POV-Ray : Newsgroups : povray.general : Rayleigh Scattering in Pov Ray Server Time
16 Jan 2026 02:17:16 EST (-0500)
  Rayleigh Scattering in Pov Ray (Message 1 to 8 of 8)
Subject: Rayleigh Scattering in Pov Ray
Date: 26 Apr 2000 07:29:29
Message: <3906d319@news.povray.org>
Hello All
Is there anyone out there who could provide me with some sort of code for
implementing Rayleigh scattering equation.
I a currently trying to implement a model for the atmosphere, but I need the
right from of scattering equation for this to work.
Thanks.
Ammar
Subject: Re: Rayleigh Scattering in Pov Ray
Date: 26 Apr 2000 09:28:32
Message: <chrishuff_99-849F96.08313226042000@news.povray.org>
In article <3906d319@news.povray.org>, "Ammar" <a.a### [at] ueaacuk>
> need the right from of scattering equation for this to work.
There is already Rayleigh scattering...scattering media type 3. Are you
trying to implement wavelength dependant Rayleigh scattering?
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 26 Apr 2000 15:36:25
Message: <oogegscuvkcuspnpa61c54tg09h153h4kg@4ax.com>
On Wed, 26 Apr 2000 08:31:32 -0500, Chris Huff
Because if you are, too bad, as you currently can't. IIRC a patch is
being to implement wavelength dependant Rayleigh scattering but I
don't know what its progress is.
Peter Popov ICQ : 15002700
Date: 26 Apr 2000 16:21:53
Message: <chrishuff_99-B105FE.15245326042000@news.povray.org>
In article <oogegscuvkcuspnpa61c54tg09h153h4kg@4ax.com>, Peter Popov
I had the impression Ammar was trying to write a patch which adds
Rayleigh scattering, which is evidently not the case. Also, Rayleigh
scattering is media type 4, not 3 as the documentation states.
Date: 27 Apr 2000 01:13:24
Message: <3907cc74$1@news.povray.org>
Peter Popov wrote in message ...
Current progress is that it is almost complete.  However, I'm running into
the problem of oversaturation of colors near the horizon.  Consequently, the
image looks just fine -- until you get to the horizon.  At that point, the
sky turns white.
I'm waiting for the "film effect" post-processing to be implemented to see
if this will fix the problem.  If people want me to, by next Thursday I
could release a version that doesn't have this problem fixed.
Mark
Date: 27 Apr 2000 14:14:32
Message: <39088388@news.povray.org>
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3907cc74$1@news.povray.org...
Well, I for one won't stop you from doing so.
Date: 28 Apr 2000 02:56:34
Message: <7m8igs024ej0nm5t62hpv4r1ob538qv9bt@4ax.com>
On Thu, 27 Apr 2000 01:15:06 -0400, "Mark Wagner"
>sky turns white.
Well, maybe you could fake it by decreasing brightness by an
exponential factor. Not quite realistic, I guess, but it will look as
expected and that what usually counts.
This would basically take the same approach, right? I mean, applying a
nonlinear curve to input/output brightness to desaturate the upper
levels.
Date: 29 Apr 2000 01:49:27
Message: <390a77e7@news.povray.org>
Peter Popov wrote in message <7m8igs024ej0nm5t62hpv4r1ob538qv9bt@4ax.com>...
the
>>sky turns white.
The problem is figuring out how to do this while computing the media.  It
would be much easier to do this after the image is rendered.
>levels.
Yes, but as I said above, it is easier to implement.
Mark
