POV-Ray : Newsgroups : povray.general : implicit and parametric surfaces ? Server Time
21 Jun 2026 18:41:32 EDT (-0400)
  implicit and parametric surfaces ? (Message 1 to 6 of 6)
Subject: implicit and parametric surfaces ?
Date: 14 Apr 2000 19:08:02
Message: <38f7a4d2@news.povray.org>
Hi !
how can I render implicit and parametric surfaces with povray without
using any external programs ?
I have tried to make lots of smooth_triangles with some macros, but you
can clearly see the edges of these triangles (ugly).
Any hints ?
Achim
Subject: Re: implicit and parametric surfaces ?
Date: 14 Apr 2000 19:32:03
Message: <38F7AD64.EA2CC6FF@erols.com>
> Hi !
I use pencil and paper.
> you can clearly see the edges of these triangles (ugly).
> Any hints ?
Use smaller triangles.
ICQ: 46085459
Date: 14 Apr 2000 19:53:32
Message: <chrishuff_99-ABE5E1.18561514042000@news.povray.org>
Depends on what you mean by "external programs". You can use an
unofficial version of POV-Ray which has been modified to support
isosurfaces and parametric objects, like MegaPOV:
http://nathan.kopp.com/patched.htm
Well, make sure your normal calculating code is right, otherwise you can
just use smaller triangles and more of them. This can use up your memory
quite fast, though...
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 14 Apr 2000 19:54:32
Message: <38f7afb8@news.povray.org>
"John VanSickle" <van### [at] erolscom> schrieb im Newsbeitrag
news:38F7AD64.EA2CC6FF@erols.com...
> > Hi !
without
and how many triangles can you draw per hour ? (SCNR)
> > Any hints ?
I don't think that this is the problem. It must be something else. Apart
from that, I don't
want to calculate the derivatives used to form the normals by hand.
Below is my attempt to create the sombrero as a mesh of
smooth_triangles. Perhaps someone can find the problem.
Achim
<snip--->
global_settings { assumed_gamma 1.0 }
camera
  location  <2, 2, -2>
  look_at   <0, 0, 0>
background { color rgb <0, 0, 0> }
light_source { <20, 20, -10> colour 1 }
// Set up the loop variables:
// the xc & zc variables will go from -1.0 to +1.0
// in NumIterations loops.
#declare NumIterations = 10; // try 6 to 16
#declare Increment     = 1.0/(NumIterations*2);
#declare yStretch      = 0.25;
//#declare pi          = 3.141592653589793238462643383279502884197169399375105820975;
//helper functions
#macro function(px, pz)
 (sin(sqrt(px*px+pz*pz)*4*pi))
#macro dfdx(px, pz)
 (px*cos(sqrt(px*px+pz*pz)*4*pi)/(2*sqrt(px*px+pz*pz)))
#macro dfdz(px, pz)
 (pz*cos(sqrt(px*px+pz*pz)*4*pi)/(2*sqrt(px*px+pz*pz)))
#macro tangentx(px, pz)
 (<1.0, dfdx(px, pz), 0.0>)
#macro tangentz(px, pz)
 (<0.0, dfdz(px, pz), 1.0>)
#macro normalxz(px, pz)
 (vcross(tangentx(px, pz), tangentz(px, pz)))
#macro MakeQuad(px, pz)
// #debug concat("quad (", str(px, 0, 3), "/", str(py, 0, 3), "/", str(pz, 0, 3), ") ,
(", str(px + Increment, 0, 3), "/", str(py
, 0, 3), "/", str(pz + Increment, 0, 3), ")\n")
 smooth_triangle
  <px,     yStretch*function(px, pz),       pz>,
  normalxz(px, pz)
  <px + Increment, yStretch*function(px + Increment, pz),    pz>,
  normalxz(px + Increment, pz)
  <px,     yStretch*function(px, pz + Increment),    pz + Increment>
  normalxz(px, pz + Increment)
 smooth_triangle
  <px,     yStretch*function(px, pz + Increment),    pz + Increment>,
  <px + Increment, yStretch*function(px + Increment, pz + Increment), pz
+ Increment>
  normalxz(px + Increment, pz + Increment)
mesh
 #declare zc = -1.0;
 #while (zc < 1.0)
  #declare xc = -1.0;
  #while (xc < 1.0)
   MakeQuad(xc, zc)
   #declare xc = xc + Increment;
  #declare zc = zc + Increment;
 texture
  pigment
   color rgb <1, 0, 0>
  finish
   ambient 0.2 specular 0.7 roughness 0.05 reflection 0.3
<snip--->
Date: 15 Apr 2000 10:33:04
Message: <38F87DF2.95BAB3E4@planete.net>
A patch PovRay version enabling isosurface will do fine.
D.M.
Date: 15 Apr 2000 19:34:01
Message: <38F8FF5D.7B40C2D2@erols.com>
> > > Hi !
> without
I don't.  I use the pencil and paper to write the POV script that
generates the triangles.
John
ICQ: 46085459
