POV-Ray : Newsgroups : povray.general : help w/simple macro Server Time
18 Jul 2026 15:54:15 EDT (-0400)
  help w/simple macro (Message 1 to 8 of 8)
Subject: help w/simple macro
Date: 19 May 2000 16:36:30
Message: <3925A6B6.CB89CD94@osu.edu>
Hi, ive recently been trying to ween myself off modellers and do some
hand coding. So I made a simple macro as practice, well.. it's short so
here it is. (my_spike is just a cone really)
#macro Make_Grid (spacing, size)
	#local grid = 0;
	#while (grid < size)
		#local zee = spacing * grid;
		#local copy = 0;
		#while (copy < size)
		object {
			my_spike
			translate <spacing*copy, 0, zee>
		#local copy = copy + 1;
	#local grid = grid + 1;
	//A cheap fix for it not putting a cone at <0,0,0>
	object { my_spike }
then i do:
#declare Grid_1 = Make_Grid(.5, 2)
and this renders and all. But how do I do anything with Grid_1 now? Say
I want to
rotate it 45*x and translate it 3*y.
Am I doing things at all close to correct? Thanks for the help...
Ross
Subject: Re: help w/simple macro
Date: 19 May 2000 17:44:50
Message: <3925B53F.DD41BC62@hotmail.com>
>         #local grid = 0;
>                 #local copy = 0;
>                 object {
>                         my_spike
>                 #end
>         #end
>         object { my_spike }
> #end
> then i do:
> I want to
> Ross
I have not tried your code,
but as far as I can see it looks OK.
Now you just have to change your last #declare to this
#declare Grid_1 =
union {
  Make_Grid(.5, 2)
  rotate 45*x
  translate 3*y
You could also have done this:
#macro Make_Grid(spacing, size)
  union {
    // place the rest of your
    // macro code here
#end // macro Make_Grid
And then the last declare could/should
be done like this:
#declare Grid_1 =
object {
  Make_Grid(.5, 2)
  rotate 45*x
  translate 3*y
And (of coarse) you can use other CSG operators instead of union
Tor Olav
mailto:tor### [at] hotmailcom
Date: 19 May 2000 18:03:59
Message: <3925BB39.44CB3208@osu.edu>
> #declare Grid_1 =
> union {
>   Make_Grid(.5, 2)
>   rotate 45*x
>   translate 3*y
> Tor Olav
Hey, thanks! I'm off to try it out.
Ross
Date: 19 May 2000 18:47:18
Message: <3925C3DF.4A4F0913@hotmail.com>
> #declare Grid_1 =
> union {
>   Make_Grid(.5, 2)
>   rotate 45*x
>   translate 3*y
Now I have read your question thoroughly.
(as I should have done in the first place :)
And I have also tested your code.
Below you find the code for my new suggestion.
The "big" difference is the passing of the
spike shape trough a variable; "Thing" to
the macro.
(POV-Ray does not force you to do this, but
I think this is good programming practice.)
#macro Make_Grid(Thing, spacing, size)
  #local xCnt = 0;
  #while (xCnt < size)
    #local zCnt = 0;
    #while (zCnt < size)
      object {
        Thing
        translate spacing*<xCnt, 0, zCnt>
      #local zCnt = zCnt + 1;
    #local xCnt = xCnt + 1;
#declare Spike = cone { <0, 0, 0>, 0.2, <0, 1, 0>, 0 }
#declare Grid_1 =
union {
  Make_Grid(Spike, 0.5, 6)
  pigment { color Yellow }
object {
  Grid_1
  rotate 45*x
  translate 3*y
Tor Olav
PS:
You can also have the macro apply changes
to the Thing object with #declare.
E.g.: In the macro you can say
#declare Thing = object { Thing scale <1, 2, 1> }
And then after you have called the macro
the Spike will be twice as high as before.
Date: 19 May 2000 19:14:05
Message: <3925CA25.AA9536C4@hotmail.com>
> the macro.
I forgot to mention that this enables you to
have the macro accept other shapes too.
Now you can do things like this:
#declare Grid_1 =
union {
#declare Grid_2 =
union {
  Make_Grid(sphere { y*0.8, 0.3 }, 0.5, 6)
difference {
  object { Grid_1 }
  object { Grid_2 }
  rotate 45*x
  translate 3*y
  pigment { color Red }
Tor Olav
Date: 19 May 2000 21:20:47
Message: <3925E95A.4157ED94@osu.edu>
> the macro.
