solve for values of order
~0.01 (for a 1.3 rad torus filling 100 pixels).  Requires more than 18
digits of precision.
Double precision on standard Intel chips is ~15 decimal digits.
Result: lots of speckles in torus.
Fix: Intersect ray with bounding box of torus before solving quartic.
Move start point of ray to point of intersection.  Speckles go away.
Workaround for current POV-Ray?  Don't know, perhaps intersect torus
with a box that is a little bigger than it to force ray origin to be
closer.
Xander
Date: 23 May 2000 22:10:52
Message: <slrn8imf7o.359.ron.parker@linux.parkerr.fwi.com>
>closer.
I'd put it inside a 100% transparent box that's a little bigger, which
will cause POV to cast a new (transmitted) ray from the intersection
point with the box.  I'm guessing that the CSG intersection solution
won't work, but I haven't tried either.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
These are my opinions.  I do NOT speak for the POV-Team.