I agree. I had thought about it since your first post. The one thing
that is not entirely intuitive to me is this part
#declare Grid_1 =
union {
object {
  Grid_1
  rotate 45*x
  translate 3*y
Now if I wanted two "Grids" I'd have to do another #declare Grid_2...
etc., and another object {Grid_2 ...}. Now this is how I thought it
would work. especially after reading (and misunderstanding, i presume)
the section in the povray docs about macros as functions that return
some value.
#declare Grid_1 = object{ Make_Grid(Spike, 0.5, 6) }
and then I hoped to be able to do something like
object {
	Grid_1
	rotate 45*x
	translate 3*y
I'm pretty sure I tried this, and I'm pretty sure it didn't do what I
expected. What I expected was what your initial solution did.
But anyway, this is all probably just a result of me not knowing the
language completely.
Thanks for your help,
Ross
Date: 20 May 2000 21:15:04
Message: <392737B3.F4C86EF1@hotmail.com>
8< .... snip ...
> The one thing
> #declare Grid_1 =
> union {
> object {
>   Grid_1
>   rotate 45*x
>   translate 3*y
> some value.
> object {
>         Grid_1
>         rotate 45*x
>         translate 3*y
You have to be aware that in POV-Ray macros does not behave
like functions in other languages.
(Someone please correct me if I'm wrong about the following:)
Macros in POV-Ray does not return function values.
They just return text that is to be pasted in where the
macro is called.
So the macro you posted;
  #local grid = 0;
    #local copy = 0;
      object {
        my_spike
  object { my_spike }
just generated a lot of "spike" objects. And these were
pasted in to the part of the code that called the macro:
Like this:
(The carriage returns, spaces and the extra .0 are
of coarse not correct.)
#declare Grid_1 = object {
                    my_spike
                    translate <0.0, 0, 0.0>
                  object {
                    my_spike
                    translate <0.5, 0, 0.0>
                  object {
                    my_spike
                    translate <0.0, 0, 0.5>
                  object {
                    my_spike
                    translate <0.5, 0, 0.5>
                  object {
                    my_spike
As you see the first spike object is assigned to
the Grid_1 variable and the others are just left
to be rendered were they now are.
(This is why there was missing a cone at <0, 0, 0>
and I believe that this lead you to do the "cheap fix":
To add a last cone at this position (origo). :)
Now the Grid_1 variable contains a single cone
object and that object is rotated and translated
when one does this:
object {
  Grid_1
  rotate 45*x
  translate 3*y
So then one ends up with 5 cones:
1 rotated and translated
4 in the xz-plane.
Then I came and suggested to put the code that
called the macro into a union operator:
#declare Grid_1 =
union {
  Make_Grid(.5, 2)
  rotate 45*x
  translate 3*y
This time the result of calling the macro
is this:
#declare Grid_1 =
union {
  object {
    my_spike
  object {
    my_spike
  object {
    my_spike
  object {
    my_spike
  object {
    my_spike
  rotate 45*x
  translate 3*y
The Grid_1 variable now contains a union of all
the 5 cone objects. And note that now they are
all rotated and translated away from the xz-plane
together.
Now all that is needed to make this new object
visible is to just write the name of the variable
that holds it.
Like this:
Grid_1
If you want to do further "operations" on this
object, then just put the name of the variable
inside an object declaration and apply more
"operations" to it.
E.g.:
object {
  Grid_1
or:
difference {
  object { Grid_1 translate  y/16 }
  object { Grid_1 translate -y/16 }
The fact that macros returns text instead of
function values can be exploited in other
ways than I have shown here.
E.g.:
One cane make macros that passes arrays
of 2D points to a lathe shape.
Instead of having to type in all the points
manually inside the shape statement, the
macro reads them out of an array (that is
passed to the macro) and pastes them into
the brackets of a lathe statement with all
the necessary commas.
I can show you examples of how to do
things like this with macros if you are
interested.
Hope this helped.
Tor Olav
Date: 21 May 2000 23:21:24
Message: <3928A8A2.639439E3@osu.edu>
::snip::
> interested.
> Hope this helped.
> Regards,
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
wow. your help has been greatly appreciated to say the least. Thankyou.
I'm going to have to read all your posts now for every other topic :)
Of course i'm interested! But i'll just keep messing around with things
for now.
thanks again,
ross
